motee-z Posted June 12, 2008 Share Posted June 12, 2008 Hello to all can any one help to draw chainage for equal distance on a polyline as in attached jpg Quote Link to comment Share on other sites More sharing options...
CarlB Posted June 13, 2008 Share Posted June 13, 2008 I believe this has been discussed a few times and routine(s) have been posted. Try searching for "stationing" which is the U.S. equivalent to "chainage". Quote Link to comment Share on other sites More sharing options...
jason tay Posted June 13, 2008 Share Posted June 13, 2008 Hi, you can use block, create a line in block then use measure command,type block, block name and create the chainage line base on the measurement you want. hope can help :_) Quote Link to comment Share on other sites More sharing options...
CarlB Posted June 13, 2008 Share Posted June 13, 2008 Maybe this one -? http://www.cadtutor.net/forum/showthread.php?t=3876 or, DC_Chains at http://afralisp.net/lisp/dctools.htm Quote Link to comment Share on other sites More sharing options...
fixo Posted June 13, 2008 Share Posted June 13, 2008 (edited) I'm crazy busy and can't to rewrite it to your exact needs but hope this will get you started (defun div-error (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ "Error!") (princ msg) ) (while (> (getvar "cmdactive") 0) (command)) ;;; (command "._undo" "_end") ;;; (command "._u") (setq *error* olderror) (princ) ) (defun divplus (len segm / num lst) (setq num (fix (/ len segm))) (setq cnt 0) (while (<= cnt num) (setq tmp (* cnt segm)) (setq lst (append lst (list tmp))) (setq cnt (1+ cnt)) ) (setq delta (- len (last lst))) (if (not (zerop delta)) (setq lst (append lst (list (+ (last lst) delta)))) lst ) ) (defun divminus (len segm / lst) (while (>= len 0.) (setq lst (append lst (list len))) (setq len (- len segm)) ) (if (not (zerop (last lst))) (setq lst (append lst (list 0.0))) ) lst ) (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt ) ) ) ) (defun answer (quest / wshl ans) (or (vl-load-com)) (setq wshl (vlax-get-or-create-object "WScript.Shell")) (setq ans (vlax-invoke-method wshl 'Popup quest 7 "Answer This Question:" vlax-vbYesNo)) (vlax-release-object wshl) (cond ((= ans 6) (setq opt T)) ((= ans 7) (setq opt nil)) ) opt ) (defun make-station (bname / acsp adoc atprom attag at_obj blk_obj hgt lay line_obj sfar ) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) (if (and (= (getvar "tilemode") 0) (= (getvar "cvport") 1) ) (setq acsp (vla-get-paperspace adoc)) (setq acsp (vla-get-modelspace adoc)) ) (vla-startundomark adoc) (if (not (tblsearch "block" bname)) (progn (setq attag "NUMBER" ;(strcase (getstring "\nAttribute tag : \n")) atprom "NUMBER" ;(strcase (getstring T "\nAttribute prompt : \n")) hgt 1.0 ;(getreal "\nAttribute text height : \n") ) (setq lay (getvar "clayer")) (setvar "clayer" "0") (setvar "attreq" 0) (setq line_obj (vlax-invoke acsp 'Addline '(0. 0. 0.) (list 0. (* hgt 12.) 0.))) (vla-put-color line_obj acyellow) (setq blk_obj (vla-add (vla-get-blocks adoc) (vlax-3d-point '(0. 0. 0.)) bname) sfar (vlax-safearray-fill (vlax-make-safearray vlax-vbObject '(0 . 0)) (list line_obj) ) ) (vla-copyobjects adoc sfar blk_obj) ;;; RetVal = object.AddAttribute(Height, Mode, Prompt, InsertionPoint, Tag, Value) (setq at_obj (vla-addattribute blk_obj hgt acattributemodeverify atprom (vlax-3d-point '(-0.5 1. 0.)) attag "0+00") ) ;;; (vla-put-alignment at_obj acAlignmentBottomCenter) ;;; (vla-put-textalignmentpoint ;;; at_obj ;;; (vlax-3d-point '(0. 1. 0.)) ;;; ) (vla-put-rotation at_obj (/ pi 2)) (vlax-release-object blk_obj) ) (progn (princ "\n\t >> Block does already exist!