CADgirl Posted March 10, 2008 Share Posted March 10, 2008 This message comes up whenever I open this drawing. We got the drawing from the architect so it has something to do with them. I was just wondering if there was any way to get rid of it. It's kind of annoying. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 10, 2008 Share Posted March 10, 2008 You could see if you can install the Object Enablers. Or _PROXYNOTICE = 0 Quote Link to comment Share on other sites More sharing options...
CADgirl Posted March 10, 2008 Author Share Posted March 10, 2008 Wonderful! It worked. Thank you so much. Quote Link to comment Share on other sites More sharing options...
RingSteel Posted March 10, 2008 Share Posted March 10, 2008 Wow! Thanks SLW. I thought I just had to live with that annoyance. Quote Link to comment Share on other sites More sharing options...
kennykramer Posted December 18, 2008 Share Posted December 18, 2008 where can I get these enablers and how do I know which enablers I need thanks:oops: Quote Link to comment Share on other sites More sharing options...
A1DWG Posted December 18, 2008 Share Posted December 18, 2008 The enablers depend on the software and add ons used to create the drawing in the first place. They are listed in the message you have now managed to turn off. If you scroll through the error mesage the software package should be identified, along with another important piece of information - the number of proxy images with graphics - hopefully none, otherwise you haven't all the drawing. If it only has proxyimages without graphics you are (usually) OK. I have only found the add-ons are ones you have to purchase. ADT / Schedule software etc. Quote Link to comment Share on other sites More sharing options...
kennykramer Posted December 18, 2008 Share Posted December 18, 2008 It Seams Like They Are Created By Arx Any Ideas?? Quote Link to comment Share on other sites More sharing options...
A1DWG Posted December 18, 2008 Share Posted December 18, 2008 Can you copy the text from the proxy message or post a screen print so we can see? Quote Link to comment Share on other sites More sharing options...
kennykramer Posted December 18, 2008 Share Posted December 18, 2008 DBX IS I GUESS WHAT CREATED THESE OBJECTS, I AM USING ACAD 2000i AND THE DRAWING WAS MADE AND SAVED BACK TO 2000 ???? HOW CAN I POST THE BOX HERE SO YOU CAN SEE?? SURE APPRECIATE THE HELP BIG TIME:? Quote Link to comment Share on other sites More sharing options...
A1DWG Posted December 18, 2008 Share Posted December 18, 2008 Can you copy and paste the text from the proxy message? If not try Print Screen and post the image. Try looking on http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2753223&linkID=9240818 I found this on the links at the bottom of the page. Quote Link to comment Share on other sites More sharing options...
kennykramer Posted December 18, 2008 Share Posted December 18, 2008 The Last Command Created Proxy Objects And Proxy Entities To Represent Origional Objects And Entities Whose Parent Arx Application Are Currently Not Loaded These Proxy Objects And Proxy Entities May Yeld Unexpected Results Missing Application Object Dbx Class Total Proxy 17 # Of Objects (no Graphic) 17 I Couldnt Send The Box I Tried:? Quote Link to comment Share on other sites More sharing options...
kennykramer Posted December 18, 2008 Share Posted December 18, 2008 :?the Last Command Created Proxy Objects And Proxy Entities To Represent Origional Object And Entities Whose Parent Arx Application Are Currently Not Loaded Those Proxy Objects And Entities May Yeld Unexpected Results Missing Application Object Dbx Classes Total Proxy 17 # Of Objects (no Graphic) 17 Couldnt Post The Box Quote Link to comment Share on other sites More sharing options...
A1DWG Posted December 18, 2008 Share Posted December 18, 2008 Not too sure, if someone else could help, but I think its a database / data extraction. Try the link previously posted to suit you version of CAD. Quote Link to comment Share on other sites More sharing options...
clydemit Posted June 2, 2011 Share Posted June 2, 2011 I know i am late but here you go: I had a recent autocad 2012 tutor come and help us with errors we have been having the proxy info we get is because our files were exported from programs like solidworks and microstation into .dwg so this export has to drop infomation which makes the drawing look for the missing files which gives you the error. Quote Link to comment Share on other sites More sharing options...
