abra-CAD-abra Posted January 11, 2018 Posted January 11, 2018 All, In AutoCAD 2016, and when using vlax-for and vla-get-layouts in the code below, I need to switch to a different layout before the new layout names are applied to the layouts. (defun C:DEMO (/ tab str) (vl-load-com) (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) (setq tab (vla-get-name lyt)) (setq str (substr tab 1 4)) (vla-put-name lyt (strcat "2" str)) ) (princ) ) Any ideas? Thanks Quote
BIGAL Posted January 12, 2018 Posted January 12, 2018 error: Automation Error. Cannot rename the Model layout need a IF to check tab is not Model (defun C:DEMO (/ tab str) (vl-load-com) (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) (setq tab (vla-get-name lyt)) (setq str (substr tab 1 4)) (If (/= "Model" tab) (vla-put-name lyt (strcat "2" str)) ) ) (princ) ) (c:demo) Quote
abra-CAD-abra Posted January 12, 2018 Author Posted January 12, 2018 error: Automation Error. Cannot rename the Model layout need a IF to check tab is not Model (defun C:DEMO (/ tab str) (vl-load-com) (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) (setq tab (vla-get-name lyt)) (setq str (substr tab 1 4)) (If (/= "Model" tab) (vla-put-name lyt (strcat "2" str)) ) ) (princ) ) (c:demo) Thanks BIGAL, Fixed it. SUBSTR starts at 1, not 0 as with other functions like NTH. (defun C:DEMOX (/ tab str) (vl-load-com) (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) (setq tab (vla-get-name lyt)) (setq str (substr tab 2 5)) (if (not (eq "MODEL" (strcase (vla-get-name lyt)))) (vla-put-name lyt (strcat "2" str)) ) ) (princ) ) Appreciate your help Quote
