Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2015
    Mar 2016
    1
    Default Old Plotter driver problems, a challenge
    I have an old HP 750C+ plotter I have been able to successfully load a driver on my Windows 7 64 bit computer and have plotted form it. I recently had some changes made to my computer and now cannot seem to install the plotter again. I can create PDF's and plot them with the plotter so I know windows is recognizing the plotter but auto cad will not. When i use the add-a- plotter wizard in auto cad ultimately it will ask me for a saved pcp or pc2 file or select plot to a port which is set up. My question is where can I find these files (PCP, or PC2) or is there another way to set up the plotter so I can plot through Auto Cad. I also know that I have to disable the windows driver signature upon system start up which I have done.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,501
    If pdf's are plotting then there must be a system printer driver, this should just appear in your available printers list top left when type PLOT. Maybe even "windows system printer" make sure 750C is default. No need to run "Add".
  1. Plotter driver language in Chinese, not English
    By ttownsend in forum AutoCAD Beginners' Area
    Last Post: 5th Dec 2017, 02:41 pm
  2. roland dx 1100 plotter driver that will run under windows 7
    By Jennywren in forum AutoCAD Beginners' Area
    Last Post: 27th Aug 2012, 03:39 am
  3. Problem installing Plotter driver
    By charlie72 in forum AutoCAD Drawing Management & Output
    Last Post: 29th Aug 2009, 01:27 pm
  4. HPGL generic driver to Canon plotter
    By Chudder in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jun 2008, 12:13 pm
  5. Old 250c Plotter Need Driver
    By CADJAX in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jul 2007, 06:51 pm
Tags for this Thread
