Results 1 to 2 of 2
    Full Member
    AutoCAD 2017
    Dec 2015
    Aus
    92
    Default reinforcement dynamic block
    Hi All,
    Was wondering if someone would be able to assist with this dynamic block (attached) that i'm trying to set up. I've been trying to make a block for showing reinforcement on details which would show main bar (just a line) along with distribution bars (dots) which you can stretch to suit.
    Ive gotten quite close to getting that sorted but theres a couple more things i'd like to do which I can't seem to work out.
    firstly, the dot for distribution steel is an array action set to 300c/c which works fine when you stretch to the right but not the left. It seems to leave behind the original dot instead of moving it also
    secondly, when you stretch the line it would be good if the dots for distribution steel could also move with it. At the moment they need to be stretched separately
    Any help would be greatly appreciated!
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,400
    have a look at the recent post by Bill Tillman about "picket fence" which had similar questions about right and left.
  1. How Can I Make Reinforcement Lisp
    By wrha in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Nov 2016, 05:09 pm
  2. Area reinforcement question
    By Marco1979 in forum Revit Structure
    Last Post: 31st Aug 2015, 03:17 pm
  3. Dynamic block: "Flat reinforcement cage"
    By cordill in forum AutoCAD General
    Last Post: 5th Jul 2013, 01:36 pm
  4. Advanced Dynamic Block for RC column Reinforcement
    By marav in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Apr 2010, 12:03 pm
