anuj Posted June 18, 2008 Posted June 18, 2008 Hi, Today only I registered myself with CT, though I used to visit CT as a non-member. I am using LDD 2007 and after creating surface I would like to label spot elevation with arrow and some text next to it for instance; from surface I got spot elevation=5215.60, but i would like to display it as 15.60FL, where FL stands for flowline similarly I would be adding text like EX, BC, HP, LP. At present I do this manually which takes lot of time. thanks in advance Quote
fixo Posted June 20, 2008 Posted June 20, 2008 Hi anuj, and welcome on board! I know nothing about LDD and spots but in the common cases this should helps I hope: ;;lbn.lsp (vl-load-com) (defun C:LabelSpots (/ ls numeric p p1 p2 suffix sz txt z) (setq suffix (getstring T "\nEnter the suffix (or press Enter to set default) <FL> : ")) (if (eq "" suffix) (setq suffix "FL")) (while (setq p1 (getpoint "\nPick node point (or press Enter to Exit): ")) (setq z (caddr p1) sz (rtos z 2 (getvar "lunits")) ls (vl-string->list sz) numeric (vl-list->string (member (nth (- (vl-position 46 ls) 2) ls) ls)) txt (strcat numeric suffix) ) (setq p2 (getpoint p1 "\nSpecify text insertion point: ")) (command "_.qleader" p1 p2 "" (rtos (* (strlen txt) (getvar "textsize")) 2 0) txt "" "") ) (princ) ) (defun C:LBS () (C:LabelSpots) ) (princ "\n\t\t***\tStart command with LabelSpots or with LBS ...\t***") (princ) ~'J'~ Quote
anuj Posted June 20, 2008 Author Posted June 20, 2008 Thanks for the solution. I tried this and works fine when you click on object with Z elevation but it doesnot interpolate. for eg. If I am having two contours say Z elevation=1000 & 1010 respectively when clicked on contours it does the job perfectly....but when i clicked somewhere in between these two it says 0 elevation. What I am looking for is it should give something like 1001 depending upon the where one clicked and display it as 01.00FL I know there is option in LDD but that displays full z elevation but i want just the last two digit upto 2 decimal like it should display 1010 as 10.00FL Quote
fixo Posted June 20, 2008 Posted June 20, 2008 Ah, sorry, my bad I need to rewrite it I see now, you want to retrieve the last two digits before comma and next two digits after See you ~'J'~ Quote
fixo Posted June 20, 2008 Posted June 20, 2008 Try the following one instead ;;lbn.lsp (vl-load-com) (defun C:LabelSpots (/ dz ls lu lup numeric osm p1 p2 suffix sz txt z) (setq lu (getvar "lunits")) (setvar "lunits" 2) (setq lup (getvar "luprec")) (setvar "luprec" 4) (setq dz (getvar "dimzin")) (setvar "dimzin" (setq osm (getvar "osmode")) (setvar "osmode" 1) (setq suffix (getstring T "\nEnter the suffix (or press Enter to set default) <FL> : ")) (if (eq "" suffix) (setq suffix "FL")) (while (setq p1 (getpoint "\nPick node point (or press Enter to Exit): ")) (setq z (caddr p1) sz (rtos z 2 3) ls (reverse (cdr (reverse (vl-string->list sz)))) numeric (vl-list->string (member (nth (- (vl-position 46 ls) 2) ls) ls)) txt (strcat numeric suffix) ) (setq p2 (getpoint p1 "\nSpecify text insertion point: ")) (command "_.qleader" p1 p2 "" (rtos (* (strlen txt) (getvar "textsize")) 2 0) txt "") ) (setvar "osmode" osm) (setvar "lunits" lu) (setvar "luprec" lup) (setvar "dimzin" dz) (princ) ) ;;shortcut: (defun C:LBS () (C:LabelSpots) ) (princ "\n\t\t***\tStart command with LabelSpots or with LBS ...\t***") (princ) ~'J'~ Quote
abidcdm Posted September 26, 2009 Posted September 26, 2009 Hi Dears,Please help to writting a lisp for to daraw a beam elevation beam elevations.Exmaple: Beam top reinforcement addl bar lenth is L/3 and bottom L/4 of clear span.I want a lisp when i will click two point of clear span of beam. it it will divide L/3 and L/4 of total lenth....Many thanks I learned so many thingsfor CADtutor..... Quote
