plecs Posted July 20, 2018 Posted July 20, 2018 I want to make a new application and when I press the load button lsp file I give the error "error: bad argument value: non-negative: -1" Quote
BIGAL Posted July 20, 2018 Posted July 20, 2018 Without the code a bit hard to work out whats wrong. Quote
plecs Posted July 20, 2018 Author Posted July 20, 2018 (defun c:intdrstg () ;========================================================================================================================== (vl-load-com) ;========================================================================================================================== (resetsilviu) ;se afla in setari_MobCAD ;========================================================================================================================== (setq ipt (getpoint "\n Alege colt DR-JOS <Exit>: ")) (setq ipt1 (getpoint "\n Alege colt DR-SUS <Exit>: ")) (setq ipt2 (getpoint "\n Pina unde STG-SUS <Exit>: ")) ;========================================================================================================================== (defun caremaidecare () ;========================================================================================================================== (vl-load-com) ;========================================================================================================================== (mapcar (function (lambda ( sym foo str def ) (set sym (cond (((eval foo) (strcat str " <" (vl-princ-to-string (set sym (cond ((eval sym)) ( def )))) "> : " ))) ((eval sym)))))) '(*nrs* *ret*) '(getint getint) '("\nNumar Spatii" "\nRetragere Intermediar DIN FATA") '(3 100)) ;========================================================================================================================== (progn (setq nrint (- *nrs* 1)) ;numar intermediari (setq spatiu (/(- (- (car ipt) (car ipt2)) (* nrint grPAL)) *nrs*)) ;lungime sparii intre intermediari (setq disp (rtos spatiu 5)) (setq hint (- (caddr ipt1) (caddr ipt))) ;inaltime intermediari H );end progn (princ) );end defun (princ) ;========================================================================================================================== (setq myAnswer "Da") ; set up a variable to hold the answer (setq dnint nil) ; set up a variable to hold your guess (while (/= myAnswer dnint) ;while you don't know the answer (initget "Da Nu") (setq dnint (getkword (strcat "\nSpatiu = " disp "mm" "[Da/Nu]: "))) (caremaidecare) ) ;close the loop ;========================================================================================================================== (cond ((= ckret "0") (progn (setq *a* (- *a* (+ *ret* *retpfl*))) ;adincime intermediari (setq ckret "1") ;ckret - este variabila care scade pfl daca are falt sau nut );end progn ) ((= ckret "1") (progn (setq *a* *a*) ;adincime polita cu retragere daca este cazul );end progn ) (T (prompt "\nInter Gresit")) );end cond ;========================================================================================================================== (offresetvar) ;se afla in setari_MobCAD ;========================================================================================================================== (resetsilviu) ;se afla in setari_MobCAD ;========================================================================================================================== (if (= dnint "Da") (progn (repeat nrint (if (null ipti) (progn (setq ipti (list (- (car ipt) (+ spatiu grPAL)) (+ (cadr ipt) *ret*) (caddr ipt))) ;XYZ point intermediari (command "_.box" "_non" ipti "L" grPAL *a* hint)(int1000) (setq a1 (list (car ipt) (cadr ipti)(caddr ipt))) ;XYZ point dreapta jos (setq a2 (list (car ipt) (cadr ipti)(caddr ipt1))) ;XYZ point dreapta sus (setq a3 (list (car ipt2) (cadr ipti)(caddr ipt))) ;XYZ point stinga jos (setq a4 (list (car ipt2) (cadr ipti)(caddr ipt1))) ;XYZ point stinga sus (entmakex (list (cons 0 "POINT") (cons 10 a1))) (entmakex (list (cons 0 "POINT") (cons 10 a2))) (entmakex (list (cons 0 "POINT") (cons 10 a3))) (entmakex (list (cons 0 "POINT") (cons 10 a4))) (setq s4 (list (car ipt) (cadr