VBA Code not working
smuthuc
Please the below VBA code not working
please correct this one
Public Sub Draw_Bpoly()
Dim p As Variant
p = ThisDrawing.Utility.GetPoint(, "First the Point:")
Dim p1(1) As Double
p1(0) = p(0)
p1(1) = p(1)
ThisDrawing.SetVariable "osmode", 0
ThisDrawing.SendCommand "_.-boundary" & vbCr & "_A" & vbCr & "_I" & vbCr & "_N" & vbCr & vbCr & vbCr & p1 & vbCr
End Sub
thanking you...:roll:
Edited by SLW210
Code Tags
I'm not an AutoCAD VBA user and do not have it installed but I would think that p should be dimensioned as an array and not a plain variant. For example,
Dim p(0 To 2) As Double
Dim p As Variant
Dim pstr As String
p = ThisDrawing.Utility.GetPoint(, "Pick the inner point of boundary")
pstr = Replace(CStr(p(0)), ",", ".") & "," & Replace(CStr(p(1)), ",", ".")
ThisDrawing.SendCommand Chr(3) & Chr(3) & "_.-boundary" & vbCr & pstr & vbCr & vbCr
End Sub
Thanking you....
i used yours code. but i is showing invalid input....
but i changed little things and it will work well once again thanking....
Dim p As Variant
Dim pstr As String
ThisDrawing.SendCommand  "_.-boundary" & vbCr & pstr & vbCr & vbCr
End Sub
Edited by SLW210
Code Tags
Thanking you for your kind replys.......
i used your advice even i will show type mismatch
then i got solution from others like you i will work well
Dim p As Variant
ThisDrawing.SendCommand "_.-boundary" & vbCr & "_A" & vbCr & "_I" & vbCr & "_N" & vbCr & vbCr & vbCr & p(0) & "," & p(1) & vbCr & vbCr
End Sub
thanking you...
Edited by SLW210
Code Tags
