FTBPrimeEvil Posted August 18, 2008 Share Posted August 18, 2008 I have multiple cad drawings (300 *dwg's)that need some items changed, is there a way to seach multiple cad drawing in my project for specific instances of text in each drawing? Do the drawings have to be open? Can you seach just thru the project with out opening each drawing, how does this work? Thank YOU in advance! Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 18, 2008 Share Posted August 18, 2008 I think you can use Windows search using the option 'A word or phrase in the file:' Quote Link to comment Share on other sites More sharing options...
FTBPrimeEvil Posted August 18, 2008 Author Share Posted August 18, 2008 I have vista and can't see how to seach for text with in documents and/or DWG's? Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 18, 2008 Share Posted August 18, 2008 I think you can use Windows search using the option 'A word or phrase in the file:'I don't think this works any more. The dwg compression means that text is not easily found. Quote Link to comment Share on other sites More sharing options...
Strix Posted August 18, 2008 Share Posted August 18, 2008 I'm assuming you already know how to do a global search and replace within one drawing? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 20, 2008 Share Posted August 20, 2008 I am hoping what I write below makes sense. You can easily open 300 dwg's using a script, that script would then run either a lisp or vba to make the text changes then save and close dwg. eg open dwg1 (load "findmytext") close y open dwg2 (load "findmytext") close y etc A couple of hints if you use the command mode (click start button lower left of screen) you can get to your drawing directory then do DIR *.dwg >mylist exit command mode Using word or notepad you can edit the file mylist to create your script. you need to know a bit about navigating directories the old DOS way. I am sure though if you search there is code here to do dwg lists. I am pretty sure I asked here previously about using "find" within scripts and did not get an answer hence suggested lisp or vba. Some one may know a way to do "find" Just in finishing I have left out about the gotchas like a directory with spaces in the name will not work you need some VBA to get around that. here is an example of making slides Filedia 0 open S:\AUTODESK\BLOCKS\AMBULANCe\ambalance_access.dwg zoom extents zoom 0.9x mslide ambalance_access open S:\AUTODESK\BLOCKS\AMBULANCe\ambalance_access_side.dwg zoom extents zoom 0.9x mslide ambalance_access_side open S:\AUTODESK\BLOCKS\AMBULANCe\ambalance_access_side1.dwg zoom extents zoom 0.9x mslide ambalance_access_side1 open S:\AUTODESK\BLOCKS\AMBULANCe\ambalance_perspective.dwg zoom extents zoom 0.9x mslide ambalance_perspective open S:\AUTODESK\BLOCKS\AMBULANCe\ambo zoom extents zoom 0.9x mslide ambo open S:\AUTODESK\BLOCKS\AMBULANCe\Ambulance.dwg zoom extents zoom 0.9x mslide Ambulance filedia 1 Quote Link to comment Share on other sites More sharing options...
ERIK-CADVIZ Posted August 31, 2008 Share Posted August 31, 2008 Hi there, I wrote a LSP a few years ago in which you put a bunch of find and replace strings into a txt file then you can add the lsp to your startup suite and essentially do a batch find and replace on as many drawings as you want. If you are interested I could send it to you and give you a brief explaination of how to use it. Regards, Erik Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 31, 2008 Share Posted August 31, 2008 I have multiple cad drawings (300 *dwg's)that need some items changed, is there a way to seach multiple cad drawing in my project for specific instances of text in each drawing? ToolPac includes a search and replace tool that will operate on any number of drawings. Quote Link to comment Share on other sites More sharing options...
gabriela.g Posted October 29, 2008 Share Posted October 29, 2008 eric, I just saw your message, and I have a similar problem. Would you please send me your code? Quote Link to comment Share on other sites More sharing options...
hosyn Posted May 30, 2013 Share Posted May 30, 2013 Hi there, I wrote a LSP a few years ago in which you put a bunch of find and replace strings into a txt file then you can add the lsp to your startup suite and essentially do a batch find and replace on as many drawings as you want. If you are interested I could send it to you and give you a brief explaination of how to use it. Regards, Erik plzz send this code for me Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 31, 2013 Share Posted May 31, 2013 plzz send this code for me You should check out this wonderful lisp by Lee Mac http://www.lee-mac.com/bfind.html it is just one of the numerous great lisps which Lee very generously makes available, for free, on his site. Thanks Lee! Quote Link to comment Share on other sites More sharing options...
cadvision Posted June 5, 2013 Share Posted June 5, 2013 Check out Multi-Batch and run a search/replace lisp www.multi-batch.com Quote Link to comment Share on other sites More sharing options...
AndyCBR1000RR Posted July 2, 2013 Share Posted July 2, 2013 I have a written small utility provided as a stand alone exe file which allows you to search multiple drawing files for a specific occurrence of any specified text. The program returns a list off all drawings containg the specified text. Utility can also search accross network folders & drives. The utility requires AutoCAD to be installed on the client PC or on the network to be searched. No setup required can be run directly from a USB. If anyone interested please email me at andy_a_graham@hotmail.com Quote Link to comment Share on other sites More sharing options...
AndyCBR1000RR Posted March 26, 2014 Share Posted March 26, 2014 I have a written small utility provided as a stand alone exe file which allows you to search multiple drawing files for a specific occurrence of any specified text. The program returns a list off all drawings containg the specified text. Utility can also search accross network folders & drives. The utility requires AutoCAD to be installed on the client PC or on the network to be searched. No setup required can be run directly from a USB. If anyone interested please email me at andy_a_graham@hotmail.com ** I have now updated the above utility to include a 'Search & Replace' function on the text within AutoCAD drawing files ** Quote Link to comment Share on other sites More sharing options...