\n") (princ))) (if (tblsearch "block" bname) T (progn (alert "Impossible to add block"))) (setvar "attreq" 1) (setvar "clayer" lay) (vl-catch-all-apply (function (lambda ()(vla-delete line_obj)))) (vla-regen adoc acactiveviewport) (vla-endundomark adoc) (vlax-release-object acsp) (vlax-release-object adoc) (princ) ) (or (vl-load-com)) (defun C:d10 (/ *error* acsp adoc appd div-error len num olderror pl pt pt_list step util ) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (or appd (setq appd (vla-get-application adoc))) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc) ) ) ) (or util (setq util (vla-get-utility adoc))) ;;; (command "._undo" "_end") ;;; (command "._undo" "_mark") (setq olderror *error*) (setq *error* div-error) ;;; (setq bname (getstring T "\nStation block name : \n")) ;;; (make-station bname) (if (not (tblsearch "block" "Station")) (make-station "Station")) (vla-getentity util 'pl 'pt "\nSelect line NEAR OF POINT TO START measure: >>> \n" ) (if pl (progn (setq step (getreal "\nEnter step for stationing <10> : \n")) (setq opt (answer "Rotate text perpendicularly to pline?")) (if (not step)(setq step 10.)) (setq len (vlax-curve-getdistatparam pl (vlax-curve-getendparam pl) ) ) (if (< (distance (vlax-safearray->list pt) (vlax-curve-getstartpoint pl) ) (distance (vlax-safearray->list pt) (vlax-curve-getendpoint pl) ) ) (setq pt_list (divplus len step)) (setq pt_list (divminus len step)) ) (setq pt_list (vl-remove-if (function not) (mapcar (function (lambda (x) (vlax-curve-getpointatdist pl x) ) ) pt_list ) ) ) (setq num 0) ;;; (setq num (getint "\nEnter initial station number\n")) (mapcar (function (lambda (x / dr ang att_list at blk_obj) (progn (setq ang (alg-ang pl x) ang (cond ((< (/ pi 2) ang (* pi 1.5)) (+ pi ang)) (T ang) ) ) (setq blk_obj (vlax-invoke acsp 'Insertblock x "Station" 1 1 1 ang) ) (setq att_list (vlax-invoke blk_obj 'Getattributes)) (foreach at att_list (if (eq (vlax-get at 'Tagstring) "NUMBER") (progn (vlax-put at 'Textstring (if (< num 990.) (strcat "sta: 0+" (rtos num 2 2)) (strcat "sta: " (itoa (fix (/ num 1000.)))[color=red];<--- changes 1200. on num (typo)[/color] "+" (rtos (- num (* (fix (/ num 1000.)) 1000)) 2 2) ) )) (if (not opt) (vlax-put at 'Rotation 0)) (vla-update at) ) ) ) (vla-update blk_obj) (vlax-release-object blk_obj) (setq num (+ num step)) ) ) ) pt_list ) (if (not (vlax-object-released-p pl)) (vlax-release-object pl) ) ) (princ "\nNothing selected try again\n") ) (vla-zoomextents appd) (vla-regen adoc acactiveviewport) (setq *error* olderror div-error nil ) ;;; (command "._undo" "_end") (princ) ) (prompt "\n") (prompt "\n *** Type D10 to execute *** \n") (princ) ~'J'~ Edited January 16, 2012 by fixo typo has been found Quote Link to comment Share on other sites More sharing options...
motee-z Posted June 13, 2008 Author Share Posted June 13, 2008 thank you fixo you only i want to explain my idea your routin very great but when measuring reach to one thousnd there is mistake here so total length not correct please modify it thanks Quote Link to comment Share on other sites More sharing options...
fixo Posted June 13, 2008 Share Posted June 13, 2008 thank you fixo you only i want to explain my ideayour routin very great but when measuring reach to one thousnd there is mistake here so total length not correct please modify it thanks Sorry, I'm busy at the moment Perhaps, later I can do it ~'J'~ Quote Link to comment Share on other sites More sharing options...
fixo Posted June 13, 2008 Share Posted June 13, 2008 Forgot to say about I wan't to work with your picture Upload here your real working drawing that would be much easier to help you ~'J'~ Quote Link to comment Share on other sites More sharing options...
motee-z Posted June 15, 2008 Author Share Posted June 15, 2008 thank you fixo for your help thanks to carlB for the link it solved what i need exactly Quote Link to comment Share on other sites More sharing options...
