Lisp for Run/Execute the custom Command aautomatically
Hi Everyone,
I have a Lisp file to Turnoff unwanted Layers.
I want to run this lisp automatically, when i open the Drawing file.
Actually in my office i don't have a access for C Drive, so that i can't add this into acaddoc.lsp.
Please anyone help me out to do this.
(defun c:unoff (/ layers)
 (command "._-layer" "_f" "*Electric*" "")
(command "._-layer" "_off" "*Electric*" "")
Thanks in advance
Create an acaddoc.lsp file in the same directory as your drawings with the following content:
(defun c:unoff nil
   (command "_.-layer" "_f" "*Electric*" "_off" "*Electric*" "")
(if (= 'list (type s::startup))
   (setq s::startup (append s::startup '((c:unoff))))
   (defun-q s::startup nil (c:unoff))
Hello Lee,
Thank you so much for your code.
Its working Perfectly.
But in my case, i have saved the drawing file to different folders/Path, so can i save this lisp file to one common folder and run from that folder?
Or else we need to place create all the Drawing Directory?
Please let me Know.
Thanks
If you can't access the content of existing support paths as you seem to imply from your first post, add a new trusted support path to your AutoCAD environment and save it there.
I got it.
Thank you so much Lee.:)
