katto01 Posted July 16, 2018 Share Posted July 16, 2018 Hello, I am trying to get the bounding box for all entities on a layer. I would like to be able to do this from EXCEL. I tried to modify an AutoCAD VBA routine that works in the AutoCAD VBA to work in EXCEL, however I seem to miss something. Please see my code below. It fails at the ss(0).. line. Please advise Thank you Sub Get_BoundingBox() Dim XNAME As String 'On Error Resume Next 'This tells VBA to ignore errors Set ACAD = GetObject(, "AutoCAD.Application") 'Get a running instance of the class AutoCAD.Application Dim ssetObj As AcadSelectionSet Dim sset As AcadSelectionSets Dim acadobj As AcadObject Dim objname As String Dim ptllmin As Variant Dim ptllmax As Variant Dim HH As Variant Dim objlayer As String Dim entItem As AcadEntity Dim I As Integer Dim corner1(0 To 2) As Double Dim corner2(0 To 2) As Double corner1(0) = -10000000000#: corner1(1) = -10000000000#: corner1(2) = 0 corner2(0) = 10000000000#: corner2(1) = 10000000000#: corner2(2) = 0 I = 0 Set sset = ACAD.ActiveDocument.SelectionSets For Each ssetObj In sset If UCase(ssetObj.Name) = "TEST" Then sset.Item("TEST").Delete Exit For End If Next Set ssetObj = ACAD.ActiveDocument.SelectionSets.Add("TEST") ' Add all the objects to the selection set ssetObj.Select acSelectionSetAll Q$ = Chr(9) For Each acadobj In ssetObj objname = acadobj.ObjectName objlayer = acadobj.Layer HH = acadobj.Handle Const X = 0 Const Y = 1 ss(0).GetBoundingBox ptMin, ptMax For Each entItem In ss ACAD.ActiveDocument.entItem.GetBoundingBox ptllmin, ptllmax If ptllmin(X) < ptMin(X) Then ptMin(X) = ptllmin(X) If ptllmin(Y) < ptMin(Y) Then ptMin(Y) = ptllmin(Y) If ptllmax(X) > ptMax(X) Then ptMax(X) = ptllmax(X) If ptllmax(Y) > ptMax(Y) Then ptMax(Y) = ptllmax(Y) Next Sheet5.Cells(I, 1).Value = I Debug.Print objname, Q$, objlayer, Q$, HH I = I + 1 Sheet5.Cells(I, 1).Value = I Sheet5.Cells(I, 2).Value = objname Sheet5.Cells(I, 3).Value = objlayer Sheet5.Cells(I, 4).Value = HH Sheet5.Cells(I, 5).Value = ptMin(X) Sheet5.Cells(I, 6).Value = ptMin(Y) Sheet5.Cells(I, 7).Value = ptMax(X) Sheet5.Cells(I, 7).Value = ptMax(Y) Next acadobj End Sub Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 17, 2018 Share Posted July 17, 2018 (edited) I am no expert on VBA but compare this code by lee-mac and you can see that you are missing an object when calling the bounding box. (vl-catch-all-apply 'vla-getboundingbox (list obj 'a 'b)) Also ss(0) maybe just ss and why bounding box call twice ? Look into variables extmax extmin also lisp version (setq ss (ssget)) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))) (vla-getboundingbox obj 'll 'ur) (setq ll(vlax-safearray->list ll)) (setq ur (vlax-safearray->list ur)) (princ ll) ) Edited July 17, 2018 by BIGAL Quote Link to comment Share on other sites More sharing options...
