Grrr Posted March 18, 2018 Share Posted March 18, 2018 CADTutor was down for maintenance, which reminded me what I wanted to do: Not the prettiest coding, but upon testing there are no failures: (defun C:test nil (TicTacToe) ) ; Tic Tac Toe ; Written By Grrr ; Credits: Lee Mac (defun TicTacToe ( / SubstNth GroupByN kL vL *error* dcl des dch dcf tmp ) (defun SubstNth ( n v L / i ) (setq i -1) (mapcar (function (lambda (x) (if (eq n (setq i (1+ i))) v x))) L)) (defun GroupByN ( n L / r ) ; Grrr (repeat n (and L (setq r (cons (car L) r))) (setq L (cdr L)) r) (if L (cons (reverse r) (GroupByN n L)) (list (reverse r))) ); defun GroupByN (setq kL '( ("A1" "B1" "C1") ("A2" "B2" "C2") ("A3" "B3" "C3") ); list ); setq kL (setq vL '( (nil nil nil) (nil nil nil) (nil nil nil) ) ) (defun *error* ( msg ) (and (< 0 dch) (unload_dialog dch)) (and (eq 'FILE (type des)) (close des)) (and (eq 'STR (type dcl)) (findfile dcl) (vl-file-delete dcl)) (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " msg)) )) (princ) ); defun *error* (cond ( (progn (while (not (member dcf '(0 1))) (*error* nil) (cond ( (not ; Rewrite and Reload the dialog continiously (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq des (open dcl "w")) (vl-every (function (lambda (x) (princ (strcat "\n" x) des))) (list "test : dialog " "{ label = \"Tic Tac Toe\"; spacer;" " : column " " {" (apply (function strcat) (mapcar (function (lambda (kL vL) (strcat "\n" " : row " " { fixed_width = true; alignment = centered; " (apply (function strcat) (mapcar (function (lambda (k v) (strcat "\n" " : button { key = \"" k "\"; label = \"" (cond (v)("")) "\"; width = 3; fixed_width = true; height = 1.5; }") ); lambda (xx) ); function kL vL ); mapcar ); apply 'strcat " }" ); strcat ); lambda (r) ); function kL vL ); mapcar ); apply 'strcat " }" " spacer_1; ok_only; : text { key = \"error\"; }" "}" ); list ); vl-every (not (setq des (close des))) (< 0 (setq dch (load_dialog dcl))) ); and ); not (princ "\nUnable to write or load the DCL file.") (setq dcf 0) ) ( (not (new_dialog "test" dch)) (princ "\nUnable to display the dialog") (setq dcf 0) ) (T (eval (read (apply 'strcat (mapcar 'chr '(40 83 69 84 95 84 73 76 69 32 34 101 114 114 111 114 34 32 34 87 114 105 116 116 101 110 32 98 121 32 71 114 114 114 34 41))))) (mapcar (function (lambda (rk rv) (mapcar (function (lambda ( k v ) (action_tile k (vl-prin1-to-string (quote ( (lambda ( / i n tmp ) (cond ( (not (nth (setq i (vl-position $key (apply 'append kL))) (apply 'append vL))) (setq vL (GroupByN 3 (SubstNth i "O" (apply 'append vL)))) (cond ( (vl-some 'null (apply 'append vL)) ; SubstNth ( n v L ) (cond ; apply a little logic (but not alot, since we don't want to draw everytime) ( ; row (and (setq n -1) (setq n (vl-some '(lambda (row) (setq n (1+ n)) (if (and (= 2 (length (vl-remove-if-not '(lambda (x) (= x "O")) row))) (vl-some 'null row) ); and n ); if ); lambda (row) vL ); vl-some ); setq n ); and (setq vL (SubstNth n (SubstNth (vl-position nil (nth n vL)) "X" (nth n vL)) vL ); SubstNth ); setq vL ) ; row ( ; col (and (setq n -1) (setq n (vl-some '(lambda (col) (setq n (1+ n)) (if (and (= 2 (length (vl-remove-if-not '(lambda (x) (= x "O")) col))) (vl-some 'null col) ); and n ); if ); lambda (col) (apply 'mapcar (cons 'list vL)) ); vl-some ); setq n ); and (setq vL (apply 'mapcar (cons 'list vL))) (setq vL (SubstNth n (SubstNth (vl-position nil (nth n vL)) "X" (nth n vL)) vL ); SubstNth ); setq vL (setq vL (apply 'mapcar (cons 'list vL))) ) ; col ( ; mid (null (nth 1 (nth 1 vL))) (setq vL (SubstNth 1 (SubstNth 1 "X" (nth 1 vL)) vL ); SubstNth ); setq vL ) ; mid (t ; random! (while (nth (setq tmp (LM:randrange 0 ) (apply 'append vL))) (setq vL (GroupByN 3 (SubstNth tmp "X" (apply 'append vL)))) ); t ); cond ); vl-some 'null ); cond (cond ( (or (vl-some '(lambda (x) (equal x '("O" "O" "O"))) (append vL (apply 'mapcar (cons 'list vL)))) (vl-some '(lambda (x) (equal (mapcar 'nth '(0 1 2) x) '("O" "O" "O"))) (list vL (reverse vL))) ); or (done_dialog 3) ) ( (or (vl-some '(lambda (x) (equal x '("X" "X" "X"))) (append vL (apply 'mapcar (cons 'list vL)))) (vl-some '(lambda (x) (equal (mapcar 'nth '(0 1 2) x) '("X" "X" "X"))) (list vL (reverse vL))) ); or (done_dialog 4) ) ( (apply 'and (apply 'append vL)) (done_dialog 5) ) ( (done_dialog 2) ) ); cond ) ( (set_tile "error" "Already taken!") ) ); cond ); lambda ) ); quote ); vl-prin1-to-string ); action_tile k ); lambda ); function rk rv ); mapcar ); lambda ); function kL vL ); mapcar (cond ( (= dcf 3) (set_tile "error" "You win!") (mapcar '(lambda (x) (mapcar '(lambda (xx) (mode_tile xx 1)) x)) kL) ) ( (= dcf 4) (set_tile "error" "You loose!") (mapcar '(lambda (x) (mapcar '(lambda (xx) (mode_tile xx 1)) x)) kL) ) ( (= dcf 5) (set_tile "error" "Draw!") (mapcar '(lambda (x) (mapcar '(lambda (xx) (mode_tile xx 1)) x)) kL) ) ); cond (setq dcf (start_dialog)) ); T ); cond ); while (= 0 dcf) ); progn (princ "\nUser cancelled the dialog.") ) ); cond (*error* nil) (princ) ); defun ;; Rand - Lee Mac ;; PRNG implementing a linear congruential generator with ;; parameters derived from the book 'Numerical Recipes' (defun LM:rand ( / a c m ) (setq m 4294967296.0 a 1664525.0 c 1013904223.0 $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m) ) (/ $xn m) ) ;; Random in Range - Lee Mac ;; Returns a pseudo-random integral number in a given range (inclusive) (defun LM:randrange ( a b ) (+ (min a b) (fix (* (LM:rand) (1+ (abs (- a b)))))) ) Have fun! Imma gona do my drafting work now.. Quote Link to comment Share on other sites More sharing options...
rlx Posted March 18, 2018 Share Posted March 18, 2018 Nice! Can't wait for v2.0 : 4 in a row or v3.0 : 5 in a row :-) or even better : Mahjong gr. Rlx Quote Link to comment Share on other sites More sharing options...
Grrr Posted March 18, 2018 Author Share Posted March 18, 2018 Nice! Can't wait for v2.0 : 4 in a row or v3.0 : 5 in a row :-) or even better : Mahjong gr. Rlx Thanks, I didn't even knew that 4x4 / 5x5 .. existed. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted March 18, 2018 Share Posted March 18, 2018 Here are my oldies, but there must be 2 players - I haven't considered artificial intelligence : https://www.theswamp.org/index.php?topic=49245.0 (you have to be logged) P.S. I've set my firefox to work with https - if you can't access, change https to http... Quote Link to comment Share on other sites More sharing options...
pBe Posted March 18, 2018 Share Posted March 18, 2018 CADTutor was down for maintenance, which reminded me what I wanted to do:.. Shouldn't that be "No drafting work, which reminded me what I wanted to do:.." You have too much time in your hand Grrr One thing though, Put an option where the AI start first, If I start from the center I always win or draw. Thinking about it, Once can write a code where the game always ends in a draw. [/s]ALWAYS, no win, just draw. Okay I changed my mind. its Win or draw but never lose. Is there a way to never lose at Tic-Tac-Toe Tic-tac-toe#Combinatorics Quote Link to comment Share on other sites More sharing options...
Grrr Posted March 18, 2018 Author Share Posted March 18, 2018 Here are my oldies, but there must be 2 players - I haven't considered artificial intelligence :https://www.theswamp.org/index.php?topic=49245.0 (you have to be logged) P.S. I've set my firefox to work with https - if you can't access, change https to http... Wow, thats insane.. both variations 2D and 3D! Now I remember that I was looking before for tic tac toe, found yours, but rather wanted a DCL version. Shouldn't that be "No drafting work, which reminded me what I wanted to do:.." You have too much time in your hand Grrr Free time.. well, I'm just distributing it for work or interests. Thankfully this one took me 30-40 minutes of writing. One thing though, Put an option where the AI start first, If I start from the center I always win or draw. Thinking about it, Once can write a code where the game always ends in a draw. [/s]ALWAYS, no win, just draw. Okay I changed my mind. its Win or draw but never lose. At first the AI started at random cell, but then I thought that the best logical position would be middle-center (if it was free). I could included more checks, but would be kinda boring everytime ending with a draw or losing. Did not consider to put any checks for the AI at all.. but it really bothered me what dumb@ss it was, when it doesn't blocks me on (O nil O) / (O O nil) / (nil O O) rows or columns. Is there a way to never lose at Tic-Tac-Toe Tic-tac-toe#Combinatorics Could use them, if I wanted to win a bet.. but now you brought the next idea "Gambling Game". Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 19, 2018 Share Posted March 19, 2018 (edited) Grrr check out the game "Connect 4" Edited March 19, 2018 by BIGAL Quote Link to comment Share on other sites More sharing options...
