Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Forum Newbie
    AutoCAD 2007
    Jan 2007
    Ohio, USA
    7
    Thank you all very much for all of your advice. I don't really have much experience using the loft command, so I'll be sure to give it a go and then say how it worked out.
    One other side question: I'm going to apply a material to these ducts. I was wondering if there is a way to attach something that looks like duct seams and creases in the metal by using an image map and a bump map or something. Does anyone know where I could find some images to use? Or how would I go about making them, as I have next to no experience with bump mapping. Thanks again!
  2. #12
    Forum Newbie
    AutoCAD 2007
    Jan 2007
    Ohio, USA
    7
    Yep, works like a charm. Excellent. Thanks everyone! Anyone know how to make 24x24 ceiling diffusers as well?
  3. #13
    Super Member yedan's Avatar
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    as for bump mapping you can create seam looking lines on a square material map and use that applied to you model, with the correct mapping and placement of the lines you can make it look as tho it is seamed without actually needing a bump map as such, when i was creating skins for mapping space ship models for game modifications i always the Paint shop pro and using the bevel tools you can make a line have the appearance of a raised or lowered section which if done to a straight line would give the apparence of a joint line or seam
  4. #14
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    Quote Originally Posted by blood86x View Post
    you're just gonna have to dive right in man... pick up a book on 3D or something. that's the best way...
    or maybe look for a program called Autodesk Building Systems - it's a total 3D package for designing things like HVAC, Plumbing, and Piping - does everything for you, all you do is tell it what you want.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  5. #15
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    this was asked again this week - bookmarked for FAQ
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  6. #16
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Quote Originally Posted by Strix View Post
    How did you get this assignment Strix?
    Looks like you are doing a great job and working hard.
  7. #17
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    I think it was coz I spend WAY too much time loitering about the forum SLW
  8. #18
    Forum Newbie
    AutoCAD 2012
    Sep 2012
    1
    hello everyone. i am really new to all this especially the 3d parts and i am needed to draw some square to rounds that are tilted and kind of crazy really. just need to se if there is a site or something that can point me in the direction of step by step on this. Any help would be greatly appreciated!
  9. #19
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Loft.
    Attach your attempt here.
    If you want to unfold it - you should be using Autodesk Inventor.
    Students can get Inventor free here http://www.autodesk.com/edcommunity
  1. Inverse Square Light
    By Tomahawkjam in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Feb 2006, 07:51 pm
  2. Square to Round
    By J-LYLE in forum AutoCAD Drawing Management & Output
    Last Post: 10th Mar 2005, 09:06 pm
  3. Viewport not square
    By ziemerd in forum AutoCAD Drawing Management & Output
    Last Post: 26th Oct 2004, 01:48 pm
  4. Ductwork / Pipework Schematics
    By Qwest in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2004, 04:32 pm
  5. ...Do I draw object with round AND square vertexes?
    By lekkaut in forum AutoCAD General
    Last Post: 7th Mar 2004, 01:09 pm
