hello i need a macro to add to a button for:
make a line on layer "AM_4" with Amzigzag line and then when i finish to return on layer 0 and the color is by block is it possible?
thanks
^C^C_clayer AM_4;
^C^C_color BYLAYER;
^C^C_linetype;
Amzigzag;;^C^C_pline;;
Edited by jim78b
I modified
^C^C_clayer AM_4;^C^C_color BYLAYER;
^C^C-linetype;S AMZIGZAG;;
^C^C_PLINE;\\;layerp;
^C^C_clayer 0;^C^C_color BYBLOCK;^C^C-linetype;S BYLAYER;;
but is incorrect because permit to draw a single line and can not repeat the command
Have you considered using lisp which could add both the layer and linetype if needed as well as being repeatable?
If lisp not available it could be done in a Tool Palette.
sorry but I'm not able. a macro will be better. can you test my macro please?
The macro can call a lisp ?
(setvar 'clayer "AM_4")
(command "_color" "BYLAYER" "-linetype" "s" "AMZIGZAG")
(command "_pline")
(while (= (getvar "cmdactive") 1 ) (command pause)
(setvar 'clayer "0")
Edited by BIGAL
(command "_pline")
at the end i want return on layer "0" with color :byblock and linetype:bylayer
hello my friend no is it possible only a macro? because i need it to associate to a button.
thanks best regards
thanks best regards
Unless you're running a LT version there's no reason you cannot use lisp in a macro. You may need to add a space or semicolon; at the end of the lisp for enter.
Ok sorry have you right .I can use lisp.please can you put at the end of the code color by block and line bylayer i need this :)
Thanks a lot
Try:
*^C^C(progn(setvar 'clayer "AM_4")(setvar 'cecolor "ByBlock")(setvar 'celtype "AMZIGZAG")(command "-linetype" "s" "AMZIGZAG" "_pline")(while (= (getvar "cmdactive") 1 ) (command pause))(setvar 'clayer "0")(setvar 'cecolor "ByLayer")(setvar 'celtype "ByLayer")(princ))
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Repeating-commands-automatically.html
Repeating commands automatically
Adding an asterisk (*) before the command definition (*^C^C_Circle) will cause the command to repeat until you select another command or press the ESC key.
Try:
give me invalid function
Can you copy and paste exactly what it says?
Are you sure you're not running a LT version of Mechanical 2013?
I delete button but I remember it wrote invalid ...function and last word was pline.but can i past the code in the command bar?
No i am using mechanical
Command: *^C^C(progn(setvar Unknown command "*^C^C(PROGN(SETVAR". Press F1 for help.
Command: 'clayer
Enter new value for CLAYER : "AM_4")(setvar 'cecolor "ByBlock")(setvar 'celtype "AMZIGZAG")(command "-linetype" "s" "AMZIGZAG" "_pline")(while (= (getvar "cmdactive") 1 ) (command pause))(setvar 'clayer "0")(setvar 'cecolor "ByLayer")(setvar 'celtype "ByLayer")(princ))
Cannot set CLAYER to that value.
*Invalid*
Oops missed a bracket after amzigzag anyway the 1 liner
^c^c^p(setvar 'clayer "AM_4")(command "_color" "BYLAYER" "-linetype" "s" "AMZIGZAG")(command "_pline")(while (= (getvar "cmdactive") 1 ) (command pause))(setvar 'clayer "0")(command "_color" "BYBLOCK" "-linetype" "s" "BYLAYER")
Ok thanks Now should work