ipti) (caddr ipt1))) (setq s1 (list (- (car ipt) spatiu)(cadr ipti) (caddr ipt1))) ;XYZ point semn inter dreapta (setq s2 (list (car ipti) (cadr ipti) (caddr ipt1))) ;XYZ point semn inter stinga (setq s3 (list (car ipt2) (cadr ipti) (caddr ipt1))) ;XYZ point semn stinga (setq tx1 (list (+(car s1) (-(/ spatiu 2)150)) (cadr ipti) (caddr ipt1))) ;XYZ point text dreapta (setq tx2 (list (+ (car s3)(-(/ spatiu 2)150)) (cadr ipti) (caddr ipt1))) ;XYZ point text stinga (command "-insert" "dimsk" s4 "1" "" "0")(command "explode" (entlast));semn interior corp dreapta (command "-insert" "txto" tx1 "1" "" "0")(command "explode" (entlast)); (command "-insert" "dimsj" s1 "1" "" "0")(command "explode" (entlast));semn inter dreapta (command "-insert" "dimsk" s2 "1" "" "0")(command "explode" (entlast));semn inter stinga (command "-insert" "txto" tx2 "1" "" "0")(command "explode" (entlast)); (command "-insert" "dimsj" s3 "1" "" "0")(command "explode" (entlast));semn interior corp stinga (setq newcot (rtos spatiu 5)) (modcota) (setq cv1 (list (- (car ipti)160) (cadr ipti) (+ (caddr ipti) (-(/ hint 2)150)))) ;XYZ point text vertical (setq cv2 (list (car ipti) (cadr ipti)(+ (caddr ipti) hint)));XYZ point semn sus (command "-insert" "dimss" ipti "1" "" "0")(command "explode" (entlast));semn jos (command "-insert" "txtv" cv1 "1" "" "0")(command "explode" (entlast));text (command "-insert" "dimjs" cv2 "1" "" "0")(command "explode" (entlast));semn sus (setq newcot (rtos hint 5)) (modcota) ) (progn (setq ipti (list (- (car ipti) (+ grPAL spatiu)) (cadr ipti) (caddr ipti))) ;XYZ point intermediari (command "_.box" "_non" ipti "L" grPAL *a* hint)(int1000) (setq s1 (list (car ipti) (cadr ipti) (caddr ipt1)));XYZ point dreapta sus semn (setq tx1 (list (+ (car s1) (-(/ spatiu 2)130))(cadr s1) (caddr s1))) ;XYZ point text (setq s2 (list (+(car s1) grPAL) (cadr s1) (caddr s1))) ;XYZ point stinga sus semn (command "-insert" "dimsk" s1 "1" "" "0")(command "explode" (entlast));semn stinga (command "-insert" "txto" tx1 "1" "" "0")(command "explode" (entlast));text (command "-insert" "dimsj" s2 "1" "" "0")(command "explode" (entlast));semn dreapta (setq newcot (rtos spatiu 5)) (modcota) ) );end if );end repeat ;========================================================================================================================== (setq htext (RTOS hint)) (setq htext1 (RTOS spatiu)) (setq text (STRCAT "\nH-Inaltime Spatiu = " htext "-mm" " " "\nLumgime Spatiu = " htext1 "-mm")) ;(setq text1 (STRCAT "\nLumgime Spatiu = " htext1 "-mm" )) (prompt text) ;========================================================================================================================== )T);end if ;========================================================================================================================== (onresetvar);se afla in setari_MobCAD ;========================================================================================================================== (layrestordef) ;restore active layer ;se afla in setari_MobCAD ;========================================================================================================================== (setq varlst '(ipt1 ipt2 htext text htext1 text1 ipti a1 a2 a3 a4 s1 s2 tx1 tx2 *adi* *ret* hint spatiu nrint cv1 cv2 newcot dnint disp)) (mapcar '(lambda (x)(set x nil)) varlst) ;========================================================================================================================== (princ) );end defun (princ) ;========================================================================================================================== ;========================================================================================================================== ;========================================================================================================================== Quote
marko_ribar Posted July 20, 2018 Posted July 20, 2018 Have you tried searching the web and looking for similar problems solutions? https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/visual-lisp-make-application-error/td-p/8127427 HTH., M.R. Quote
