ziele_o2k Posted January 30, 2018 Share Posted January 30, 2018 I'm inserting new table using this routine: (defun cd:ACX_AddTable (Space Pb Rows Cols RowH ColH) (vla-AddTable Space (vlax-3d-point (trans Pb 1 0)) Rows Cols RowH ColH ) ) Example : (cd:ACX_AddTable (cd:ACX_ASpace) (getpoint) 5 5 10 30) but I'm don't know how to rotate inserted table to current UCS. I'm guessing that this have something in common with direction property but I'm stuck here... Any help ? Subroutines: (defun cd:ACX_ASpace () (if (= (getvar "CVPORT") 1) (vla-item (cd:ACX_Blocks) "*Paper_Space") (cd:ACX_Model) ) ) (defun cd:ACX_Blocks () (or *cd-Blocks* (setq *cd-Blocks* (vla-get-blocks (cd:ACX_ADoc))) ) *cd-Blocks* ) (defun cd:ACX_Model () (or *cd-ModelSpace* (setq *cd-ModelSpace* (vla-get-ModelSpace (cd:ACX_ADoc))) ) *cd-ModelSpace* ) (defun cd:ACX_ADoc () (or *cd-ActiveDocument* (setq *cd-ActiveDocument* (vla-get-ActiveDocument (vlax-get-acad-object)) ) ) *cd-ActiveDocument* ) Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted January 30, 2018 Share Posted January 30, 2018 Try this (setq table (vla-AddTable Space (vlax-3d-point (trans Pb 1 0)) Rows Cols RowH ColH ) ) (vlax-put table 'direction (trans '(1 0 0) 1 0 T)) Quote Link to comment Share on other sites More sharing options...
ziele_o2k Posted January 30, 2018 Author Share Posted January 30, 2018 how to regen this?? Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted January 30, 2018 Share Posted January 30, 2018 (edited) I never had this problem. It seems it appears like this if you just insert the table. vla-update doesn't help, but it comes to normal as soon as you start populating the cells or adjust the rows, columns. Even a vla-move will regenerate it. (setq table (vla-AddTable Space (vlax-3d-point 0.0 0.0 0.0) Rows Cols RowH ColH ) ) (vlax-put table 'direction (trans '(1 0 0) 1 0 T)) (vla-move table (vlax-3d-point 0.0 0.0 0.0) (vlax-3d-point (trans Pb 1 0))) Edited January 30, 2018 by Stefan BMR Quote Link to comment Share on other sites More sharing options...
