Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    AutoCAD Manual Entry between Lisp Routine.
    Hi Everyone.
    I have Lisp file to make double offset, offset distance are getting automatically as per lisp. but i want enter that distance manually and that entered value will be taken as offset distance.
    Please anyone tell me how to change this.
    Code:
    (defun c:oly (/ l s p e)
    (command ".undo" "m")
    (command "-layer" "M" "DELETE-LAYER" "c" "green" "DELETE-LAYER" "" "")
      (setq l (entlast))
      (if (tblsearch "LAYER" "DELETE-LAYER")
        (while (and
                 (setq s (car (entsel "\nPick Line/Polyline to offset :")))
                 (wcmatch (cdr (assoc 0 (entget s))) "LINE,*POLYLINE")
                 (setq p (getpoint "\nSpecify offset side :"))
          (foreach x '((1.25 6) (1.75 3))
            (command "_.offset" (car x) (ssadd s) "_non" p "")
            (and
              (not (= (setq e (entlast)) l))
              (entmod
                (append
                  (entmod
                    (subst
                      '(8 . "DELETE-LAYER")
                      (assoc 8 (entget e))
                      (entget e)
                  (list (cons 62 (cadr x)))
              (setq l e)
        (alert "Layer name <DELETE-LAYER> is not found in drawing <!>.")
    Thanks in Advance
    Full Member
    AutoCAD 2014
    Dec 2010
    79
    So, now that distance is here:
    first offset:
    distance: 1.25, color: 6
    second offset:
    distance: 1.75, color: 3
    Do you still want 2 lines?
    What about those colors?
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    Yes still i need to offset two lines both are coming with different colours..
    Right now i want to enter the offset distance manually.
    Full Member
    AutoCAD 2014
    Dec 2010
    79
    Code:
    (setq offsetdistance 0.0)  ;; just to remember it next time
    (setq offsetdistance2 0.0)  ;; just to remember it next time
    (defun c:oly (/ l s p e x prompt data)
      (if (> offsetdistance 0.0)
        (setq prompt (strcat "\nEnter distance 1 <" (rtos offsetdistance 2 2) ">: "))
        (setq prompt "\nEnter distance 1: ")
      (if (setq x (getreal prompt))
        (setq offsetdistance x)
      (if (> offsetdistance2 0.0)
        (setq prompt (strcat "\nEnter distance 2 <" (rtos offsetdistance2 2 2) ">: "))
        (setq prompt "\nEnter distance 2: ")
        (setq offsetdistance2 x)
      (setq data (list
        (list offsetdistance 6)
        (list offsetdistance2 3)
        (setq l (entlast))
          (while (and
           (foreach x data
              (and
                (entmod
                  (append
                    (entmod
                      (subst
                        (entget e)
                (setq l e)
    If you want different colors, change the 6 and the 3 in these lines:
    Code:
      (setq data (list
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,577
    I am going to say I did not look to closely will try to find I did a offset routine that just allowed like a csv as input 3,2,-3,-2 so end up with 4 lines +/ve I guess could add color also.
    Somethings just write and post and dont really save then this happens can not find.
    This is not what I was looking for but a simple offset you can enter -ve to go other side.
    Code:
    (defun C:MULOFF ( / obj s off)
    (vl-load-com)
    (setq obj (entsel "\nSelectObject"))
    (setq s (getpoint "\nPick Offset side"))
    (while (/= (setq off (getreal "\nEnter offset or Enter to exit")) nil)
    (vl-cmdf "_.offset" off obj s "")
    (setq obj (entlast))
    (c:muloff)
    If you want change layer
    Code:
    (chprop obj "la" "delete-layer" "")
  6. #6
    Full Member
    AutoCAD 2015
    Sep 2016
    99
    Thank you so much Emmanuel,
    It's working perfectly.
    One more Help, I want to offset two more lines (total 4 lines) with different distances, Please tell me how to change the lisp.
