Results 1 to 5 of 5
Thread: Water Line
    Junior Member
    Land Desktop 2004
    Mar 2015
    22
    Default Water Line
    So, I taught myself how to write a line with the letter "w" for waterline.
    I don't like how it looks. the "w" sits between every dash.
    Is there a way to bring the "w" in at every other dash, or every third dash?
    Thank you
    *WATER_LINE,WATER line ----W----W----W----W----W----W--
    A,.5,-.2,["W",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.25
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,792
    Yes is the answer need to add the extra lines then the W I don't have one but that is the way to do it.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,154
    When you are dealing with linetype definitions, it helps to have an image in your mind of the old fashioned pen plotters. A positive length is drawn with the pen down on the paper, and a negative length is drawn with the pen up which produces a gap.
    So looking at your linetype definition, you need to add "0.5,-0.45" which would produce an extra dash. You could add as many as you liked, and at which end you wanted.
    A,.5,-.45,.5,-.2,["W.........]-.25,.5,-.45
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,152
    I have moved your thread to the The CUI, Hatches, Linetypes, Scripts & Macros Forum.
    See THIS to add to what eldon has shown.
  5. #5
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    851
    I set ltscale, annoscale, and msltscale all to one so the X and Y offsets are true values so I can get them right the first time.
    To start and end with a half dash so the lines look the same on both ends.
    A,.25,-.2,["W",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2,.25
    This one has two dashes at each end and three between W's
    A,.25,-.2,.5,-.2,["W",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2,.5,-.2,.25
    The half dash at each end adds one between W's so you cannot do an even number of dashes between W's though.
    Layer 0 for ByBlock Block entities, everything else ByLayer. So many issues can be solved with good templates.
  1. Water
    By Attila The Gel in forum AutoCAD General
    Last Post: 25th Jul 2010, 03:52 pm
  2. what should I use to draw water?
    By supernoke in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Apr 2010, 02:23 pm
  3. water line layout
    By jtb503 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Mar 2009, 05:05 pm
  4. Designing of water supply and sewage water pipelines in 3D
    By gicasdd in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Sep 2008, 08:53 am
