asos2000 Posted June 22, 2008 Share Posted June 22, 2008 Is there a lisp to get the Center of Gravity for an area and if it is possible getting the CG for several areas I am thinking that, that lisp draws a point in CG and a leader showing the coordinates (or what ever) for pointing to the CG as attached Thanx Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 23, 2008 Share Posted June 23, 2008 Just a footnote the centre of a hatch pattern is not the centre of gravity for the 3 objects shown. If you extrude the objects and subtract the holes then list object you will get the true centre of gravity. this works for concrete tilt panels not sure how then to get centre gravity of 3 panels combined. 1st principles maybe for centroid. Quote Link to comment Share on other sites More sharing options...
fixo Posted June 23, 2008 Share Posted June 23, 2008 Just a footnote the centre of a hatch pattern is not the centre of gravity for the 3 objects shown. If you extrude the objects and subtract the holes then list object you will get the true centre of gravity. this works for concrete tilt panels not sure how then to get centre gravity of 3 panels combined. 1st principles maybe for centroid. Hi, BIGAL Yes, you're right I deleted my worng solution ~'J'~ Quote Link to comment Share on other sites More sharing options...
asos2000 Posted June 25, 2008 Author Share Posted June 25, 2008 thanx fixo thanx BIGAL that what I doing but I am searching for a lisp for saving the time for extrude of each area but i cant get the CG for more than one area, in that case i have to use another program looks like SAP or what ever I want to do every thing in AutoCAD Thans all Quote Link to comment Share on other sites More sharing options...
hendie Posted June 25, 2008 Share Posted June 25, 2008 I wrote a program to place a point on the centroid of a solid or region, it may help CENT http://www.resourcecad.com/programs/ If I remember correctly, if you select more than one solid or region then use MASSPROPS, the centroid it returns is the centroid of all the objects Quote Link to comment Share on other sites More sharing options...
ASMI Posted June 25, 2008 Share Posted June 25, 2008 Draws circles in Centroid points: (defun c:gecen(/ cSet cLst oldSnp) (vl-load-com) (princ "\n<<<Select Regions or 3D-solids >>> ") (if(setq cSet(ssget '((0 . "REGION,3DSOLID")))) (progn (setq cLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) oldSnp(getvar "OSMODE") ); end setq (mapcar 'setvar (list "OSMODE" "CMDECHO")(list 0 0)) (foreach ent cLst (if(vlax-property-available-p ent 'Centroid) (command "_.circle"(vlax-get ent 'Centroid)"50.0") ); end if ); end foreach (mapcar 'setvar (list "OSMODE" "CMDECHO")(list oldSnp 1)) ); end progn ); end if (princ) ); end of c:gecen Quote Link to comment Share on other sites More sharing options...
asos2000 Posted June 26, 2008 Author Share Posted June 26, 2008 Thanx ASMI that lisp is very good Could that lisp get one CG for the selected objects Regards Quote Link to comment Share on other sites More sharing options...
ASMI Posted June 26, 2008 Share Posted June 26, 2008 Ok. (defun c:gecen(/ cSet cLst oldSnp cCen cAre cmLst gCen) (vl-load-com) (princ "\n<<<Select Regions or 3D-solids >>> ") (if(setq cSet(ssget '((0 . "REGION,3DSOLID")))) (progn (setq cLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) oldSnp(getvar "OSMODE") ); end setq (mapcar 'setvar (list "OSMODE" "CMDECHO")(list 0 0)) (foreach ent cLst (if(vlax-property-available-p ent 'Centroid) (progn (setq cCen(vlax-get ent 'Centroid) cAre(vlax-get ent 'Area) cmLst(cons(list cCen cAre)cmLst) ); end setq (command "_.circle" cCen "50.0") ); end progn ); end if ); end foreach (if (and cmLst (/= 1(length cmLst)) ); enad and (progn (setq gCen (list (/ (apply '+ (mapcar '* (mapcar 'caar cmLst)(mapcar 'cadr cmLst))) (apply '+ (mapcar 'cadr cmLst)) ); end / (/ (apply '+ (mapcar '* (mapcar 'cadar cmLst)(mapcar 'cadr cmLst))) (apply '+ (mapcar 'cadr cmLst)) ); end / ); end list ); end setq (command "_.circle" gCen "50") (foreach pt(mapcar 'car cmLst) (command "_.line" pt gCen "") ); end foreach ); end progn ); end if (mapcar 'setvar (list "OSMODE" "CMDECHO")(list oldSnp 1)) ); end progn ); end if (princ) ); end of c:gecen I can add leaders with coordianates, but I dont't know text size you need. Or you want request for text size and circles diameter Quote Link to comment Share on other sites More sharing options...
asos2000 Posted June 26, 2008 Author Share Posted June 26, 2008 what a great lisp refer to the leader and text, can you use the current styles for dim and text. refer to selecting objects, is it posible to select a pline? or click inside the area for avoiding any void in shape (looks like upper shape in attached pic) thanx Quote Link to comment Share on other sites More sharing options...
