wimal Posted June 25, 2018 Posted June 25, 2018 I have a group containing lines and arcs only.Can I get the total length of lines and arcs with lisp. Quote
JuniorNogueira Posted June 25, 2018 Posted June 25, 2018 Try this: (defun tlines () (setq lbeg (cdr (assoc '10 ent))) (setq lend (cdr (assoc '11 ent))) (setq llen (distance lbeg lend)) (setq tlen (+ tlen llen)) (ssdel sn ss1) ) (defun tarcs () (setq cen (cdr (assoc '10 ent))) (setq rad (cdr (assoc '40 ent))) (setq dia (* rad 2.0)) (setq circ (* (* rad pi) 2.0)) (setq sang (cdr (assoc '50 ent))) (setq eang (cdr (assoc '51 ent))) (if (< eang sang) (setq eang (+ eang (* pi 2.0))) ) (setq tang (- eang sang)) (setq tang2 (* (/ tang pi) 180.0)) (setq circ2 (/ tang2 360.0)) (setq alen (* circ2 circ)) (setq tlen (+ tlen alen)) (princ) (ssdel sn ss1) ) (defun tplines () (command "area" "e" sn) (setq tlen (+ tlen (getvar "perimeter"))) (ssdel sn ss1) ) (defun tsplines () (command "area" "e" sn) (setq tlen (+ tlen (getvar "perimeter"))) (ssdel sn ss1) ) (DEFUN C:TOTLEN (/ tlen ss1 sn sn2 et) (setq cmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (setq tlen 0) (prompt "\nSelect only the entities you want for the total length:" ) (setq ss1 (ssget)) (while (> (sslength ss1) 0) (setq sn (ssname ss1 0)) (setq ent (entget sn)) (setq et (cdr (assoc '0 ent))) (cond ((= et "LINE") (tlines)) ((= et "ARC") (tarcs)) ((= et "LWPOLYLINE") (tplines)) ((= et "POLYLINE") (tplines)) ((= et "SPLINE") (tsplines)) ((or (/= et "LINE") (/= et "ARC") (/= et "LWPOLYLINE") (/= et "POLYLINE") (/= et "SPLINE") ) (ssdel sn ss1) ) ) ) (alert (strcat "\nThe total length of selected rows, polylines and arcs is:" (rtos tlen 2 2) ) ) (setvar "cmdecho" cmdecho) (prompt "\nAplicativo de terceiros!! ") (princ) ) Quote
hanhphuc Posted June 25, 2018 Posted June 25, 2018 (edited) (vl-load-com) (defun c:gsum (/ l len ) (if (vlax-for x (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))) (setq len 0. l (cons (list "Group " (vla-get-Name x) " Length = " (vlax-for x x (if (wcmatch (strcase (vla-get-ObjectName x)) "*BARC,*BLINE") (setq len (+ len (vlax-curve-getdistatparam x (vlax-curve-getendparam x)))) ) (rtos len 2) ) ) l ) ) ) (foreach x l (terpri) (princ (apply 'strcat x))) (alert "\nOops! No group found?") ) (textscr) (princ) ) Edited June 25, 2018 by hanhphuc removed 'and' Quote
wimal Posted June 26, 2018 Author Posted June 26, 2018 (vl-load-com) (defun c:gsum (/ l len ) (if (vlax-for x (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))) (setq len 0. l (cons (list "Group " (vla-get-Name x) " Length = " (vlax-for x x (if (wcmatch (strcase (vla-get-ObjectName x)) "*BARC,*BLINE") (setq len (+ len (vlax-curve-getdistatparam x (vlax-curve-getendparam x)))) ) (rtos len 2) ) ) l ) ) ) (foreach x l (terpri) (princ (apply 'strcat x))) (alert "\nOops! No group found?") ) (textscr) (princ) ) Program is working . But I need to first select the group and find the total length of that group. Quote
wimal Posted June 26, 2018 Author Posted June 26, 2018 Try this: (defun tlines () (setq lbeg (cdr (assoc '10 ent))) (setq lend (cdr (assoc '11 ent))) (setq llen (distance lbeg lend)) (setq tlen (+ tlen llen)) (ssdel sn ss1) ) (defun tarcs () (setq cen (cdr (assoc '10 ent))) (setq rad (cdr (assoc '40 ent))) (setq dia (* rad 2.0)) (setq circ (* (* rad pi) 2.0)) (setq sang (cdr (assoc '50 ent))) (setq eang (cdr (assoc '51 ent))) (if (< eang sang) (setq eang (+ eang (* pi 2.0))) ) (setq tang (- eang sang)) (setq tang2 (* (/ tang pi) 180.0)) (setq circ2 (/ tang2 360.0)) (setq alen (* circ2 circ)) (setq tlen (+ tlen alen)) (princ) (ssdel sn ss1) ) (defun tplines () (command "area" "e" sn) (setq tlen (+ tlen (getvar "perimeter"))) (ssdel sn ss1) ) (defun tsplines () (command "area" "e" sn) (setq tlen (+ tlen (getvar "perimeter"))) (ssdel sn ss1) ) (DEFUN C:TOTLEN (/ tlen ss1 sn sn2 et) (setq cmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (setq tlen 0) (prompt "\nSelect only the entities you want for the total length:" ) (setq ss1 (ssget)) (while (> (sslength ss1) 0) (setq sn (ssname ss1 0)) (setq ent (entget sn)) (setq et (cdr (assoc '0 ent))) (cond ((= et "LINE") (tlines)) ((= et "ARC") (tarcs)) ((= et "LWPOLYLINE") (tplines)) ((= et "POLYLINE") (tplines)) ((= et "SPLINE") (tsplines)) ((or (/= et "LINE") (/= et "ARC") (/= et "LWPOLYLINE") (/= et "POLYLINE") (/= et "SPLINE") ) (ssdel sn ss1) ) ) ) (alert (strcat "\nThe total length of selected rows, polylines and arcs is:" (rtos tlen 2 2) ) ) (setvar "cmdecho" cmdecho) (prompt "\nAplicativo de terceiros!! ") (princ) ) Thanks It is working perfectlly. Quote
hanhphuc Posted June 26, 2018 Posted June 26, 2018 Program is working . But I need to first select the group and find the total length of that group. what do you mean "group' here ? if it is merely a selection not 'ACAD_GROUP' ? then quick & dirty VL (vl-load-com) (defun c:sum ( / l ) (if (and (ssget '((0 . [color="purple"]"LINE,ARC"[/color])))[color="green"] ; <-- add selection filter with comma e.g: *POLYLINE,SPLINE,etc.. [/color] (vlax-for x (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))) (setq l (cons (vlax-curve-getdistatparam x (vlax-curve-getendparam x)) l) ) ) ) (alert (strcat "\nTotal length = " (rtos (apply '+ l ) 2 ))) (princ "\nNothing selected?") ) (princ) ) FWIW here is Lee's version Quote
