wharris1996 Posted July 12, 2018 Share Posted July 12, 2018 Hello, I am trying to make a script that will move items for me. I am importing anywhere from 2 to 9 drawings as Xrefs, then running this VBA script to move them based on the sheet number to a predefined spot for layout setups. The script is reading the names fine and making the point, but it is returning Runtime Error 5 on the move command, and I am not sure why. Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
wharris1996 Posted July 12, 2018 Author Share Posted July 12, 2018 Sorry didn't see CODE formatting guidelines: Sub DWG_Combine() 'On Error Resume Next 'Reads number of objects, moves them based on name, then creates layouts. Finally, explodes all for editing Dim i, NumObj, ObjID As Integer Dim SS1 As AcadSelectionSet Dim MspaceObj As AcadObject Dim p1(0 To 2), p2(0 To 2) As Double 'set p1 as origin p1(0) = 0: p1(1) = 0: p1(2) = 0 'selection set? If Err.Number <> 0 Then Set SS1 = ThisDrawing.SelectionSets.Add("SS1") End If 'Counts number of objects NumObj = ThisDrawing.ModelSpace.Count 'MsgBox NumObj i = 0 'Cycles through each item in the modelspace, reads the ID number, and moves a multiple of the ID Number For Each Item In ThisDrawing.ModelSpace Set MspaceObj = ThisDrawing.ModelSpace.Item(i) 'MsgBox MspaceObj.EffectiveName ObjID = Left(Right(MspaceObj.EffectiveName, 2), 1) 'MsgBox objID p2(0) = (ObjID - 1) * 45: p2(1) = 0: p2(2) = 0 MspaceObj.Move p1, p2 i = i + 1 Next End Sub Quote Link to comment Share on other sites More sharing options...
