Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Full Member dilan's Avatar
    Civil
    Civil 3D 2017
    Jan 2018
    From North
    36
    Default Delete files, directory or folder on your computer using Lsp
    Hello everybody!
    On my computer in the Temp folder, I have .txt files.
    I know their names and positions, how can I delete them using lsp?
    I thought that I myself could write a program, but later I understood that I can not manage.
    I started with that first need to get a username:
    Code:
    (setq username (getenv "username"))
    But on this and stopped.... I do not have enough knowledge to finish it ((
    I decided to apply to specialists
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    A batch file is easier and can be ran outside Autocad. Save this to c:\ as deltext.bat just type c:\deltext in the square bottom left as a command in windows. Yes you can run inside Autocad as well.
    Code:
    c:
    cd \temp
    del *.txt
    If their part of a lisp program and your writing say temporary files then use (vl-file-delete filename) but its one file at a time.
    Civil
    Civil 3D 2017
    Jan 2018
    From North
    36
    Quote Originally Posted by BIGAL View Post
    Code:
    c:
    cd \temp
    del *.txt
    Thank you BIGAL
    I will try to use the second option
    Super Member rlx's Avatar
    rlx's Computer Details
    W10
    i74ghz/ssd500/2tbhdd
    Electrical
    rlx's Discipline Details
    electrical designer dragon
    Electrical
    I dont excel in anything but I rearly give up
    AutoCAD 2016
    Nov 2014
    Bergen op Zoom , Netherlands
    1,057
    Welcome on Cadtutor Dilan
    quickly copied and pasted something together , just for fun and barely tested. But for file operations beautiful tools like Total Commander etc. exists.
    Code:
    ; http://www.cadtutor.net/forum/showth...uter-using-Lsp
    ; written by RLX for Dilan 9 jan 2018
    (defun c:Delete_Dilan ( / folder extension file file-list )
      (vl-load-com)
      (if (and (setq extension "*.txt" folder (GetFolder "Select folder with txt files"))
        (vl-consp (setq file-list (vl-directory-files folder extension 1)))
        (vl-consp (setq file-list (Tokkie folder extension file-list file-list)))
        (vl-consp (setq file-list (mapcar '(lambda (x)(strcat folder "\\" x)) file-list))))
        (foreach file file-list (vl-file-delete file))
    ; test (setq fldr (GetFolder "Who , what , Where?"))
    (defun GetFolder ( msg / sh objFolder objParentFolder strPath)
      (setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application" ))
      (setq objFolder (vlax-invoke sh 'BrowseForFolder 0 msg 0 ""))
      (if objFolder
       (and
         (setq strTitle (vlax-get objFolder "Title"))
         (setq objParentFolder (vlax-get objFolder 'ParentFolder))
         (setq strPath (vlax-get (vlax-invoke objParentFolder "Parsename" strTitle) "Path"))
         (vlax-release-object objParentFolder)
         (vlax-release-object objFolder))
       (vlax-release-object sh)
      strPath
    (defun pimp_list ( %lst / i imax slim)
      ; stringlimit (emperical), uppercase is bigger , but so are many M's or W's
      (if (= #RlxBatch-ShowUpperCaseNames "1") (setq slim 82)(setq slim 95))
      (if (or (void RlxBatch-UseTempProjectList) (= RlxBatch-UseTempProjectList "0"))
          (setq i 0 imax (strlen (itoa (length %lst))))
          (mapcar '(lambda (x) (setq i (1+ i)) (strcat (fixitoa i imax) " - " (limitstring x slim))) %lst)
        ; this option retains number of position in (main) project list for item in sub project list
