quickly change blocks to annotative
I have 100's of blocks that I need to change to annotative. is there a way to do it quickly or a lisp routine, rather than editing every single block and changing the setting to annotative from the properties palette?
thanks, not the quickest but managed since I had many blocks I used data extraction to get the name of all the blocks, export to CSV, then import to Word, to further clean the formatting with find and replace (to get rid of the extra tabs and commas). I noticed word changes straight inverted commas to curly inverted commas so I did the same process again in notepad++. then i added the (foreach blk '("myblock1" "myblock2" "myblock3") (annotativeblock blk)) and pasted into AutoCAD and voila!! thanks again :) might there be a quicker method?? :D :D
certainly faster than doing them one by one manually
  • 2 weeks later...
apparently in the company this is going to be a common occurrence. any faster way?
Try this .. it will make all blocks in a drawing annotative.
;; Lee's code
;; https://goo.gl/KT3Ja1
(defun annotativeblock (blk)
 (and (setq blk (tblobjname "block" blk))
      (progn (regapp "AcadAnnotative")
      (entmod (append (entget (cdr (assoc 330 (entget blk))))
		      '((-3
			 ("AcadAnnotative"
			  (1000 . "AnnotativeData")
			  (1002 . "{")
			  (1070 . 1)
			  (1070 . 1)
			  (1002 . "}")
(defun _allannotative (/ d)
 (while (setq d (tblnext "block" (null d)))
   (and (not (assoc 1 d)) (annotativeblock (cdr (assoc 2 d))))
(_allannotative)
Edited by ronjonp
wow perfect!!!!!!
:notworthy:
