Coders
Does any of you know if it is possible encrypt txt files?
I have some output data written to a txt file using lsp but that is sensitive and i want it to be encrypted and decrypted when the lsp is needing the info again?
Compile them to VLX using the vlide.
And how to de-compile to read the file again?
Or set it as variable and load that back in
any idea how i can set password protection on xls files using lisp?
You don't "decompile". You have source code that you compile. :unsure:
i wasn't talking about LSP files but txt or other file types lol
And fas cant be read by lsp using the read-line funtion as far as i know
You would need a commercial encryptor program that reads / writes. Just Google. You may have to pay for it.
How secure do you want the file to be?
You could do something very simple that makes it a pain to read, for example at the start of the file list an encryption key, perhaps 7 double digit numbers (65 03 14 etc) then simple go through the text file shifting each character by the next number in the key, either add or subtraction as well. Simple to work out and code I guess.
Similarly to hav it password protected you could do similar with the passwird being the key
Have you though about writing a Binary file ? You wont see the text. Its a bit more complicated get & put bytes.
Here is basic idea if OP means encrypt/decrypt text file, ie: ascii
;simple XOR cipher - hanhphuc
;reference https://en.wikipedia.org/wiki/XOR_cipher
(defun [color="blue"]xor[/color] (str i) (vl-list->string (mapcar ''((x) (boole 6 i x)) (vl-string->list str))))
;Test= "11110011" = 243 (ascii)
_$ (setq str (xor "Hanhphuc" 243 )) [color="red"]; encypt [/color]
[color="green"]"»’›ƒ›†"[/color]
_$ (xor str 243)[color="red"]; decrypt[/color]
[color="green"]"Hanhphuc"[/color]
;Example from wiki
"W"; 87
"i"; 105
"k"; 107
"i"; 105
;example; [color="red"][b]W[/b][/color]iki
(ascii (xor "[color="red"]W[/color]" 243) )
; 164
;(chr "W") = 87
;"11110011" = 243
_$ ([color="blue"]menucmd[/color] "M=$([color="blue"]xor[/color], 87, 243)")
; 164
;Decrypt
(xor "‡»¶ó¢¦º°¸ó±¡¼¤½óµ¼«ó¹¦¾£*ó¼¥¶¡ó§»¶ó¿²©ªó·¼´" 211)
(xor "ж»þ¯«·½µþ¼¬±©°þ¸±¦þ´«³®*þ±¨»¬þª¶»þ²¿¤§þº±¹"  222)
(xor "½ŒÉ˜œ€Š‚É‹›†ž‡É†‘Ƀœ„™šÉ†ŸŒ›ÉŒÉ…ˆ“É†Ž" 233)
"The quick brown fox jumps over the lazy dog"
Edited by hanhphuc
Thanks guys/girls for all the idea's cq codes
There are a few examples HERE for en\decrypting.
  • 3 months later...
hanhphuc can create password strings comparing with encrypt
I have an autolisp file:
(defun c:test ()
(vl-registry-read "HKEY_CURRENT_USER\\Software\\Microsoft\\pass")
("HKEY_CURRENT_USER\\Software\\Microsoft\\pass" "" "abcq123")
(setq Password "HKEY_CURRENT_USER\\Software\\Microsoft\\pass")
(setq password (123456789abc)
password2 (987654321cba)
(setq password password2 )
(setq 1 9)
(setq 2 8)
(setq 3 7)
(setq 4 6)
(setq 5 5)
(setq 7 3)
(setq 8 2)
(setq 9 1)
(setq a c)
(setq b a)
(setq c b)
(if (= Password "abc123") (equal password password2 ) fuzz)
please help
I want the password to be equal to passwor2 to run lisp
not sure i understand, try assoc list
[color="green"];vanilla[/color]
(defun foo (str)
 (apply 'strcat
 (mapcar ''((x)
	    (cond
	     ((cdr
	       ([color="blue"]assoc[/color]
		(chr x)
		'([color="purple"]("1" . "9")
		  ("2" . "8")
		  ("3" . "7")
		  ("4" . "6")
		  ("5" . "5")
		  ("6" . "4")
		  ("7" . "3")
		  ("8" . "2")
		  ("9" . "1")
		  ("10" . "0")
		  ("a" . "c")
		  ("b" . "b")
		  ("c" . "a")[/color]
(foo [color="purple"]"123abc"[/color])
[color="green"]"987cba"[/color] ?
[color="green"];Vlisp[/color]
([color="blue"]vl-string-translate [/color][color="purple"]"1234567890abc" "9876543210cba"[/color] [color="red"][b]"123abc"[/b][/color])
Edited by hanhphuc
add vlisp version
