Ok I have a Diesel that I want to make any shape from a pline but I can't do it because the requires to know how many points are needed. Like below:
^C^C_pline;\\\\\\\revcloud;a;(* (getvar "dimscale") 0.35);o;n;
Is there any way to allow as many points needed till the box is close, or if I have to use lisp it will be until the user hits enter.
Thanks in advance for everything.
I would draw your pline then push the button for this:
revcloud;a;(* (getvar "dimscale") 0.35);o;l;n; or write a LISP that uses the WHILE to hold the command open til you close the pline
How would you go about making a lisp that will hold until you close the pline or hit enter?
Something like this:
(defun c:plev(/ lOb nPl)
 (setq lOb(entlast))
 (command "_.pline")
 (while(/= 0(getvar "CMDACTIVE"))
   (command pause)
   ); end while
 (if(not(equal c(setq nPl(entlast))))
     (command "_.revcloud" "_a" (* 0.35(getvar "DIMSCALE"))
       "" "_o" nPl "_n")
   ); end if
 ); end of c:plev
 (setq lOb(entlast))
 (command "_.pline")
   (command pause)
   ); end while
          "" "_o" nPl "_n")
   ); end if
 ); end of c:plev
This is what I am trying to do with what you have in this order:
1. Make layers Revcloud2 and Revt2
(command "_.layer" "m" "Revcloud2" "c" "5" "" ""))
(command "_.layer" "m" "RevT2" "c" "145" "" ""))
2. Make layer Revclud2 Current
(command "_,layer" "s" "Revcloud2")
3. Your code
(setq lOb(entlast))
(command "_.pline")
(command pause)
); end while
"" "_o" nPl "_n")
); end if
); end of c:plev
4. Make layer Revt2 Current
(command "_,layer" "s" "Revt2")
5. Insert Revtri Block.
(command "_.INSERT" "revtri" "s" (getvar "dimscale") pause "0")
(command "_.attedit" "n" "y" "" "" "" "l" "1" "2" ))
6. End
I just can't figure out how to put it all together.
Thanks for all your help!!!
Here is a quickie, no testing.
(defun c:MyLisp ()
 (command "_.layer" "m" "Revcloud2" "c" "5" "" "") ; Make layer & sets Current
 [b](c:plev)  ; call the routine[/b]
 (command "_.layer" "s" "Revt2") ; Make layer Revt2 Current
 ;; Insert Revtri Block.
 (command "_.attedit" "n" "y" "" "" "" "l" "1" "2")
(defun c:plev (/ lOb nPl)
 (setq lOb (entlast))
 (command "_.pline")
 (while (/= 0 (getvar "CMDACTIVE")) (command pause))  ; end while
 (if (not (equal c (setq nPl (entlast))))
   (command "_.revcloud" "_a" (* 0.35 (getvar "DIMSCALE")) "" "_o" nPl "_n")
 )       ; end if
)         ; end of c:plev
its coming up with no function definition on the plev command
See the code change above in bold type.
Thanks I got it to work. I changed that and it worked. Thanks again CAB.
