Help! Call Lisp vlax-curve-getPointAtDist from VBA
joe2456
Hello Anybody Help.
I need to get point from spline with use lisp function in autocad vba
Could somebody can help me?
Best Regard
Joe
I write this function but still error on get variable form lisp
anybody help!
Function GetPointSpline(oEnt As AcadEntity, distance As Double) As Variant
Dim sVar As Variant
Dim strCom As String
Dim USERR1 As Variant
'sVar = ""
' Call Get Point in spline distance 1.5 from begin point
With ThisDrawing
   .SetVariable "USERR1", 1
   .SendCommand "(vl-load-com)" & vbCr
     strCom = "(setvar " & Chr(34) & "USERR1" & Chr(34) &  Chr(32) & "(vlax-curve-getPointAtDist  (vlax-ename->vla-object  (handent " & Chr(34) & oEnt.Handle & Chr(34) & " )  )"  & " 1.5))" & vbCr
   .SendCommand strCom
   GetPointSpline = .GetVariable("USERR1")
End With
End Function
Result:
; error: AutoCAD variable setting rejected: "USERR1" (-5.97251 -11.4573 0.0)
How can i get variable value "USERR1" (-5.97251 -11.4573 0.0) in autocad vba?
Edited by SLW210
Code Tags
You can not save to USERRx as its a real expects a single number you can save to users1 a string, I would run the lisp as a library function just load and run then get the returned point convert to a VBA variable trying to find example. This way could have a library of the vlax curve stuff.
Almost forgot, you need to rewrite the code
; pt=(-5.97251 -11.4573 0.0)
(setq ans (strcat (rtos (car pt) 2 2) " " (rtos (cadr pt) 2 2) "" (rtos (caddr pt) 2 2)))
   .SendCommand strCom
I just know a little bit lisp code , So How to I get value return string from .Sendcommand strCom.
Thank you.BIGAL
Edited by SLW210
Code Tags
Start by breaking down into a 2 step process
Not tested
strCom = "(setvar " & Chr(34) & "USERS1" & Chr(34) & Chr(32) & vbCr)"
.SendCommand strCom
strcom "(setq pt (vlax-curve-getPointAtDist (vlax-ename->vla-object (handent " & Chr(34) & oEnt.Handle & Chr(34) & " ) )" & " 1.5)))" & vbCr
.SendCommand strCom