ASMI Posted June 26, 2008 Share Posted June 26, 2008 Ok. Maybe tomorrow, today there isn't time. Quote Link to comment Share on other sites More sharing options...
ASMI Posted June 26, 2008 Share Posted June 26, 2008 Found a few time. (defun c:gecen(/ actDoc cSet cLst oldSnp cCen cAre cmLst gCen enPt) (vl-load-com) (princ "\n<<<Select Regions or 3D-solids >>> ") (if(setq cSet(ssget '((0 . "REGION,3DSOLID")))) (progn (setq cLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) oldSnp(getvar "OSMODE") ); end setq (mapcar 'setvar (list "OSMODE" "CMDECHO")(list 0 0)) (vla-StartUndoMark (setq actDoc(vla-get-ActiveDocument (vlax-get-acad-object)))) (foreach ent cLst (if(vlax-property-available-p ent 'Centroid) (progn (setq cCen(vlax-get ent 'Centroid) cAre(vlax-get ent 'Area) cmLst(cons(list cCen cAre)cmLst) ); end setq ); end progn ); end if ); end foreach (if (and cmLst (/= 1(length cmLst)) ); enad and (progn (setq gCen (list (/ (apply '+ (mapcar '* (mapcar 'caar cmLst)(mapcar 'cadr cmLst))) (apply '+ (mapcar 'cadr cmLst)) ); end / (/ (apply '+ (mapcar '* (mapcar 'cadar cmLst)(mapcar 'cadr cmLst))) (apply '+ (mapcar 'cadr cmLst)) ); end / ); end list enPt(polar gCen(/ pi 3) (*(getvar "DIMTXT")(getvar "DIMSCALE")5)) ); end setq (command "_.qleader" gCen enPt "" "" "temp_text" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car gCen)2(getvar "DIMDEC")) "\\P" "y="(rtos(cadr gCen)2(getvar "DIMDEC")) ); end strcat ); end vla-put-TextString (foreach pt(mapcar 'car cmLst) (command "_.line" pt gCen "") (setq enPt(polar pt(/ pi 3) (*(getvar "DIMTXT")(getvar "DIMSCALE")5))) (command "_.qleader" pt enPt "" "" "temp_text" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car pt)2 2) "\\P" "y="(rtos(cadr pt)2 2) ); end strcat ); end vla-put-TextString ); end foreach ); end progn ); end if (mapcar 'setvar (list "OSMODE" "CMDECHO")(list oldSnp 1)) (vla-EndUndoMark actDoc) ); end progn ); end if (princ) ); end of c:gecen Is it good? Coordinates in the current UCS. Quote Link to comment Share on other sites More sharing options...
filan1a Posted June 27, 2008 Share Posted June 27, 2008 Thank ASMI i tested it and work fine till now Quote Link to comment Share on other sites More sharing options...
asos2000 Posted July 8, 2009 Author Share Posted July 8, 2009 This is great lisp But can this lisp get the CG of this shape? Quote Link to comment Share on other sites More sharing options...
CADkitt Posted July 23, 2010 Share Posted July 23, 2010 I love this script but it doesn't work with solids I get this error back: ; error: ActiveX Server returned the error: unknown name: "AREA" I don't know a lot (like nothing) of visuallisp, soooo any one who can fix this? Quote Link to comment Share on other sites More sharing options...
