Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Full Member
    AutoCAD 2008
    Nov 2007
    46
    Default "explode" (distance) parts - solids
    Hi, with word EXPLODE i don't meen the explode command. To brake appart part (block or solid).
    But i would like to "explode" all parts (blocks or solids) appart and move eatch of them some disstance appart from enother for presentation purposes and then join them together if i would like again with a command to return to original place.
    Any way to do that automaticly with a command in Autocad 2008?
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    I use only AutoCAD 2006 and there is no tool for "explode" as you said. I don't think they implemented it in 2008... :-(
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    Try Iinventor?
    Or Alibre
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
    Full Member
    AutoCAD 2008
    Nov 2007
    46
    Quote Originally Posted by Raggi_Thor View Post
    Try Iinventor?
    Or Alibre
    Problem is, that i have current project made in Autocad 2008. And its going to pruduction soon.
    But i will have to learn some real 3d modelers beacose autocad yust have many restrictions.
  5. #5
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    Maybe you can search for some add ons.
    I bet someone has written a lisp or vba routine that moves all blocks and solids away from a given point with a given factor.
  6. #6
    Mechanical
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    3,577
    It is a bit more difficult: if you wish the program to detect itself the directions to move the solids/blocks you must have something like constrains. But AutoCAd doesn't work with constrains -so the "manual way" is the only one I can see for the moment.
  7. #7
    Super Member riga's Avatar
    AutoCAD 2007
    May 2007
    Switzerland
    723
    I was thinking it should be possible to obtain a similar effect using dynamic blocks properties and the polar strech action, but I'm a real newbie in the use of dynamic blocks and so I'm not sure what I have in mind is feasible. Maybe members more into dynamic blocks can give their opinion on this
    HAVE A NICE DAY
  8. #8
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Quote Originally Posted by riga View Post
    Good idea riga. This could probably be done with Visibility parameters and/or Lookups. There is a recent post in the General section with a location for some video tutorials on Dynamic Blocks.
    Dynamic Block Help
  9. #9
    AutoCAD 2007
    May 2007
    Switzerland
    723
    Quote Originally Posted by SLW210 View Post
    Dynamic Block Help
    I tought it was possible to do ot with polar strech action, but for a presentation the idea of visibility/lookups parameters could work better and it's easyer to do (depending on the numbers of objects that needs to be "exploded").
    At this point I think it will be usefull to have a couple of images that represent which is the effect sloman needs to obtain, so that we can suggest at least a good enough work around
    HAVE A NICE DAY
  10. #10
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    I do this here sometimes and since all we have is basic AutoCAD I do it with layers. I put almost everything on its own layer, or group them where is makes the best sense and then in a layout I end up with many viewports with all the layers frozen except just one. This has obvious limitations but it gets the job done.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Convert "body" to "Solid"
    By powerdog in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2007, 04:11 pm
  2. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  3. "Explode" 3D object into flat cutting pattern shap
    By VBAjedi in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2006, 11:24 am
  4. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
  5. Why have solids started "bleeding"?
    By Cadastrophic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Mar 2004, 11:09 pm
