oonan Posted December 10, 2017 Share Posted December 10, 2017 Hello, master. I need your help for this lisp, it is my old lisp to get areas from objects but does not work in autocad 2016, i think that is in the bpoly funcion but i dont know how to fix the error: "No function definition: vlax-ename->vla-object" (vl-load-com) (defun arear (clave / nentpoly area os listapolys caso 2dacadena contador0 contador1 *Error*) (DEFUN *ERROR* (msg) (PRINC "Error >> ") (princ msg) (if (= msg "Function cancelled") (arearmistake1) (arearmistake2)) (quit) ) (defun arearmistake1 () (alert "\nFuncion Cancelada") (setvar "osmode" os) (foreach caso listapolys (entdel caso)) (setvar "cecolor" colorant) (setvar "Clayer" CapaActual) (princ) ) (defun arearmistake2 () (alert "\nEl contorno no esta Cerrado") (setvar "osmode" os) (foreach caso listapolys (entdel caso)) (setvar "cecolor" colorant) (setvar "Clayer" CapaActual) (princ) ) (setq CapaActual (getvar "Clayer")) (if (null (tblobjname "STYLE" "R-80")) (entmake '((0 . "STYLE")(100 . "AcDbSymbolTableRecord")(100 . "AcDbTextStyleTableRecord") (2 . "R-80")(70 . 0)(40 . 0.18)(3 . "ROMANS"))) ) (if (null (tblobjname "LAYER" "A-TEXTOS 10")) (entmake '((0 . "LAYER")(100 . "AcDbSymbolTableRecord")(100 . "AcDbLayerTableRecord") (2 . "A-TEXTOS 10")(70 . 0)(62 . 10)(370 . -3))) ) (setq contador0 0) (setq contador1 0) (setq area 0.0 os (getvar "osmode")) (setvar "osmode" 4) (setq colorant (getvar "cecolor")) (setvar "cecolor" "201") (While (setq nentpoly (bpoly (getpoint "\n<Indique punto(s)>(intro para terminar):"))) (redraw nentpoly 3) (setq contador0 (1+ contador0)) (setq area (+ area (vlax-curve-getArea (vlax-ename->vla-object nentpoly))) listapolys (cons nentpoly listapolys)) (princ (strcat (fnum area) " m2")) (setq contador1 (1+ contador1)) (setq areax (vlax-curve-getArea (vlax-ename->vla-object nentpoly))) (princ (strcat "\n(AREA " CLAVE " "(itoa contador0)") (ACUMULADO: " (fnum area) " m2) " "(PARCIAL: " (fnum areax) " m2)")) ) (setq areac (fnum area)) (prompt (strcat "\nAREA TOTAL DE " clave ": " areac " m2"))(terpri) (setvar "cecolor" colorant) (entmake (list '(0 . "TEXT")'(100 . "AcDbEntity")'(8 . "A-TEXTOS 10")'(100 . "AcDbText") '(62 . 256)'(10 0.0 0.0 0.0)(cons 40 0.18)(cons 1 (strcat clave " = " areac "m2")) '(50 . 0.0)'(41 . 1)'(51 . 0.0)'(7 . "R-80")'(72 . 2) (cons 11 (getpoint "\n<Punto para colocar el texto>"))'(210 0.0 0.0 1.0)'(100 . "AcDbText")'(73 . 1))) (foreach caso listapolys (entdel caso)) (setvar "osmode" os) (prin1) ) (defun fnum (num) (setq f 2) ;redondea a 2 decimales (setq int (rtos num 2 f) pos (vl-string-search "." int) pos (if pos pos (strlen int)) fp (substr int (+ pos 2) (strlen int)) int (substr int 1 pos)) (while (< (strlen fp) f) (setq fp (strcat fp "0"))) (repeat (/ pos 3) (setq int (strcat (substr int 1 (- pos 3)) "," (substr int (- pos 2) (strlen int))) pos (- pos 3))) (vl-string-left-trim "," (if (zerop f) int (strcat int "." fp)) ) ) (defun c:CRP () (arear "CARPETA ASFÁLTICA")) thank you for your attention. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted December 11, 2017 Share Posted December 11, 2017 Add (vl-load-com) to your code. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 11, 2017 Share Posted December 11, 2017 See here: http://www.cadtutor.net/forum/showthread.php?1390-How-to-use-the-LISP-routines-in-this-archive&p=339645&viewfull=1#post339645 Quote Link to comment Share on other sites More sharing options...
rlx Posted December 12, 2017 Share Posted December 12, 2017 (edited) since the very first line of OP's code begins with (vl-load-com) my first thought would be to check if the visual lisp functions are loaded (vl.arx) in the first place. p.s. function works here on my pc (autocad 2016) so you might have to (re)install / enable vlisp Edited December 12, 2017 by rlx Quote Link to comment Share on other sites More sharing options...
oonan Posted December 14, 2017 Author Share Posted December 14, 2017 thanks to all, a try but the (vl-load-com) is at the beginning so I can only review the vl.arx but I do not know how to do it Quote Link to comment Share on other sites More sharing options...
rlx Posted December 14, 2017 Share Posted December 14, 2017 When you start vlisp , the visual lisp editor , if the visual lisp library is successfully loaded and vl-load-com is loaded , commands like 'vl-catch-all-apply' should appear in blue. If not , you should probably reinstall AutoCAD or search your system for vl.arx and load it via menu : tools->autolisp->load application gr.Rlx Quote Link to comment Share on other sites More sharing options...
rlx Posted December 14, 2017 Share Posted December 14, 2017 Also , creation of style failed so creation of text object will also fail. Made a few small mods to your code. gr. Rlx CRP.LSP Quote Link to comment Share on other sites More sharing options...