          (setq imax (strlen (itoa (length RlxBatch-ProjectList))))
          (mapcar
     '(lambda (x) (strcat (fixitoa (1+ (vl-position (strcase x t) RlxBatch-ProjectList)) imax) " - " (limitstring x slim)))
      %lst
    ; s = string , n = max string length
    (defun limitstring ( s n / l)
      (setq l (strlen s)) (if (> l n) (strcat (substr s 1 (- (/ n 2) 7 )) " . . . " (substr s (- l (/ n 2)))) (strcat s "")))
    ;check if item is nil of empty string (5 spaces deep)
    (defun void (x) (if (member x (list "" " " "  " "   " "    " "     " nil '())) t nil))
    ; make sure itoa has fixed length , i.e. (fixitoa 1 3) -> "001"
    (defun fixitoa ( #i #n / s ) (setq s (itoa #i))(while (> #n (strlen s))(setq s (strcat "0" s))) s)
    ;--- Tokkie ------------------------------------------------------Tokkie ------------------------------------------------------- Tokkie ---
    ; alternative for listbox multiple selection, a lot of trouble (and not necessarily better) , just different
    ; $txt1 & 2 = header text 1 & 2 , %lst% list of strings, %plist = pre-selected list of strings (if any)
    ; (Tokkie "Block1" "Attributes for visibility2" '("a1" "a2" "a3") '("a2"))
    ; this means toggle for "a1" & "a3" are "0" (off) and "a2" is on ("1")
    ; if previous list is empty all toggles will have default "0" (this differs from my original smartlist routines)
    ; also different is pretty-list , designed to limit string length of members in the list
    (defun Tokkie ( $txt1 $txt2 %lst %plist / err fn fp dcl nof-tog cur-tog pretty-list tokkie-list slider-index return)
      (Tokkie_Init)
      (Tokkie_Dialog)
      (Tokkie_Exit)
      (terpri)
      (reverse return)
    (defun Tokkie_Init ()
      ;(setq err *error* *error* Tokkie_err)
      (cond
        ((not (setq fn (vl-filename-mktemp "Tokkie.dcl"))))
        ((not (setq fp (open  fn "w"))))
        ((null %lst))
        ; tokkie-list keeps toggle value (default "1") for each member in %lst
        (t (setq nof-tog (length %lst) pretty-list (pimp_list %lst)))
      ; tokkie list holds default for toggles - (chr 49) = "1" , (chr 48) = "0"
      (if (and (not (null %lst)) (not (null %plist)))
        ; if item is found in both argument lists , set toggle on ("1") else off ("0")
        (setq tokkie-list (mapcar '(lambda (x)(if (member x %plist)(chr 49)(chr 48))) %lst))
        ; if empty or no preset list was provided all tokkies are off
        (setq tokkie-list (mapcar '(lambda (x) (chr 48)) %lst)))
      (if (null %lst)
        (progn (alert "Nothing to show")(Tokkie_Exit))
          (Tokkie_write_header)
          (if (<= nof-tog 10)(Tokkie_write_body1 pretty-list)(Tokkie_write_body2 pretty-list))
          (Tokkie_write_footer)
      (if fp (close fp))(gc)
      (setq slider-index 0)
    (defun Tokkie_err (s) (princ s)(Tokkie_Exit)(princ))
    (defun Tokkie_Exit ()
      ;|(setq *error* err)|; (if fp (close fp)) (if dcl (unload_dialog dcl))(if (and fn (findfile fn))(vl-file-delete fn)))
    (defun Tokkie_write_header ()
      (write-line
        (strcat
          "Tokkie:dialog{label=\"Tokkie - Rlx(2017)\";spacer;spacer;"
          ":text_part {key=\"txt1\";width=100;fixed_width=true;}"
          ":text_part{key=\"txt2\";width=100;fixed_width=true;}spacer;") fp))
    (defun Tokkie_write_body1 ( %l / i )
      (write-line ":boxed_column{" fp)
      (setq i 0)
          (write-line
            (strcat
       ":row{spacer;:toggle{key=\"tg" (itoa i) "\";width=2;fixed_width=true;}"
       ":text_part{key=\"tp" (itoa i) "\";label=\"" x "\";width=100;fixed_width=true;}}") fp)
          (setq i (1+ i)))
       %l