Cymro Posted May 21, 2010 Share Posted May 21, 2010 Thanks for this excellent routine. One thing if anyone could help me, what do I need to change in the routine to rotate the text of the chainages by 180 degrees. many thanks Cymro Quote Link to comment Share on other sites More sharing options...
Cymro Posted December 9, 2010 Share Posted December 9, 2010 Hi, me again. I am using the above routine quite often now, I have tried and tried to change the code to rotate the text by 180 degrees without success. If there is anyone out there who can do it quickly, it would be greatly appreciated. It takes a long time to manually rotate text. many thanks Cymro Quote Link to comment Share on other sites More sharing options...
Michaels Posted December 9, 2010 Share Posted December 9, 2010 This part including the rotation text for the Att. text tags . (vla-put-rotation at_obj (/ pi 2)); <-- this is 90 degree to make it 180. replace the (/ pi 2) to pi And when the routine asks you for rotation, hit NO to let the routine gets your angular degree that you added to the routine. Quote Link to comment Share on other sites More sharing options...
Cymro Posted December 10, 2010 Share Posted December 10, 2010 Hi thanks for getting back, I may not have explained myself fully. What I would like is when asked for text perpendicular to pline the output is rotated 180 to what is produced at present. The left is what the code produces after confirming text rotated perpendicular to line, the right is the output that i would like. Hope someone can help many thanks Stephen Quote Link to comment Share on other sites More sharing options...
irneb Posted December 14, 2010 Share Posted December 14, 2010 It seems you want to "reverse" the polyline first. There are a few things which can do such, as a sample see alanjt's over here. Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 14, 2010 Share Posted December 14, 2010 This may also be of interest. Quote Link to comment Share on other sites More sharing options...
Tomica Posted July 28, 2011 Share Posted July 28, 2011 Hi fixo your lsp is great, but can chainage continue to for example 30 000 meters. Because when it com to 1+990 it start's again from 0+000,00, Can you help me Fixo with this so that the chainage go to 30+000,00 or more. Quote Link to comment Share on other sites More sharing options...
cios106 Posted January 16, 2012 Share Posted January 16, 2012 Hi all. Im always using "defun c:" type lisps. So i could not run Fixo's lisp, how can i run it ? What should i type to use it ? Many many thanks. Quote Link to comment Share on other sites More sharing options...
irneb Posted January 16, 2012 Share Posted January 16, 2012 You could try his c:d10 defun, though it uses a block named Station. You could edit it I suppose. Quote Link to comment Share on other sites More sharing options...
fixo Posted January 16, 2012 Share Posted January 16, 2012 Hi fixo your lsp is great, but can chainage continue to for example 30 000 meters.Because when it com to 1+990 it start's again from 0+000,00, Can you help me Fixo with this so that the chainage go to 30+000,00 or more. I've found a typo in this routine, try edited code from post #5 again And also it would be goog to see your stationing format sou you could be want to attach the picture of small piece of your polyline, to be frankly it's looking ugly (this one is from my very oldies) Think I'll back to it to rewrite some parts in there Quote Link to comment Share on other sites More sharing options...
m4rdy Posted January 17, 2012 Share Posted January 17, 2012 (defun answer (quest / wshl ans) (or (vl-load-com)) (setq wshl (vlax-get-or-create-object "WScript.Shell")) (setq ans (vlax-invoke-method wshl 'Popup quest 7 "Answer This Question:" vlax-vbYesNo)) (vlax-release-object wshl) (cond ((= ans 6) (setq opt T)) ((= ans 7) (setq opt nil))) opt ) ................... (setq opt (answer "Rotate text perpendicularly to pline?")) ................... Hai Oleg, This function is new to me. I like it. And I'll keep in my lib. Thank you. mardi Quote Link to comment Share on other sites More sharing options...
