ehsantavassolian Posted July 21, 2018 Share Posted July 21, 2018 (edited) In the microstation software, I can choose a circle-shaped area on a map, draw a copy of the selected range out of the map so that I can block it and magnify it . Is it possible in AutoCAD or via Autolisp? Edited July 21, 2018 by ehsantavassolian Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted July 21, 2018 Share Posted July 21, 2018 Your attachments are invalid... If your map is actually DWG with CAD entities you can select portion you like, then block it and then do CLIPIT with circle shaped polygon to simulate your task... Quote Link to comment Share on other sites More sharing options...
ehsantavassolian Posted July 21, 2018 Author Share Posted July 21, 2018 yes i have dwg file But how can I choose all the drawings by choosing a circle. Without using Trim commands. them wipeout the circle and block it . The number of drawings in the map is very large, and the use of the Trim command is very time consuming can we do it with autolisp? Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 21, 2018 Share Posted July 21, 2018 Andrea did something similair to the request here. However I'm not sure whats the technique to create a viewport like that in modelspace. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted July 21, 2018 Share Posted July 21, 2018 Of course Andres have ideas... I replicated his achievement while ago... https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/magnifying-glass-in-autocad/m-p/7034374/highlight/true#M352530 HTH., M.R. Quote Link to comment Share on other sites More sharing options...
ehsantavassolian Posted July 22, 2018 Author Share Posted July 22, 2018 This was the best answer. thank you :shock: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/magnifying-glass-in-autocad/m-p/7034374#M352530 Quote Link to comment Share on other sites More sharing options...
Grrr Posted July 22, 2018 Share Posted July 22, 2018 Of course Andres have ideas... I replicated his achievement while ago...https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/magnifying-glass-in-autocad/m-p/7034374/highlight/true#M352530 HTH., M.R. Nice one, Marko! In order to slighly increase the performance I would suggest to add a 'sleep' so there won't be that many command calls per cursor movement: [color="red"](setq tm (rem (getvar 'cdate) 30))[/color] (while (/= 3 (car (setq gr (grread t)))) (if loop (entdel bn) ) (setq p (cadr gr)) (if [color="red"](/= tm (setq tmp (rem (getvar 'cdate) 30))[/color]) (vl-catch-all-apply (function (lambda nil (setq tm tmp) (setq v (mapcar '- '(0 0 0) p)) (setq vn (mapcar '* v (list scf scf scf))) (entupd (cdr (assoc -1 (entmod (subst (cons 10 p) (assoc 10 (entget s2)) (entget s2)))))) (setq ip (mapcar '+ pp vn)) (setq bn (vlax-vla-object->ename (vla-insertblock spc (vlax-3d-point ip) n scf scf scf 0))) (command "_.XCLIP" bn "" "_N" "_S" e) (setq loop t) ) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted July 22, 2018 Share Posted July 22, 2018 Why not use paper space viewports to accomplish this? Quote Link to comment Share on other sites More sharing options...
