blintz Posted March 29, 2018 Share Posted March 29, 2018 Hello to all sorry, I use the translator I have a "A_Hyd_mm" folder with the hydraulic blocks of the autocad electrical library I want to create slides of these blocks I use this Script to create slides _OPEN FILE (command "_zoom" "_E") SLIDE1 _QSAVE the code works but displays the exploded entity I do not see the clean design but with all the attribute labels e.g thank's Quote Link to comment Share on other sites More sharing options...
blintz Posted March 29, 2018 Author Share Posted March 29, 2018 https://drive.google.com/file/d/1m-YkpVmkIk04PM60VArCEWgALpWsCFvz/view?usp=sharing https://drive.google.com/file/d/109BoZ4VtKKwf2k5pkJ1ydPjvMdaQCtGt/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 29, 2018 Share Posted March 29, 2018 My suggestion just check the mslide no cad at moment _OPEN FILE2 (command "_zoom" "_E") (command "_zoom" "0.8") mSLIDE _close _OPEN FILE2 (command "_zoom" "_E") (command "_zoom" "0.8") mSLIDE _close Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 30, 2018 Share Posted March 30, 2018 I have moved your thread to the The CUI, Hatches, Linetypes, Scripts & Macros Forum. Quote Link to comment Share on other sites More sharing options...
blintz Posted March 30, 2018 Author Share Posted March 30, 2018 ok Quote Link to comment Share on other sites More sharing options...
blintz Posted March 30, 2018 Author Share Posted March 30, 2018 Thanks Al for your advice. It works well but the problem remains I have to add now that I use an excel vba to do this this prg has two problems 1. does not allow saving to a directory other than where it was taken from original files 2. each * .sld file is saved and created but each view is dirty, see all labels Now or this excel file is corrupt or it exists better as a code thank you all Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 30, 2018 Share Posted March 30, 2018 The only way to avoid "dirty" is to change the dwg then make the slide a manual task I did this for a lot of our slides really used erase very hard but did not save. filedia 0 _Open file1 (command "_zoom" "_E") (command "_zoom" "0.8") mSLIDE c:\myslides\file1 _close _OPEN FILE2 (command "_zoom" "_E") (command "_zoom" "0.8") mSLIDE c:\myslides\file2 _close Quote Link to comment Share on other sites More sharing options...
blintz Posted April 1, 2018 Author Share Posted April 1, 2018 Hi Al I understood your speech and I appreciate your every advice but if this lisp does everything because script no? furthermore, if trying to modify sld or dxf in windows jpg format, bmp too many problems to avoid future questions, I have to do database of hydraulic libraries now I attach lisp https://drive.google.com/file/d/1JU5DFs5mwZTjDJgEoAy2V1yLnj-Vp3wk/view?usp=sharing then I attach sql and electric dwg Quote Link to comment Share on other sites More sharing options...
