matramurena Posted January 22, 2007 Share Posted January 22, 2007 Hello, About 50% of the time when I open the dashboard it appears but is totally blank. There are no icons on it, however on mouseover it says which icon should be on that place and when you click it it does the function.... I have no idea how this is possible. ANother prob I sometimes have is with the Materials-tab. Here once in a while a material I made appears to look totally black in the example-window but in the drawing it works fine. Anyone had this probs before? Quote Link to comment Share on other sites More sharing options...
charlie72 Posted August 26, 2008 Share Posted August 26, 2008 Hi Im just wondering if you ever got the dashboard problem sorted. I seem to have the same problem. Quote Link to comment Share on other sites More sharing options...
charlie72 Posted August 26, 2008 Share Posted August 26, 2008 After fiddling about with it is seems that you have to riht click over the dashboard bar then select control panel and pick the various items that you want. Quote Link to comment Share on other sites More sharing options...
papagyi Posted August 26, 2008 Share Posted August 26, 2008 After fiddling about with it is seems that you have to riht click over the dashboard bar then select control panel and pick the various items that you want.And then you should save your work space and you can easy get your favourite setting any time. Quote Link to comment Share on other sites More sharing options...
charlie72 Posted September 1, 2008 Share Posted September 1, 2008 Thanks for the tip papagyi. Quote Link to comment Share on other sites More sharing options...
