Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    Default Dynamic Block help
    Thanks for reading and helping.
    I am trying to create a dynamic block with certain parameters, but having trouble.
    I would like my Dynamic block to have an object (3/16 diam circle) to insert 6" to the right of entry point.
    Then has to stretch to the right with a second circle inserting 6" from the opposite end point after stretch reaches a minimum of 18".
    However, if the stretch distance from insertion point to end point is less than 18", then the circle must be centered.
    So,
    1) Circle must be centered along stretch if < 18"
    2) Two circles 6" from each end if > 18"
    I know there are much smarter people out there that can figure this out. It's just slipping my understand how to execute this in the block.
    I hope this description makes sense.
    Thanks
    Full Member Incognito Cube's Avatar
    Incognito Cube's Computer Details
    Windows 10 Pro
    Dell Precision T1700
    Intel(R) Xeon(R) CPU E3-1225 v3 @ 3.20GHz
    8Gb DDR3
    #1: Intel(R) HD Graphics P4600/P4700 #2: NVIDIA Quadro K620
    WDC WD5000AAKX-75U6A SCSI
    x2 Dell E2011H
    Surveying
    Incognito Cube's Discipline Details
    Platting Technician
    Surveying
    ALTA Surveys, Mortgage Surveys (Plot Plans, Finals, etc.), Plats, Boundary/TOPOs.
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    I believe I'm correctly understanding the basic layout of the block you're attempting to create. This looking correct so far?
    Windows 10 Pro
    8Gb DDR3
    x2 Dell E2011H
    Surveying
    Platting Technician
    Surveying
    Civil 3D 2014
    Jan 2018
    Orlando, Florida
    38
    Crap. Do I have to wait for an image link to be approved?
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    I don't know. Maybe so. I'm not seeing an image though.
  5. #5
    Senior Member
    iconeo's Computer Details
    Windows
    Multi-disciplinary
    iconeo's Discipline Details
    CAD Manager/Draftsman
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    303
    You need to use a double lookup table with intervals set to different visibility states as you stretch it in order to toggle from centered to end aligned.
    Sent from my Pixel 2 XL using Tapatalk
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    Quote Originally Posted by Incognito Cube View Post
    All links need approval until you reach 10 posts, but you can attach images directly in CADTutor, no link needed and no waiting for approval, you can attach lots of things directly to CADTutor, just click Go Advanced then Manage Attachments.
    Your image is not awaiting approval though, I can't see it because third party image hosting sites are blocked at my work.
  7. #7
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    303
    Sorta like so.
    test.dwg
  8. #8
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    I think I almost have it figured out thanks to your help. I had something already before you posted this example, but it needs tweaking to get it to auto switch visibility states when I pass the 18" mark. I like your example, but I need the base point to be left most and the stretch to the right from there. I like trying to figure these out and build them myself, just need that push with what I am not seeing to do it.
  9. #9
    Senior Member
    Windows
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2017
    Jun 2007
    Seattle
    303
    Quote Originally Posted by robwell View Post
    Best way to learn IMO
  10. #10
    Full Member
    Structural
    AutoCAD 2018
    Sep 2017
    35
    So I am still having trouble figuring out the transfer from one visibility state to another when dragging the stretch past the 18" distance. I would like to use a seamless transition as in your example, but what am I missing.
    I am attaching my block for reference and pointers.
    WEEPHOLE.dwg
  1. multiple dynamic constraints in a dynamic block
    By Huibert in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2013, 06:52 pm
  2. Insert dynamic block from file with multiple dynamic blocks
    By BUrBaKy in forum AutoCAD Drawing Management & Output
    Last Post: 14th Nov 2012, 11:38 pm
  3. Looking to *Insert Dynamic Block and rotate Dynamic Grip*
    By sbrennan85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th May 2012, 04:14 pm
  4. Dynamic Block with Dynamic Attributes
    By McTodd in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2011, 03:37 am
  5. Replies: 5
    Last Post: 26th Jun 2009, 04:50 pm
