PatFES Posted May 1, 2008 Share Posted May 1, 2008 I just installed AutoCAD 2009 and the mouse wheel pans up and down instead of zooming in and out. It will zoom in and out if I hold the shift or ctrl button down and roll the wheel, but otherwise just pans. I would like to change this to (what has been the default on all my other machines) zoom in and out with the wheel without hitting shift. Any ideas? Quote Link to comment Share on other sites More sharing options...
LCE Posted May 1, 2008 Share Posted May 1, 2008 Scroll to the bottom of this page and check the similar threads. If none of the suggestions help then post back. Out of the box though, this isn't software as I have installed it on multiple machines and works fine on all. Quote Link to comment Share on other sites More sharing options...
PatFES Posted May 1, 2008 Author Share Posted May 1, 2008 I have played with all the mouse settings, however i don't have a mouse icon in my toobar like other users. I have also tried different mouse drivers but nothing has worked yet. Quote Link to comment Share on other sites More sharing options...
LCE Posted May 1, 2008 Share Posted May 1, 2008 have you tested with a different mouse? Quote Link to comment Share on other sites More sharing options...
PatFES Posted May 1, 2008 Author Share Posted May 1, 2008 yes just tried a different mouse, same problem. I also put ACAD 2002 on this machine to see if it was a 2009 setting, but it was the same in 2002(just panning up and down) Quote Link to comment Share on other sites More sharing options...
AVITWeb Posted May 1, 2008 Share Posted May 1, 2008 Right now, the only thing I can think of is in TOOLS>OPTIONS>SYSTEM, check to see that the drop down box under CURRENT SYSTEM POINTING DEVICE is not set to TABLET or anything other than CURRENT SYSTEM POINTING DEVICE. Unless, within window's mouse driver area (under control panel) there is a setting telling it do something with this. Quote Link to comment Share on other sites More sharing options...
PatFES Posted May 1, 2008 Author Share Posted May 1, 2008 Its a miracle!!! Thank You Quote Link to comment Share on other sites More sharing options...
AVITWeb Posted May 3, 2008 Share Posted May 3, 2008 Its a miracle!!! Thank You You are welcome...which one was it? Quote Link to comment Share on other sites More sharing options...
PatFES Posted May 5, 2008 Author Share Posted May 5, 2008 I went through control panel to the mouse settings and changed it to use enable program specific settings and put ACAD 2009 on that list. Well that worked last week but came into the office this morning and its back to panning instead of zooming and the settings are the same as last week......... i think my comp is just messing with me.... any other ideas? Quote Link to comment Share on other sites More sharing options...
AVITWeb Posted May 6, 2008 Share Posted May 6, 2008 I went through control panel to the mouse settings and changed it to use enable program specific settings and put ACAD 2009 on that list. Well that worked last week but came into the office this morning and its back to panning instead of zooming and the settings are the same as last week......... i think my comp is just messing with me.... any other ideas? What kind of mouse are you using?? Microsoft, Logitech, etc? Quote Link to comment Share on other sites More sharing options...
Kimba Posted July 29, 2008 Share Posted July 29, 2008 hi PatFES, I'm having the same problem. We've tried all things here. I will be getting my computer rebuilt in September and hope that fixes things. For a quick fix, I save my drawing, close and reopen. It will last for a little while and I'll have to do it again. It's a quick fix for the time being. Quote Link to comment Share on other sites More sharing options...
5881 Posted March 26, 2009 Share Posted March 26, 2009 I had a trial version of 2009 on my computer and my mouse wheel wasn't doing anything. This worked for me. Make sure that under the control panel setting for the mouse, the wheel button is set to "middle mouse button". Then go to autoCAD and type in "mbuttonpan" and set that to 1 even if it was already 1. Hope that helps. Quote Link to comment Share on other sites More sharing options...
