ajs Posted November 1, 2007 Share Posted November 1, 2007 I'm writing a small script and I was wondering if there is a command line version of cancel? (Which I can currently access by using the "Esc" key Thank you Quote Link to comment Share on other sites More sharing options...
CADgirl Posted November 1, 2007 Share Posted November 1, 2007 I don't think there is. You can look up a list of all the commands- go to Tools, Customize, Edit Program Parameters. Quote Link to comment Share on other sites More sharing options...
Kate M Posted November 1, 2007 Share Posted November 1, 2007 ^C^C works in macros; I'm not sure about scripts. Quote Link to comment Share on other sites More sharing options...
dumfatnhappy Posted November 1, 2007 Share Posted November 1, 2007 ^C^C works in macros; I'm not sure about scripts. it works in scripts, the reason for (2) ^C is in case you are in a transparent command (call it insurance) Quote Link to comment Share on other sites More sharing options...
ajs Posted November 2, 2007 Author Share Posted November 2, 2007 Thanks for the good advice:) ---AJ Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted March 10, 2008 Share Posted March 10, 2008 I'm writing a small script and I was wondering if there is a command line version of cancel? You can put (command) in your script file to cancel a command. 1 Quote Link to comment Share on other sites More sharing options...
MichaelEBeall Posted November 18, 2012 Share Posted November 18, 2012 Bingo! The (command) at the end of the script did the trick! I'm updating The AutoCAD Workbench and I needed an answer to this question. Thank you! Quote Link to comment Share on other sites More sharing options...
