hi all
I am a bit of a newbie where lisp is involved, all i need to do is write the x distance between 2 points to a variable.
can anyone help?
(defun c:test ()
 (setq p1 (getpoint "Pick first point: ")
   p1x (car p1)
     p2x (car (getpoint "Pick second point: " p1))
   xdist (abs (- p1x p2x))
(alert (strcat "The X distance between the two points is " (rtos xdist 2 2) "\nand is saved in the variable Xdist"))
(setq p1 (getpoint "\nPick 1st point."))
(setq p2 (getpoint "\nPick 2nd point."))
(setq x (distance p1 p2))
Thank you for the replies
seems so somple now :S
Ended up using ASMI's method, just tweaked it to a more simple format (for me to understand).
Thanks again!
(defun c:signage ()
(setq POINT1 (getpoint "Pick Top Left: "))
(setq POINT2 (getpoint POINT1 "Pick Bottom Right Corner: "))
(setq POINT1X (car POINT1))
(setq POINT2X (car POINT2))
(setq XDIST (- POINT2X POINT1X))
(setq POINT1Y (cadr POINT1))
(setq POINT2Y (cadr POINT2))
(setq YDIST (- POINT1Y POINT2Y))
(alert (strcat "The X distance between the two points is "(rtos XDIST 2 2)
"\nThe Y distance between the two points is "(rtos YDIST 2 2)))
