SSGET - Polyline Select by Range in Length
GregGleason
Here is the code that works so far:
(setq ss (ssget "_C" '(7.244 2.071) '(16.665 10.003) '((0 . "*POLYLINE") (8 . "PIPE-IsoPrim"))))
What I want to do is limit the selection to a range of the polyline length, let's say 0.053 to 0.059 inclusive.
Is that code possible?
Greg
Hi,
Try this:
(defun c:Test ( / in ss en len)
 (if (setq in -1 ss (ssget "_C" '(7.244 2.071) '(16.665 10.003) '((0 . "*POLYLINE") (8 . "PIPE-IsoPrim"))))
   (while (setq en (ssname ss (setq in (1+ in))))
     (setq len (vlax-curve-getdistatparam en (vlax-curve-getendparam en)))
     (or (or (and (< len 0.059) (> len 0.053) )
             (equal len 0.053 1e-4)
             (equal len 0.059 1e-4)
         (ssdel en ss)
 (sssetfirst nil ss)
I did a minor code change on what you did Tharwat:
(defun c:Test ( / in ss en len mymin mymax)
 (setq mymin 0.053)
 (setq mymax 0.059)
     (or (or (and (< len mymin) (< len mymax))
             (equal len mymin 1e-4)
             (equal len mymax 1e-4)
         (ssdel en ss)
 (sssetfirst nil ss)
The result was that it captured every other object. Strange on why it skipped like that. All of the lines but one are 0.0547 and the remaining one is 0.0581.
Greg
(> len mymin)
Perfect!
What would I need to do to add code to change the selection to another layer?
Greg
Perfect!
Greg
You would need something like the following.
NOTE: Localize the variable 'get' in the routine.
(if (or (and (< len 0.059) (> len 0.053))
 (entmod (subst '(8 . "[color="magenta"]LayerName[/color]")
                (assoc 8 (setq [color="red"]get [/color](entget en)))
                [color="red"]get[/color]
 (ssdel en ss)
Again, perfect!
Now, is there a command to unselect the objects after it has finished?
Greg
Press ESC ;) Or remove:
(sssetfirst nil ss)
Hi,
Try this:
         (ssdel en ss)
 (sssetfirst nil ss)
This method will skip the entity following the entity removed from the set due to the reassignment of selection set indices.
Thank you Lee for paying my attention to this essential processing matter.
@Greg,
Please consider the following routine and I did remove the highlighting codes as you have requested earlier and ronjonp gratefully answered your question.
(defun c:Test ( / in ss en get len)
     (and (or (and (< len 0.059) (> len 0.053))
          (entmod (subst '(8 . "LayerName") (assoc 8 (setq get (entget en))) get))
  • 3 years later...
@Greg,
sir, how about multiple specific length ?
thanks in advance.