fixo Posted July 23, 2010 Share Posted July 23, 2010 You can retrieve volumes from solids instead of area Here is quick edition, not so elegant though Not tested do it by yourself (defun c:gec(/ actDoc cSet cLst oldSnp cCen cAre cmcList cmvList gCen enPt) (vl-load-com) (princ "\n<<<Select Regions or 3D-solids >>> ") (if(setq cSet(ssget '((0 . "REGION,3DSOLID")))) (progn (setq cLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) oldSnp(getvar "OSMODE") ); end setq (mapcar 'setvar (list "OSMODE" "CMDECHO")(list 0 0)) (vla-StartUndoMark (setq actDoc(vla-get-ActiveDocument (vlax-get-acad-object)))) (foreach obj cLst (if (vlax-property-available-p obj 'Centroid) (cond ((eq "AcDbRegion" (vla-get-objectname obj)) (progn (setq cCen(vlax-get obj 'Centroid) cAre(vlax-get obj 'Area) cmcList(cons(list cCen cAre)cmcList) ); end setq ); end progn ) ((eq "AcDb3dSolid" (vla-get-objectname obj)) (progn (setq cCen(vlax-get obj 'Centroid) cVol(vlax-get obj 'Volume) cmvList(cons(list cCen cVol)cmvList) ); end setq ); end progn )) ); end if ); end foreach (if (and cmcList (/= 1(length cmcList)) ); enad and (progn (setq gCen (list (/ (apply '+ (mapcar '* (mapcar 'caar cmcList)(mapcar 'cadr cmcList))) (apply '+ (mapcar 'cadr cmcList)) ); end / (/ (apply '+ (mapcar '* (mapcar 'cadar cmcList)(mapcar 'cadr cmcList))) (apply '+ (mapcar 'cadr cmcList)) ); end / ); end list enPt (polar gCen(/ pi 3) (* (getvar "DIMTXT")(getvar "DIMSCALE") 5)) ); end setq (command "_.qleader" "_non" gCen "_non" enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car gCen)2(getvar "DIMDEC")) "[url="file://\\P"]\\P[/url]" "y="(rtos(cadr gCen)2(getvar "DIMDEC")) ); end strcat ); end vla-put-TextString (foreach pt(mapcar 'car cmcList) (command "_.line" "_non" pt "_non" gCen "") (setq enPt(polar pt(/ pi 3) (*(getvar "DIMTXT")(getvar "DIMSCALE")5))) (command "_.qleader" pt enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car pt)2 2) "[url="file://\\P"]\\P[/url]" "y="(rtos(cadr pt)2 2) ); end strcat ); end vla-put-TextString ); end foreach ); end progn ); end if (if (and cmvList (/= 1(length cmvList)) ); enad and (progn (setq gCen (list (/ (apply '+ (mapcar '* (mapcar 'caar cmvList)(mapcar 'cadr cmvList))) (apply '+ (mapcar 'cadr cmvList)) ); end / (/ (apply '+ (mapcar '* (mapcar 'cadar cmvList)(mapcar 'cadr cmvList))) (apply '+ (mapcar 'cadr cmvList)) ); end / ); end list enPt (polar gCen(/ pi 3) (* (getvar "DIMTXT")(getvar "DIMSCALE") 5)) ); end setq (command "_.qleader" "_non" gCen "_non" enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car gCen)2(getvar "DIMDEC")) "[url="file://\\P"]\\P[/url]" "y="(rtos(cadr gCen)2(getvar "DIMDEC")) ); end strcat ); end vla-put-TextString (foreach pt(mapcar 'car cmvList) (command "_.line" "_non" pt "_non" gCen "") (setq enPt(polar pt(/ pi 3) (*(getvar "DIMTXT")(getvar "DIMSCALE")5))) (command "_.qleader" pt enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car pt)2 2) "[url="file://\\P"]\\P[/url]" "y="(rtos(cadr pt)2 2) ); end strcat ); end vla-put-TextString ); end foreach ); end progn ) (mapcar 'setvar (list "OSMODE" "CMDECHO")(list oldSnp 1)) (vla-EndUndoMark actDoc) ); end progn ); end if (princ) ); end of c:gec ~'J'~ Quote Link to comment Share on other sites More sharing options...
mtahir2003pk Posted July 25, 2010 Share Posted July 25, 2010 I use this lsp code very good... this code is too much help me can we do some more work with this lsp like i want to move my use on region center & then region mass porperty insert into drawing as a text or mtext Thanks & Regards Quote Link to comment Share on other sites More sharing options...
