neekcotrack Posted September 12, 2008 Share Posted September 12, 2008 I have resently updated to MEP 2009. The problem I am having is when I go to move any block in the drawing if the block crosses over and MEP duct the snaps snap to it an crash no matter what. There are only two ways I have found to fix it for now. Turn off all snaps before I move, or explode the block within the drawing and make another one. Has anyone had this problem? Yes I have talked to AutoDesk and there looking into it!!!!!! But the quicker I can get this answered will help. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted September 12, 2008 Share Posted September 12, 2008 I have resently updated to MEP 2009. The problem I am having is when I go to move any block in the drawing if the block crosses over and MEP duct the snaps snap to it an crash no matter what. There are only two ways I have found to fix it for now. Turn off all snaps before I move, or explode the block within the drawing and make another one. Has anyone had this problem? Yes I have talked to AutoDesk and there looking into it!!!!!! But the quicker I can get this answered will help. Have you installed all the latest updates, hot fixes, and Service Packs? http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240938 Quote Link to comment Share on other sites More sharing options...
neekcotrack Posted September 12, 2008 Author Share Posted September 12, 2008 Have you installed all the latest updates, hot fixes, and Service Packs? http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240938 Yes that has been all updated and still the same thing. AutoDesk just said to reinstall which did not fix it either. I am so lost. Quote Link to comment Share on other sites More sharing options...
dumfatnhappy Posted September 12, 2008 Share Posted September 12, 2008 Check your memory (RAM). I was very unstable untill I doubled it to 8G. as I said in another thread, right click on the task bar, open task manager and check your physical memory against your RAM. You may be on the edge like I was.... Quote Link to comment Share on other sites More sharing options...
dumfatnhappy Posted September 12, 2008 Share Posted September 12, 2008 the red is what I have on board the blue is what I'm using.... I originally had 4g installed..... now imagine the stability with that, all KINDS of crap was happening with no explanation.... Quote Link to comment Share on other sites More sharing options...
neekcotrack Posted September 15, 2008 Author Share Posted September 15, 2008 the red is what I have on board the blue is what I'm using.... I originally had 4g installed..... now imagine the stability with that, all KINDS of crap was happening with no explanation.... My memory looks fine to me. How are you running 2009 MEP with so high of a memory usage? I usually run two at a time and mine still never gets about 50% of my RAM. Quote Link to comment Share on other sites More sharing options...
neekcotrack Posted November 7, 2008 Author Share Posted November 7, 2008 Ok Autodesk fixed the problem finally for me, in there update #2. Quote Link to comment Share on other sites More sharing options...
