NeilGTi85 Posted June 16, 2008 Share Posted June 16, 2008 Hello all, I am currently working on a project where i am trying to find out the floor area of a building. The floor area is hatched, normally when I type 'list' it comes up with the area but not this time!!?? I have had this problem before and can not figure out what it is, any idea's?? Cheers Neil Quote Link to comment Share on other sites More sharing options...
NeilGTi85 Posted June 16, 2008 Author Share Posted June 16, 2008 Some more info may be needed- Acad 08 LT, building layout with rooms in polylines hatched. Help... Neil Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 16, 2008 Share Posted June 16, 2008 Is the Hatch contained in an xref, or maybe a block? When you check the Hatch Properties, what does it say? Quote Link to comment Share on other sites More sharing options...
f700es Posted June 16, 2008 Share Posted June 16, 2008 What does the "properties" panel say? With the properties panel open you should see the area. Good luck Quote Link to comment Share on other sites More sharing options...
profcad Posted June 16, 2008 Share Posted June 16, 2008 It sounds like the hatch pattern was created with an older version of AutoCAD that didn't support area in hatch objects. Type CONVERT and see if that updates the object. If that doesn't work, double click on the hatch and check the option to recreate the boundary. Delete the old hatch and then rehatch it. Quote Link to comment Share on other sites More sharing options...
edoll Posted March 18, 2013 Share Posted March 18, 2013 I have a CAD file that was produced from Illustrator (I know, probably not a good idea). It is a file of an entire university campus where I am wanting to find the area of impervious surfaces. So The DWG Works great in CAD and it is one large hatch with a boundary - not a bunch of individual hatches. When I select it in CAD, the area does not show up in the properties dialogue. Is this because the command I am asking CAD to much of a task...I have every campus path and parking lot on it aka there are probably half a million lines. Any insight as how to get an area from illustrator Dwg in autocad would be greatly appreciated. I am using 2013 LT thanks, Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 18, 2013 Share Posted March 18, 2013 And what if any answer is returned using the Area command itself? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 18, 2013 Share Posted March 18, 2013 What happens when you select the hatch, right-click and choose "Generate Boundary"? Can you use this as a workaround at least to find the area? Quote Link to comment Share on other sites More sharing options...
welldriller Posted March 19, 2013 Share Posted March 19, 2013 here comes dum-dum again would it be possible to erase the hatch - get the area - than use the redo command ???? Quote Link to comment Share on other sites More sharing options...
