Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member 3dwannab's Avatar
    3dwannab's Computer Details
    Windows 10 Pro
    Self-Built
    TR 1950X
    Architectural
    3dwannab's Discipline Details
    Arch Technician and Arch Viz
    Architectural
    TBC
    AutoCAD 2019
    Jun 2012
    Ireland
    192
    Default Trouble with vlax-delete
    Hi all,
    Here's a routine originally wrote by LeeMac.
    I wanted to delete the previously inserted blocks after it's done updating them.
    Thanks in advance. I'll wrote where the problem lies in my code.
    Code:
    (defun c:BK_Update_InsertAll_Redefine_ATTSYNCAll ( / dir doc extn spc )
        (setq extn "dwg") ;; Extension of files to Insert e.g "dwg"
        (if
            ; (setq dir (LM:DirectoryDialog (strcat "Select Directory of " (strcase extn) " Files to Insert") nil 512))
            (setq dir "W:/SS_CAD/SS_AutoCAD Block's Library/Blocks Updated/" blk "`.dwg")
                (setq doc (vla-get-activedocument (vlax-get-acad-object))
                  spc (vlax-get-property doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
                (foreach file (vl-directory-files dir (strcat "*." extn) 1)
                    (vla-insertblock spc (vlax-3D-point '(0.0 -50.0 0.0)) (strcat dir "\\" file) 1.0 1.0 1.0 0.0)
                (vla-regen doc acallviewports)
                (command "ATTSYNC" "NAME" "*")
                ; NOT WORKING, I want to delete the previously inserted block.
                (vlax-delete (vlax-ename->vla-object spc))
            (princ "\n*Cancel*")
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Hi,
    The variable 'spc' represents the space object and not the block reference so replace the variable spc with (entlast) besides that you can use the function entdel to avoid converting the object to vla-object since its not needed later on for any use.
    Code:
    (entdel (entlast))
    Windows 10 Pro
    Self-Built
    TR 1950X
    Architectural
    Architectural
    TBC
    AutoCAD 2019
    Jun 2012
    Ireland
    192
    Quote Originally Posted by Tharwat View Post
    Hi,
    Code:
    (entdel (entlast))
    Thanks Tharwat, I've done what you suggested and it errors out.
    Code:
    error: bad function: #<VLA-OBJECT IAcadPaperSpace 000001e97f6fa558>
    My code:
    Code:
    (defun c:BK_Update_InsertAll_Redefine_ATTSYNCAll ( / dir doc extn entlast )
        (if
            (setq dir "W:/SS_CAD/SS_AutoCAD Block's Library/_DM Arch Blocks (Company Master Blocks)/1508 Blocks Updated/" blk "`.dwg")
                  entlast (vlax-get-property doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
                    (vla-insertblock entlast (vlax-3D-point '(0.0 -50.0 0.0)) (strcat dir "\\" file) 1.0 1.0 1.0 0.0)
                (entdel (entlast))
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Entlast is a function and you can not use it as variable otherwise you would have lots of error clashes so just replace it as follows:
    This:
    Code:
    with this:
    Code:
    (entdel (entlast))
  5. #5
    Windows 10 Pro
    Self-Built
    TR 1950X
    Architectural
    Architectural
    TBC
    AutoCAD 2019
    Jun 2012
    Ireland
    192
    This:
    Code:
    with this:
    Code:
    (entdel (entlast))
    Silly me. I got carried away there.
    Many thanks, Tharwat!
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    No worries at all.
    You are welcome.
  7. #7
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,478
    BTW theres no vlax-delete function, you can check in VLIDE:
    Code:
    _$ vlax-delete
    nil
    _$ vla-delete
    #<SUBR @00000083291f4188 vla-Delete>
    So the correct call would be either (vla-delete <vla-object>) or (vlax-invoke-method <vla-object> 'Delete).
  8. #8
    Windows 10 Pro
    Self-Built
    TR 1950X
    Architectural
    Architectural
    TBC
    AutoCAD 2019
    Jun 2012
    Ireland
    192
    Quote Originally Posted by Grrr View Post
    Code:
    _$ vlax-delete
    nil
    _$ vla-delete
    Thanks. So basically what you're saying is it needs an argument in the form of a <vla-object> ?
  9. #9
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,478
    Quote Originally Posted by 3dwannab View Post
    Yes, I guess you want to store into a variable the return of the vla-InsertBlock method, since it returns the vla-object of the inserted block.. and then use vla-Delete method on it.
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Good catch Grrr,
  1. vlax-curve-getDistAtPoint, vlax-curve-getParamAtPoint
    By Grrr in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jul 2016, 05:22 am
  2. vlax-get-property on (vlax-get-acad-object).
    By Qonfire in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2012, 05:18 pm
  3. I can't delete lines using the delete button!!
    By lofty in forum AutoCAD General
    Last Post: 10th Dec 2009, 07:36 pm
  4. I can't delete line using delete and backspace keys
    By alif in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2009, 03:42 am
  5. vlax-curve-getStartParam .... vlax-curve-getStartPoint
    By Lee Mac in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jan 2009, 05:28 pm
Tags for this Thread