      (repeat (- 10 i)(write-line ":row{height=1.5;}" fp))
      (write-line "}spacer;" fp)
    (defun Tokkie_write_body2 ( %l / i )
      (write-line ":boxed_row {:column{" fp)
      (setq i 0)
      (repeat 10
        (write-line
          (strcat
     ":row { spacer; :toggle { key =\"tg" (itoa i) "\";width=2;fixed_width=true;}"
     ":text_part{key=\"tp" (itoa i) "\";label=\"" (nth i %l) "\";width=100;fixed_width=true;}}") fp)
        (setq i (1+ i))
      (write-line
        (strcat "}:column{:slider{key=\"sldr\";layout=vertical;min_value="(itoa (- 0 nof-tog)) ";max_value=0"
         ";small_increment=1;big_increment=10;value=0;}}}spacer;") fp)
    (defun Tokkie_write_footer ()
      (write-line
        (strcat
          "spacer;"
          ": row {: button{label=\"Select All\";key=\"all\";}:button{label=\"Select None\";key=\"none\";}}"
          "spacer;ok_cancel;}") fp))
    (defun Tokkie_Dialog ( / n drv inp)
      (if (and (setq n 0 dcl (load_dialog fn)) (new_dialog "Tokkie" dcl))
          (Tokkie_DialogUpdate)
          (Tokkie_DialogActions)
          (setq drv (start_dialog))
          (if (= drv 1)
     (mapcar '(lambda (x y) (if (= x "1")(setq return (cons y return)))) tokkie-list %lst)
     (setq return nil))
    (defun Tokkie_DialogUpdate ( / i )
      (if (= (type $txt1) 'STR)(set_tile "txt1" $txt1))
      (if (= (type $txt2) 'STR)(set_tile "txt2" $txt2))
      (set_tile "sldr" (itoa slider-index))
      (update_tokkies)
    (defun Tokkie_DialogActions ()
      (repeat 10 (action_tile (strcat "tg" (itoa n)) (strcat "(toggle_me $value " (itoa n) ")" ))(setq n (1+ n)))
      (action_tile "sldr" "(update_slider $value)")
      (action_tile "all" "(Tokkie_SelectAll)")
      (action_tile "none" "(Tokkie_SelectNone)")
      (action_tile "ok" "(done_dialog 1)")
      (action_tile "cancel" "(done_dialog 0)")
    (defun update_slider ( #i ) (setq slider-index (atoi #i)) (Tokkie_DialogUpdate))
    (defun update_tokkies (/ tokkie-index tokkie-name i)
      ;max number of toggles in dialog is 10
      (if (> (abs slider-index) (- nof-tog 10))
        (setq tokkie-index (- nof-tog 10))(setq tokkie-index (abs slider-index)))
      (if (< tokkie-index 0)(setq tokkie-index 0))
      (setq i 0)
      (while (and (< i 10) (setq tokkie-name (nth tokkie-index pretty-list)))
        (set_tile (strcat "tp" (itoa i)) tokkie-name)
        (set_tile (strcat "tg" (itoa i)) (nth tokkie-index tokkie-list))
        (setq i (1+ i) tokkie-index (1+ tokkie-index))
    (defun toggle_me ( $v #i / idx )
      (if (> (abs slider-index) (- nof-tog 10))(setq idx (- nof-tog 10))(setq idx (abs slider-index)))
      (setq tokkie-list (nthSubst (+ #i (if (< idx 0) 0 idx)) $v tokkie-list))
    (defun Tokkie_SelectAll ();reset all toggles to "1"
      ;(setq tokkie-list (mapcar '(lambda (x) (chr 49)) %lst))(Tokkie_DialogUpdate))
      (setq tokkie-list (mapcar '(lambda (x) (chr 49)) pretty-list))(Tokkie_DialogUpdate))
    (defun Tokkie_SelectNone ();reset all toggles to "0"
      ;(setq tokkie-list (mapcar '(lambda (x) (chr 48)) %lst))(Tokkie_DialogUpdate))
      (setq tokkie-list (mapcar '(lambda (x) (chr 48)) pretty-list))(Tokkie_DialogUpdate))
    (defun nthSubst (i x l / n) (setq n -1)(mapcar '(lambda (y) (if (eq i (setq n (1+ n))) x y )) l ))
    (c:Delete_Dilan)
    gr. Rlx
    ps.pps. edited code to include subfuction limitstring, fixitoa & void , part of my lib with little subfunctions so I forgot it the first time , just noticed it after I posted
  5. #5
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    892
    Try this:
    Code:
    (defun c:foo (/ tmp)
      ;; Deletes "*.txt" files in temp dir!
