Results 1 to 3 of 3
    Senior Member
    AutoCAD 2010
    Dec 2010
    Brussels
    112
    Default generate visibility states
    Is there a way for LISP to generate visibility states?
    If yes... then maybe import the block definition, from dwg file (1 file = 1 block)
    I'm combining lots of blocks into fewer blocks, by category.
    (Google completely ignores the "generate" or "create" search term. I find lots of "set dynamic state" links)
    Senior Member
    Stefan BMR's Computer Details
    Win10
    Structural
    AutoCAD 2019
    Sep 2011
    Baia Mare, Romania
    393
    Not sure exactly how it is supposed to work, or what objects do you want to add to a specific visibility, so try this one, as an example.
    First, insert some static blocks into your drawing.
    Then run the lisp and select the blocks. The lisp will create a new block with Vis States, each one representing one of the selected blocks.
    Here it is, quick and dirty.
    Code:
    ;Create Dynamic Block w/ visibility
    ;Stefan M. 10.08.2018
    (defun c:test ( / msg ss nb i bn lst)
      (if
        (and
          (setq ss (ssget '((0 . "INSERT"))))
          (setq nb (getstring "\nSpecify new block name: "))
          (setq msg "\nInvalid name")
          (snvalid nb)
          (setq msg "\nBlock already defined")
          (not (tblsearch "block" nb))
            (setq bn (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))))
            (if (not (member bn lst))
              (setq lst (cons bn lst))
          (command "_bedit" nb)
          (command "_bparameter" "_visibility" '(0.0 -10 0.0) "1")
          (foreach x lst
            (command "_bvstate" "_new" x "_hide")
            (entmakex (list '(0 . "INSERT") (cons 2 x) '(10 0.0 0.0 0.0)))
          (command "_bvstate" "_set" (car lst))
          (command "_bvstate" "_delete" "VisibilityState0")
          (command "_bsave")
          (command "_bclose")
          (command "_insert" nb "_s" 1.0 "_r" 0.0)
          (while (> (getvar 'cmdactive) 0)
            (command pause)
        (if msg (alert msg))
    PS. The lisp is working on my computer. However, it might need some checking routines. For example, I can imagine, if you use a non-english autocad, the default name of the first visibility state might not be "VisibilityState0", so my lisp could fail trying to delete it.
    Senior Member
    AutoCAD 2010
    Dec 2010
    Brussels
    112
    Thanks. Looks exactly like what I need.
  1. Using visibility states
    By Jman in forum Blocks, Images, Models & Materials
    Last Post: 17th Nov 2017, 06:57 pm
  2. Visibility and flip states
    By sammyteacake in forum AutoCAD Beginners' Area
    Last Post: 28th Mar 2012, 04:22 pm
  3. Visibility States
    By eyde in forum AutoCAD Drawing Management & Output
    Last Post: 7th Nov 2011, 10:08 pm
  4. visibility states
    By mnewton in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2011, 06:59 pm
  5. Visibility States
    By chelsea1307 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2010, 09:52 pm
