I am trying to create a routine that allows me to select a dimension that then sets this as the current dimension style and also the current layer from the dimension selected. Code Below
(defun C:SetDimLayer ()
  (princ "\Select Desired Dimstyle...")
  (setq sg (ssget))
  (command "-DIMSTYLE" "_R" sg) ;remove this line and line below works
  (command "laymcur" sg) ;remove this line and line above works
I can get this to work with either of the command statements on their own but not with both command lines. Is there something that I am missing.
Try this quick code:
(defun c:foo (/ e)
 (cond
   ((and (setq e (car (entsel "\nPick a dimension: "))) (= "DIMENSION" (cdr (assoc 0 (entget e)))))
    (setvar 'clayer (cdr (assoc 8 (entget e))))
    (command "-dimstyle" "r" (cdr (assoc 3 (entget e))))
Many Thanks Ron. Jut got to work and tried it out and it works great. Can you tell me what the assoc values are or point me in the direction to find documentation. Im relatively new to new lisp. I have gained most my knowledge from a collegue at work and reverse engineering to see what things do. This assoc is new to me though Ta
Autocad use dxf codes also known as association values, there is lots of full DXF code lists out there search here 1st. Its basicly the core data base identifying an object by a Unique key.
a few common ones but note they can be a bit mixed and match depending on the type of object
10 insert pt, start pt line etc
11 end pt line etc
8 layer see above
0 object type see above
2 name
The other thing to use is dumpit.lsp it will reveal a lot of the values and you can use VL-get & put functions re an object properties.
;;; DumpIt                                                            ;
;;; Dump all methods and properties for selected objects              ;
(defun C:DumpIt ( / ent)
 (while (setq ent (entsel))
   (vlax-Dump-Object
     (vlax-Ename->Vla-Object (car ent))
Command: DUMPIT
Select object:
; IAcadDimRotated: AutoCAD Rotated Dimension Interface
; Property values:
;   Measurement (RO) = 301.245
;   ObjectName (RO) = "AcDbRotatedDimension"
;   StyleName = "DESIGN"
HERE is the documentation from the help file too.
Also, here is a quick function you can use to inspect items in your drawings.
(defun c:dxf (/ e)
 (cond	((setq e (car (entsel "\nPick something to see DXF data: ")))
 (mapcar 'print (entget e '("*")))
