Results 1 to 7 of 7
Thread: Save a DXF file
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    Default Save a DXF file
    In AutoCAD 2011 how do I save a file as a DXF?
    Kind regards,
    Neville
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    You can use the SAVEAS command or the DXFOUT command. Both commands will open the "Save Drawing As" window. At the bottom of the window, open the "Files of Type" list box and choose the .dxf format you want to save to.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    Thanks Cad64
    However the drawing is reasonably large and I want to save individual details in DXF.
    Do I have to duplicate (ie Saveas) the whole drawing then delete everything that I don't require for each detail?
    That seems like a lot of work.
    Regards,
    Neville
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    No, you don't have to save out a bunch of drawings and delete everything from each drawing.
    When you run the DXFOUT command for the first time, and the "Save Drawing As" window opens, go to the upper right corner of the window and click the "Tools" button, then choose "Options". When the "Options" window opens, click the "DXF Options" tab and put a check in the box that says "Select Objects". Then click Ok to exit the "Options" window. Then choose where you want to save the dxf file, type in a file name and click the Save button. When the "Save Drawing As" window closes you will be able to select the objects you want to save out to the dxf file.
    Facebook:
  5. #5
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    Thanks mate, I will give it a go tomorrow.
    Regards,
    Neville
  6. #6
    AutoCAD 2013
    Nov 2011
    6,049
    Quote Originally Posted by Neville Jukes View Post
    Regards,
    Neville
    I am guessing that you won't want to make it your default SAVE filetype, but should you want to, you can do that in OPTIONS, on the OPEN & SAVE tab.
    If you choose one of the numerous .dfx file types in that dropdown list, whenever you use the SAVE command, whatever you are working on will be Saved As a .dfx.
  7. #7
    Junior Member
    Manufacture
    AutoCAD 2011
    Jun 2017
    Australia
    17
    Thanks guys particularly CAD64.
    I sorted it with your method.
    Kind regards,
    Neville
  1. how to save .shp file in pc.
    By afrazawan in forum CAD Management
    Last Post: 22nd Sep 2014, 02:01 pm
  2. How do you save a file?
    By howitzer in forum CAD Management
    Last Post: 13th May 2013, 03:42 pm
  3. Replies: 0
    Last Post: 15th Nov 2010, 08:30 am
  4. Save as a .pdf file?
    By Tridraft in forum Autodesk Inventor
    Last Post: 10th Sep 2009, 05:40 am
  5. Can't save file.
    By Sayville in forum AutoCAD Drawing Management & Output
    Last Post: 1st Mar 2007, 09:10 am
