Thanks for that, certainly works. I'll remember the bcount command for using a latter version.
I will give you 2 of mine. BCOUNT has limited functionality, though I still use it some. Mine have a few more options.
Hello,
sorry to come so late about this topic but how do you use the BlockQuantity and the BlockList?
Thanks!!
You could send me $1,000,000 US or read this.....How to Use LISP Routines
Thanks, SLW210... In fact when I enter blockquantity or blockslist, it says "blockquantity Unknown command "BLOCKQUANTITY". Press F1 for help" or "blockslist Unknown command "BLOCKSLIST". Press F1 for help."... That's why I'm asking...
PS: I already loaded the 2 files...![]()
Are they in a folder in your support file search path? _OPTIONS>Files>Support File Search path make sure you have the path included. They both work fine here. I just checked them. Make sure your spelling is correct.
Done!!... Thanks very much, SLW210!!!
I am a new member of CADTutor Forum. I can not download the files you attached. Pls help! Thanks.[/quote]
Post: Lisp for calculating the sum of blocks
Forum: AutoCAD Drawing Management & Output
Posted by: SLW210
Original Content:I will give you 2 of mine. BCOUNT has limited functionality, though I still use it some. Mine have a few more options.
I have no problem down loading them.
Must be blocked on your end.
What message do you get?
