ReMark Posted December 27, 2017 Share Posted December 27, 2017 Bug or quirk? I'm not even sure when this first started to happen. And whenever it did I just thought I had done something wrong. But today I did some testing to confirm the above. If I assign the color "red" to a layer the objects will not display in preview nor will they plot. The particulars are as follows: -This happens in both AutoCAD 2017 and 2018. I mostly use 2018 now but I decided to also test using 2017. -Color is assigned Bylayer. -Tested in a brand new drawing. -Tested using three different printers all of which are capable of printing in color. -Object layer is not turned off nor is it frozen. -Printer icon in Layer Property Manager does not have a diagonal red line through it. -Verified that acad.ctb has properties color set to "Use object color". -Tested by assigning other colors to layer and plotting. Objects are seen in plot preview in their assigned color and they print out as well. Lastly, just for the heck of it, I created another layer and set the color value to "10" which when viewed appears to be exactly like the color "red". Copied the objects on my red layer to this new layer and changed their layer property. Plotted the drawing with the same objects side-by-side and only those on the layer assigned the color of "10" appeared in the preview and plotted out just fine. You be the judge. Did I miss something? Bug or quirk? I'm thinking quirk but I don't have a clue as to what changed. That's all folks. Quote Link to comment Share on other sites More sharing options...
maratovich Posted December 27, 2017 Share Posted December 27, 2017 Have you tried on other versions? How will it be in 2014? I can check tomorrow for 2018. Attach a sample file for verification. Quote Link to comment Share on other sites More sharing options...
welldriller Posted December 27, 2017 Share Posted December 27, 2017 Hi ReMark As you know I don't have AutoCAD any more and am using DraftSight (the free version) but I chooser a new layer go to line color and select red every works fine then. I am sure you have checked this but thought I would mention it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2017 Author Share Posted December 27, 2017 Have you tried on other versions? How will it be in 2014?I can check tomorrow for 2018. Attach a sample file for verification. As I noted I did test on two different versions.....2017 & 2018. Here is a copy of the test drawing saved in 2010 file format. Red Alert Test.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2017 Author Share Posted December 27, 2017 This is a screen shot of the test drawing created in and plotted from model space. And this is a screen shot of the Preview window prior to printing the drawing. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2017 Author Share Posted December 27, 2017 Hi ReMarkAs you know I don't have AutoCAD any more and am using DraftSight (the free version) but I chooser a new layer go to line color and select red every works fine then. I am sure you have checked this but thought I would mention it. 99% of the time I assign color to layers and not to individual objects such as lines. I will break from this habit if I am doing something I expect to be temporary and usually do not save the drawing. Quote Link to comment Share on other sites More sharing options...
meracl Posted December 27, 2017 Share Posted December 27, 2017 Hi ReMark, I have tried the file using AutoCad 2018 and prints ok to pdf from both the model and layout tab with standard acad.ctb Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 28, 2017 Share Posted December 28, 2017 (edited) Will have a look tonight on 2018 we use red all the time. Maybe try another ctb, Oh we do have Red set to black, will check that also. 2016 is ok set Red to Red not black appeared in preview. Checked 2018 worked OK made sure "By Colour" Edited December 28, 2017 by BIGAL Quote Link to comment Share on other sites More sharing options...
maratovich Posted December 28, 2017 Share Posted December 28, 2017 2018 - no problem 2016 - no problem 2015 - no problem Try to create a new user in Windows. Start AutoCAD 2018 and check the print. If there is no problem, then you need to reinstall the AutoCAD and clean the registry. Quote Link to comment Share on other sites More sharing options...
eldon Posted December 28, 2017 Share Posted December 28, 2017 I can make out a ghost image in your picture of the Preview. Have you been playing around with the screening for colour number 1? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 28, 2017 Author Share Posted December 28, 2017 Plotting to PDF is of no concern as I rarely if ever have a need to do so. I rarely utilize screening but I'll check the property when I fire up AutoCAD this morning. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 28, 2017 Author Share Posted December 28, 2017 Ladies and Gentlemen....we have a WINNER! I checked the Plot Style Table Editor and the Screening value for Color 1 (red) and found it to be set to "1" instead of "100". I am not even sure when or why I made that change but thanks to eldon's good eyesight the problem is now resolved. eldon: If you PM me with your name and address I will send you enough money (U.S. dollars) to cover the cost of the first pint next time you visit your favorite pub. Thank you! ReMark Quote Link to comment Share on other sites More sharing options...
eldon Posted December 28, 2017 Share Posted December 28, 2017 The satisfaction of occasionally getting it right, surpasses all. Thank you for the offer. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 29, 2017 Share Posted December 29, 2017 The satisfaction of occasionally getting it right, surpasses all. Thank you for the offer. Nicely done eldon! The added satisfaction of getting it right, when it is for ReMark, who so tirelessly helps so many others, makes it all the sweeter. Quote Link to comment Share on other sites More sharing options...