CADkitt Posted July 26, 2010 Share Posted July 26, 2010 It worked only in the x and y axis. I tried adding the Z myself but only succeded in adding a z value that is the same value as the y. (defun c:gec(/ actDoc cSet cLst oldSnp cCen cAre cmcList cmvList gCen enPt) (vl-load-com) (princ "\n<<<Select Regions or 3D-solids >>> ") (if(setq cSet(ssget '((0 . "REGION,3DSOLID")))) (progn (setq cLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) oldSnp(getvar "OSMODE") ); end setq (mapcar 'setvar (list "OSMODE" "CMDECHO")(list 0 0)) (vla-StartUndoMark (setq actDoc(vla-get-ActiveDocument (vlax-get-acad-object)))) (foreach obj cLst (if (vlax-property-available-p obj 'Centroid) (cond ((eq "AcDbRegion" (vla-get-objectname obj)) (progn (setq cCen(vlax-get obj 'Centroid) cAre(vlax-get obj 'Area) cmcList(cons(list cCen cAre)cmcList) ); end setq ); end progn ) ((eq "AcDb3dSolid" (vla-get-objectname obj)) (progn (setq cCen(vlax-get obj 'Centroid) cVol(vlax-get obj 'Volume) cmvList(cons(list cCen cVol)cmvList) ); end setq ); end progn )) ); end if ); end foreach (if (and cmcList (/= 1(length cmcList)) ); enad and (progn (setq gCen (list (/ (apply '+ (mapcar '* (mapcar 'caar cmcList)(mapcar 'cadr cmcList))) (apply '+ (mapcar 'cadr cmcList)) ); end / (/ (apply '+ (mapcar '* (mapcar 'cadar cmcList)(mapcar 'cadr cmcList))) (apply '+ (mapcar 'cadr cmcList)) ); end / ); end list enPt (polar gCen(/ pi 3) (* (getvar "DIMTXT")(getvar "DIMSCALE") 5)) ); end setq (command "_.qleader" "_non" gCen "_non" enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car gCen)2(getvar "DIMDEC")) "\\P" "y="(rtos(cadr gCen)2(getvar "DIMDEC")) "\\P" "z="(rtos(cadr gCen)2(getvar "DIMDEC")) ); end strcat ); end vla-put-TextString (foreach pt(mapcar 'car cmcList) (command "_.line" "_non" pt "_non" gCen "") (setq enPt(polar pt(/ pi 3) (*(getvar "DIMTXT")(getvar "DIMSCALE")5))) (command "_.qleader" pt enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car pt)2 2) "\\P" "y="(rtos(cadr pt)2 2) "\\P" "z="(rtos(cadr pt)2 2) ); end strcat ); end vla-put-TextString ); end foreach ); end progn ); end if (if (and cmvList (/= 1(length cmvList)) ); enad and (progn (setq gCen (list (/ (apply '+ (mapcar '* (mapcar 'caar cmvList)(mapcar 'cadr cmvList))) (apply '+ (mapcar 'cadr cmvList)) ); end / (/ (apply '+ (mapcar '* (mapcar 'cadar cmvList)(mapcar 'cadr cmvList))) (apply '+ (mapcar 'cadr cmvList)) ); end / ); end list enPt (polar gCen(/ pi 3) (* (getvar "DIMTXT")(getvar "DIMSCALE") 5)) ); end setq (command "_.qleader" "_non" gCen "_non" enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car gCen)2(getvar "DIMDEC")) "\\P" "y="(rtos(cadr gCen)2(getvar "DIMDEC")) "\\P" "z="(rtos(cadr gCen)2(getvar "DIMDEC")) ); end strcat ); end vla-put-TextString (foreach pt(mapcar 'car cmvList) (command "_.line" "_non" pt "_non" gCen "") (setq enPt(polar pt(/ pi 3) (*(getvar "DIMTXT")(getvar "DIMSCALE")5))) (command "_.qleader" pt enPt "" "" "#" "") (vla-put-TextString (vlax-ename->vla-object(entlast)) (strcat "x="(rtos(car pt)2 2) "\\P" "y="(rtos(cadr pt)2 2) "\\P" "z="(rtos(cadr pt)2 2) ); end strcat ); end vla-put-TextString ); end foreach ); end progn ) (mapcar 'setvar (list "OSMODE" "CMDECHO")(list oldSnp 1)) (vla-EndUndoMark actDoc) ); end progn ); end if (princ) ); end of c:gec Quote Link to comment Share on other sites More sharing options...
mtahir2003pk Posted July 31, 2010 Share Posted July 31, 2010 i found one more good lsp with short code... this lsp mark centriod of region... with circle... know i want to move my ucs to region centriod... then mass property driectly into cad as a text some one know about massproperty.dwg RCG.lsp Quote Link to comment Share on other sites More sharing options...
nathanjh13 Posted January 20, 2011 Share Posted January 20, 2011 These lisps are great. Does anyone know if there is one that will generate a circle at the centre of gravity of a range of objects (as if they had been combined by the UNION command say). If I have three objects, rather than three circles being generated, is it possible to create a circle at the very c.o.g for all three pieces (as if combined)? It would be helpful for me to not combine them that was all. worth an ask. Many thanks for any replies and to the above work that has been done. Nathan Quote Link to comment Share on other sites More sharing options...
petkovski Posted January 24, 2011 Share Posted January 24, 2011 Hi I am not able to upload file. Give me your mail addres , i will send to you centroid routine. Regards Petkovski Quote Link to comment Share on other sites More sharing options...
