Hello everyone,
Is there any solution to pass the value of a symbol defined in a function for another function to be used?
I made a very long routine that it is annoying to scroll down and up to find out mistakes, so I decided to divide it into several external functions that can be called by loading them where they would be needed.
At the end I wouldn't want to store any of these values, but I would like to keep them "alive" until the whole routine is over. That means pass some setq values to one function to the next one and so on.
The easiest way would be, of cours,e to put all the local variables in the main function for them not to be stored at the end of the whole process. I find it not so clean though.
Any suggestion? thanks in advance
Something like this ?
(defun C:SpaghettiCode ( / a b c a1 b1 c1 sub1 sub2 ) ; localise everything
 ;; declare some variables in our main function:
 (mapcar 'set '(a b c) '(1 "this is b" t))
 ;; declare a subfunction that expects three variables, and asigns global symbols 'a1', 'b1' and 'c1'
 (defun sub1 ( a b c )
   (setq a1 (* a 2))
   (setq b1 (strcat "yes, " b))
   (setq c1 (if c :vlax-true :vlax-false))
 ;; declare a subfunction that uses the above global symbols 'a1', 'b1' and 'c1'
 (defun sub2 nil
   (alert
     (strcat
       "\n'a1' is: " (itoa a1)
       "\n'b1' is: '" b1 "'"
       "\n'c1' is: '" (vl-prin1-to-string c1) "'"
 ;; Run the subfunctions:
 (sub1 a b c) ;; this will bound values to the symbols 'a1', 'b1' and 'c1'
 (sub2) ;; this will use the symbols 'a1', 'b1' and 'c1'
