voyagr12 Posted August 28, 2008 Posted August 28, 2008 I am trying to insert a block via vba from a "Master Block" drawing, into another drawing. This "Master Block" drawing has almost all of our blocks in it. I can insert a dwg file as a block with out any issues. But I am not sure where to start with inserting a particular block from the master block drawing into another drawing. do i use the insertblock method? thanks in advance. Quote
SEANT Posted August 29, 2008 Posted August 29, 2008 The general method would be to open the Block container file: Dim objContainFile as AcadDocument Set objContainFile = ThisDrawing.Application.Documents.Open (Path to document) (or, if you’d prefer to open the document behind the scenes, AxDbDocument.Open with the appropriate ObjectDBX reference included in the VBA project) With the container file now open a: objContainFile.CopyObjects(Objects , Current Drawing) where Objects are the required blocks and Current Drawing is the copied blocks new document. Quote
voyagr12 Posted August 29, 2008 Author Posted August 29, 2008 I apologize, but I think I am somewhat lost. Here is some more information: Wish to insert block into a drawing(Drawing1.dwg) Block I wish to insert is named C01 in a drawing named block_drawing_civil in the following directory: C:\hfl_civil_blocks So the code would be Dim objContainFile as AcadDocument Set objContainFile = AxDbDocument.Open("C:\hfl_civil_blocks\block_drawing_civil.dwg") What do I do from here. Do I still use the insertblock method? How do I actually get the block from within one drawing to the other? Thank you very much for the help. Quote
SEANT Posted August 30, 2008 Posted August 30, 2008 I apologize, but I think I am somewhat lost. Here is some more information: Wish to insert block into a drawing(Drawing1.dwg) Block I wish to insert is named C01 in a drawing named block_drawing_civil in the following directory: C:\hfl_civil_blocks Actually, I apologize. I glossed over a critical step or two in my original post. The example below shows how to deal with the parameters you've listed. Option Explicit Sub TestDwg2DwgBlkTrans() 'Change as required Dim strPath As String Dim strBlockName As String Dim objBlock As AcadBlock Dim entRef As AcadBlockReference Dim dblPkPt() As Double strBlockName = "C01" strPath = "C:\hfl_civil_blocks\block_drawing_civil.dwg" On Error Resume Next Set objBlock = ThisDrawing.Blocks.Item(strBlockName) On Error GoTo 0 If Not objBlock Is Nothing Then objBlock.Delete 'To reinitialize Block from container file DbxCopyBlock strBlockName, strPath 'Copy block into ThisDrawing dblPkPt = ThisDrawing.Utility.GetPoint(, "Pick insertion Point: ") 'Get insertion point for test insert Set entRef = ThisDrawing.ModelSpace.InsertBlock(dblPkPt, "C01", 1#, 1#, 1#, 0#) 'Test insert End Sub Sub DbxCopyBlock(strBlockName As String, strPath As String) Dim strFullDef As String Dim objBlock As AcadBlock Dim colBlocks As AcadBlocks Dim objArray(0) As Object Dim ACDbx As Object Set ACDbx = GetAcDbxDoc() ACDbx.Open strPath Set colBlocks = ACDbx.Blocks Set objBlock = colBlocks.Item(strBlockName) 'Find appropriate block in container file's Blocks Collection Set objArray(0) = objBlock 'Create object array as required by the CopyObjects Method ACDbx.CopyObjects objArray, ThisDrawing.Blocks 'Copy to current drawing's Blocks Collection Set ACDbx = Nothing End Sub Function GetAcDbxDoc() As Object Dim strAcadVersion As String With ThisDrawing.Application strAcadVersion = Mid(.Version, 1, 2) If CInt(strAcadVersion) < 16 Then Set GetAcDbxDoc = .GetInterfaceObject("ObjectDBX.AxDbDocument") Else Set GetAcDbxDoc = .GetInterfaceObject("ObjectDBX.AxDbDocument." & strAcadVersion) End If End With End Function Quote
voyagr12 Posted September 3, 2008 Author Posted September 3, 2008 Thank you so much for you assistance. I am having a slight issue with on line of code Set GetAcDbxDoc = .GetInterfaceObject("ObjectDBX.AxDbDocument." & strAcadVersion) It is telling me "object required" I am thinking it may have something to do with my references but I have the AutoCAD/ObjectDBX common 16.0 Type Library loaded. So not sure if there is another reference that I need, or maybe this isnt even the issue. thanks again for you help. Quote
SEANT Posted September 4, 2008 Posted September 4, 2008 A couple of things: I don’t use Civil 3d so I don’t have any direct way of testing. I thought 2008 used ObjectDBX common 17.0, but I could be wrong. A double check would be to query the AutoCAD system variable ACADVER. If you type that at the command line, the whole number portion would be the number needed in strAcadVersion at the line: Set GetAcDbxDoc = .GetInterfaceObject("ObjectDBX.AxDbDocument." & strAcadVersion) It may make sense to just hardcode that in. Another thing, unrelated to the objectDBX issue – the lines of code: On Error Resume Next Set objBlock = ThisDrawing.Blocks.Item(strBlockName) On Error GoTo 0 If Not objBlock Is Nothing Then objBlock.Delete 'To reinitialize Block from container file were for some initial testing and will need reworking for a routine designed for daily use. Quote
voyagr12 Posted September 10, 2008 Author Posted September 10, 2008 I have everything working great now. Thank you so much for you assistance. It is greatly appreciated. But I have an additional question relating to this. Is there a way for me to select which drawing session I would like to insert the block into. Could I have it insert it into the last accessed? I am sending this from an access database and at times we would have two or more sessions of autocad open. If this were the case, then I would like to be able to select the session and insert the block into this particular session I have selected, or made active. It appears that currently the program inserts the block into the session that was opened first. Thanks Quote
SEANT Posted September 11, 2008 Posted September 11, 2008 Is there a way for me to select which drawing session I would like to insert the block into. Could I have it insert it into the last accessed? I am sending this from an access database and at times we would have two or more sessions of autocad open. If this were the case, then I would like to be able to select the session and insert the block into this particular session I have selected, or made active. It appears that currently the program inserts the block into the session that was opened first. You say you are “sending this from an access database” so I assume you are employing GetObject() at some point (that would also explain why the very first AutoCAD session gets preferential treatment). If that is true, is it possible to initiate your Access code through an AutoCAD VBA routine called from the target session? That would give you the opportunity to pass ThisDrawing.Application – which would conceivably be the correct instance – to the Access routine thus eliminating the need for GetObject. Quote
voyagr12 Posted September 11, 2008 Author Posted September 11, 2008 I wrote some code to open the access database from a session of AutoCAD but it didnt seem to fix my issue. But I did not pass anything, all I did was opened the db from a session of AutoCAD that wasnt the first opened. unfortunately, when I attempted to send a block back to CAD it went to the first instance. But I might be able to "Pass" the current drawing to access when I open it. (if I can figure out how). I will try and let you know. Quote
