Select a definited block, capture determinated attributes and save them in clipboard
hello! I'm a new member of this fantastic forum that I met through google searches...I'am Italian and this is the first time I write to a foreign forum...sorry for my english!
I write to ask how to solve a problem using LISP (but I'm not a programmer)
There is an operation that I perform continuously: select attributes values and copy them out of autocad! and for this operation I always use the same block "CA5"...in my files there are a lot of "CA5", but I always use one only at a time...so:
1) I want to select a single block "CA5" by mouse click
2) I want to "read" the value of 2 definited attributes (es. DESCRIPT1 and DESCRIPT2)
3) I want to combine the 2 values in a single value (es. DESCRIPT1value+space+DESCRIPT2value)
4) I want to save this new value in the windows clipboard
someone can help me write this lisp?
Thank you in advance
Hi,
How about this:
(defun C:test ( / a e enx s )
 (and
   (or _SetClipBoardText (prompt "\nNo function definition \"_SetClipBoardText\"."))
   (setq a (car (entsel "\nSelect attributed block: ")))
   (setq a (entget a))
   (or (vl-every '(lambda (x) (member x a)) '((0 . "INSERT")(66 . 1))) (prompt "\nInvalid object."))
   (setq e (cdr (assoc -1 a)))
   (setq s "")
     (while (member '(0 . "ATTRIB") (setq enx (entget (setq e (entnext e)))))
       (setq s (strcat s " " (cdr (assoc 1 enx))))
     (_SetClipBoardText (substr s 2))
 ); and
); defun
(vl-load-com)(princ)
;;  MP
;;  http://www.theswamp.org/index.php?topic=21764.msg263322#msg263322
(defun _SetClipBoardText ( text / htmlfile result )
 ;;  Caller's sole responsibility is to pass a
 ;;  text string. Anything else? Pie in face.
 (setq result
   (vlax-invoke
     (vlax-get
       (vlax-get (setq htmlfile (vlax-create-object "htmlfile")) 'ParentWindow)
       'ClipBoardData
   'SetData  "Text"  text)
 (vlax-release-object htmlfile)
 text
First of all thanks for the help! Well, I tried your LISP and it could be useful but I need to be faster using a dedicated solution...but I do not have the knowledge to correct myself, to my needs your lisp ...
In only one click on the block "ca5" i want to obtain the string
denom+denom2+sigute
could you explain to me how write the code that combines only the attributes I need in a previously chosen block?
For see an example of what I want to do...
https://drive.google.com/open?id=1ZX6Fz9lgbdmcom9LEajEFK4gq73vtpKj
P.S. why you post your LISP with the name "TEXT"? I had to rename it
Try this:
(defun C:test ( / a e enx L )
 (and
   (setq a (entget a))
       (setq L (cons (mapcar '(lambda (x) (cdr (assoc x enx))) '(2 1)) L))
     (_SetClipBoardText
       (apply '(lambda (a b c) (strcat a " " b " " c))
         (mapcar '(lambda (x) (cond ( (cadr (assoc x L)) ) (""))) '("DENOM" "DENOM2" "SIGUTE"))
 ); and
); defun
Do you mean test ? - its generally accepted default name for a routine, so you have to rename it by yourself later.
nice!
(while (member '(0 . "ATTRIB") (setq enx (entget (setq e (entnext e)))))         (setq L (cons (mapcar '(lambda (x) (cdr (assoc x enx))) '(2 1)) L))       )       (_SetClipBoardText         (apply '(lambda (a b c) (strcat a " " b " " c))           (mapcar '(lambda (x) (cond ( (cadr (assoc x L)) ) (""))) '("DENOM" "DENOM2" "SIGUTE"))         )       )
THANK YOU!
Now I think Grrr it is the diminutive for Grrreat!
Now I can make a series of copies of the lisp so each copy will have a particular combination!
I think I will have to modify this part
...a b c are variables where the lisp saves the text right? If I want to save four attributes I have to add one more variable and combine the necessary attributes...
I will write to you in the next days...Thanks again!
Thanks for the complimens, itacad!
I just liked that you listed the steps in your first post, for what you wanted the routine to do, so I decided to help.
Indeed the a b c are the variables where the attribute values are stored from the tags '("DENOM" "DENOM2" "SIGUTE").
So for further modifications I think you know what to change.
It can be done also directly just adding the attributes as you pick them using nentsel, this would be ok if you only had to do a few.
As many attributes as you like.
(defun c:add-att ( /  ans obj )
(while (/= (setq ent (nentsel)) nil)
(setq obj (vlax-ename->vla-object (car ent)))
(if (= ans nil)
(setq ans (vla-get-textstring obj))
(setq ans (strcat ans "-" (vla-get-textstring obj)))
(c:add-att)
