cat3appr Posted February 17, 2018 Posted February 17, 2018 Hello I have a polyline and I'd like to extract the easting northing coordinates at 1 meter interval, is it possible to do that? ps no LIST command I need to extract a point every meter many thanks! Quote
BIGAL Posted February 18, 2018 Posted February 18, 2018 Its a very simple task there is a vl function vlax-curve-getpointatdist which does just that. This can be expanded out to use with other objects like circle, arc & line, all in one routine. (defun ptsatdist ( / obj dist distx pt) (setq obj (vlax-ename->vla-object (car (entsel "\nPick object")))) (setq dist 1.0) (setq distx dist) (if (/= (setq len (vla-get-length obj)) nil) (progn (repeat (fix (/ len dist)) (princ "\n") (setq pt (vlax-curve-getpointatdist obj distx)) (setq distx (+ distx dist)) (princ (strcat (rtos distx 2 0) " X= " (rtos (car pt) 2 2) " Y= " (rtos (cadr pt) 2 2))) ) ) ) ) (ptsatdist) Quote