  7. #7
    Full Member
    AutoCAD 2014
    Dec 2010
    79
    4 lines:
    Code:
    (setq offsetdistance3 0.0)
    (setq offsetdistance4 0.0)
     (if (> offsetdistance3 0.0)
        (setq prompt (strcat "\nEnter distance 3 <" (rtos offsetdistance3 2 2) ">: "))
        (setq prompt "\nEnter distance 3: ")
        (setq offsetdistance3 x)
     (if (> offsetdistance4 0.0)
        (setq prompt (strcat "\nEnter distance 4 <" (rtos offsetdistance4 2 2) ">: "))
        (setq prompt "\nEnter distance 4: ")
        (setq offsetdistance4 x)
      (setq data (list
        (list offsetdistance3 4)
        (list offsetdistance4 5)
        (setq l (entlast))
          (while (and
           (foreach x data
              (and
                (entmod
                  (append
                    (entmod
                      (subst
                        (entget e)
                (setq l e)
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    707
    Quote Originally Posted by Emmanuel Delay View Post
    4 lines:
    Code:
      (setq data (list
    hi, FWIW prompt is a protective symbol. my $0.05 (setq str .. ) instead of (setq prompt (getstring ))
    another, my suggestion for multiple getreal
    it accepts zero & negative, you can modify to suit you
    Code:
    (defun _getreal (msg lst / np str l )
    ;hanhphuc
      (while (not np )
        (setq str  (getstring t
                              (strcat msg
                                      (vl-string-translate
                                        (vl-princ-to-string (mapcar '(lambda (x) (strcat "|" (rtos x 2))) lst))
              l    (cond ((read (strcat "(" str ")")))
                         (lst)
              np (if (and l (vl-every 'numberp l))
                     l
                     (prompt "\nOops! Invalid value !!")
      l
    Example:
    Code:
    (setq A (_getreal "\nEnter multiple offset distance," nil ))
    Enter multiple offset distance, nil ? : 1 2 3 4 5 ;<--user input separate by space
    (1 2 3 4 5)
    (setq B (_getreal "\nEnter multiple offset distance," A ))
    Enter multiple offset,  |1 |2 |3 |4 |5| ? : ; <Enter> to accept default values
    (1 2 3 4 5)
    ;from your test
    (setq data (_getreal "\nEnter multiple offset distance," B ))
    Enter multiple offset,  |1 |2 |3 |4 |5| ? : 6 3 4 5  ;<--user overrides default
    (6 3 4 5)
    ;data to be used
    (foreach x data
    ; offset x bla bla
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,577
    hahnphuc basicly the same as I suggested but csv style still loooking when you have so many hard to remember where you put the code some times.
    for fun the bla bla
    Code:
    (defun c:muloff(/ o s l)
    (setq o (entsel "\nSelect Object"))
    (setq pt (getpoint "\nPick Offset side"))
    (setq data (_prompt "\nEnter multiple offset distance," B ))
    (foreach i data
    (vl-cmdf "_.offset" i o pt "")
  10. #10
    AutoCAD 2007
    Apr 2013
    Happy Garden
    707
    Quote Originally Posted by BIGAL View Post
    yeah BIGAL, csv is good solution too
    i just offer generic suggestion rather than @Emmanuel Delay to rewrite his code if OP request more offsets
  1. Repeat Data Entry in Routine
    By Arizona in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Dec 2016, 11:57 pm
  2. Wipeout Lisp That helps me avoid the manual typing.
    By SunnyTurtle in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Sep 2013, 04:25 pm
  3. [LISP] First time writing LISP routine... trying to rotate, move and scale
    By chiimayred in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jul 2013, 06:02 pm
  4. Combine three lisp routine into one routine.
    By BrianTFC in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Feb 2012, 05:11 pm
  5. Plotting Routine - Allow word with spaces for text entry for paper size??
    By ILoveMadoka in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jun 2011, 01:09 pm