      (foreach x (vl-directory-files (setq tmp (getenv "temp")) "*.txt")
        (vl-file-delete (strcat tmp "\\" x))
        (print (strcat "DELETING >> " tmp "\\" x))
    )(vl-load-com)
  6. #6
    Civil
    Civil 3D 2017
    Jan 2018
    From North
    36
    Quote Originally Posted by ronjonp View Post
    Try this:
    Code:
    )(vl-load-com)
    Thank you.This is what you need. How can I do not to delete all the files .txt in the "Temp" folder? For example I need to delete the file 123.txt and 321.txt...
  7. #7
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Rlx, theres a tiny issue in the GetFolder subfunction you used - shell application object won't be released if the user specifies the folder.
    On the other hand I think (think?,more like studied from the pros) that those "external acad objects" must be released at all cost (which would mean error-trapping/wrapping).
    So heres a more reliable approach that you can use:
    Code:
    ; msg - [STR] - optional prompt message
    ; defpath - [STR] - optional default path
    ; newfolderopt [T/nil] - T = display option to create new folder, else don't
    ; Examples: (GetFolder nil nil nil) ; (GetFolder "Hello world" "D:\\GAMES" T)
    (defun GetFolder ( msg defpath newfolderopt / shell folder parentfolder path )
      (vl-catch-all-apply
        (function
          (lambda nil
            (setq shell (vlax-get-or-create-object "Shell.Application"))
            (setq folder (vlax-invoke-method shell 'BrowseForFolder 0 (cond (msg)("")) (if newfolderopt 0 512) (cond (defpath) ((strcat (getenv "userprofile") "\\Desktop\\")))))
            (setq parentfolder (vlax-get-property folder 'ParentFolder))
            (setq path (vlax-get-property (vlax-invoke-method parentfolder 'Parsename (vlax-get-property folder 'Title)) 'Path))
      (foreach x (reverse (list shell folder parentfolder path)) (vl-catch-all-apply 'vlax-release-object (list x))) path
    ); defun GetFolder
  8. #8
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,593
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  9. #9
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,474
    Quote Originally Posted by Lee Mac View Post
    Well thats the perfect approach, I just wanted to use my gray matter a bit.
  10. #10
    W10
    Electrical
    Electrical
    AutoCAD 2016
    Nov 2014
    1,057
    Quote Originally Posted by Grrr View Post
    Code:
      (vl-catch-all-apply
        (function
          (lambda nil
    ); defun GetFolder
    Just quickly cut some code from some of my appies so it may not have been the best ones. On the other hand , it took me about two minutes... but you're right have to clean up or out some of my old stuf. Thanx for the update and the advice , allways appreciated and never too old to learn
    gr. Rlx
  1. Replies: 5
    Last Post: 25th Jun 2014, 05:20 pm
  2. LISP Folder Directory and Hyperlink
    By Ohnoto in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2013, 01:50 pm
  3. Using vl-directory-files to populate list box
    By lfe011969 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2010, 07:30 pm
  4. How to copy a list of files from one directory to another?
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2010, 03:37 pm
  5. Opening Files from same directory?
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2006, 12:51 pm
