Siberian Posted August 21, 2008 Share Posted August 21, 2008 I have several drawings, all of which have the same layers that I want to turn off. Is there a way to do this just once without having to go through the whole bundle of drawings? Lisp? Quote Link to comment Share on other sites More sharing options...
smorales02 Posted August 21, 2008 Share Posted August 21, 2008 Are the layers you want to turn off within an xref that is attached to all the drawings or are the layers native to each drawing? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted August 22, 2008 Share Posted August 22, 2008 Yes, lisp could do that. Something like: (defun c:layoff() (command "layer" "off" "DIMENSIONS,HATCHES" "") ) replace the words in UPPERCASE with your own layer names. Here I described a way to run a lisp on several drawings: http://www.cadtutor.net/forum/showthread.php?t=19474 Quote Link to comment Share on other sites More sharing options...
rookie37 Posted August 22, 2008 Share Posted August 22, 2008 I had the same problem with layers. I also had to add xrefs Below is a lisp program I/the guys on here wrote for me Modify it for your drawings (DEFUN C:XR2 () (command "._XREF" "_A" "m:\\7635-87\\acad\\XR-Cadastral.dwg" "0,0" "1" "1" "0") (command "._XREF" "_A" "m:\\7635-87\\acad\\XR-sewer.dwg" "0,0" "1" "1" "0") (command "._XREF" "_A" "m:\\7635-87\\acad\\XR-water reticulation.dwg" "0,0" "1" "1" "0") (command "._XREF" "_A" "m:\\7635-87\\acad\\XR-survey.dwg" "0,0" "1" "1" "0") (command "._XREF" "_A" "m:\\7635-87\\acad\\XR-ergon.dwg" "0,0" "1" "1" "0") (command "_.layer" "T" "xr-ergon|ex-elect-ug" "") (command "_.layer" "T" "xr-telstra|ex-telstra" "") (command "_.layer" "on" "xr-telstra|ex-telstra" "") (command "_.layer" "Off" "xr-survey|survey-electricity" "") (command "_.layer" "t" "xr-survey|survey-electricity" "") (command "_.layer" "t" "xr-cadastral|map_address_txt" "") ) Quote Link to comment Share on other sites More sharing options...
Siberian Posted August 26, 2008 Author Share Posted August 26, 2008 Excellent, thx to both Quote Link to comment Share on other sites More sharing options...
grazwelis Posted July 23, 2009 Share Posted July 23, 2009 Yes, lisp could do that. Something like:(defun c:layoff() (command "layer" "off" "DIMENSIONS,HATCHES" "") ) replace the words in UPPERCASE with your own layer names. Here I described a way to run a lisp on several drawings: http://www.cadtutor.net/forum/showthread.php?t=19474 Hello.. I am green LISP could you make attach for that... and how run lisp for several drawings? Please could you give me standart which works Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 27, 2009 Share Posted July 27, 2009 Running lisp over several drawings can be acheived simply using a script file, but before running you need to add the layoff lisp program into you acad.lsp so it can be found automatically. script is then open dwg1 layoff close Y open dwg2 layoff close Y open dwg3 layoff close Y open dwg4 layoff close Y Just create the script in notepad etc save with a name and extension.SCR There are other forum topics here about picking a group of files and having a lsip program do something maybe start with "open files" Quote Link to comment Share on other sites More sharing options...
fuccaro Posted July 30, 2009 Share Posted July 30, 2009 Yes, lisp could do that. Something like:(defun c:layoff() (command "layer" "off" "DIMENSIONS,HATCHES" "") ) replace the words in UPPERCASE with your own layer names. Here I described a way to run a lisp on several drawings: http://www.cadtutor.net/forum/showthread.php?t=19474 Hello.. I am green LISP could you make attach for that... and how run lisp for several drawings? Please could you give me standart which works Thanks Did you check the link in my post? Quote Link to comment Share on other sites More sharing options...
