ILoveMadoka Posted October 3, 2008 Share Posted October 3, 2008 I've got a few different routines to change the justification to any of the available justifications in Autocad. Each one is pretty verbose. What I'm looking for is a simple routine to pick my text and have it change it to Left Center . No options, no user input. Select Objects Enter Enter Done! Anyone have a simple routine like that or can you point me to one? You guys are awesome! TIA! Quote Link to comment Share on other sites More sharing options...
borgunit Posted October 3, 2008 Share Posted October 3, 2008 Here is an old one I downloaded once... (defun c:tj (/ j e p11 p10 f en plin p10n fn y) (setq j (getstring "\nLeft/Center/Middle/Right ")) (setq j (strcase j)) (setq e (entget (car (entsel)))) (setq p11 (assoc 11 e)) (setq p10 (assoc 10 e)) (setq f (assoc 72 e)) (setq en e) (if (= (cdr f) 0) (setq plin (cons 11 (cdr p10)))) (if (= (cdr f) 0) (setq en (subst plin p11 en))) (if (and (= j "L") (/= (cdr f) 0)) (progn (setq p10 (cons 10 (cdr p11))) (setq en (subst p1on p10 en)) ) ) (IF (= J "L") (setq fn 0)) (IF (= J "C") (setq fn 1)) (IF (= J "M") (setq fn 4)) (IF (= J "R") (setq fn 2)) (setq fn (cons 72 fn)) (setq en (subst fn f en)) (entmod en) (princ) ) Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted October 5, 2008 Author Share Posted October 5, 2008 Nope that's not it. I have that one and it doesn't address the "newer" justifications. I think the Middle Left, etc.. use both (assoc 71 & (assoc 72 Autocad release 9 had just come out when I started CAD... So Middle Left and such were not around back then.. I guess if I could nail down group codes are specific to a particular justification I could modify the above code to suit. Quote Link to comment Share on other sites More sharing options...
CAB Posted October 6, 2008 Share Posted October 6, 2008 (defun c:tjLeft(/ ss obj) (vl-load-com) (and (setq ss (ssget "_+.:E:S" '((0 . "TEXT")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (vla-put-alignment obj acAlignmentLeft) ) (princ) ) ;| acAlignmentLeft acAlignmentCenter acAlignmentRight acAlignmentAligned acAlignmentMiddle acAlignmentFit acAlignmentTopLeft acAlignmentTopCenter acAlignmentTopRight acAlignmentMiddleLeft acAlignmentMiddleCenter acAlignmentMiddleRight acAlignmentBottomLeft acAlignmentBottomCenter acAlignmentBottomRight |; Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted October 14, 2008 Author Share Posted October 14, 2008 WOW! You are way out of my league!! Thanks so much!! Awesome programming knowledge! Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted October 14, 2008 Author Share Posted October 14, 2008 So what is the syntax for Center Justified? I thought it was simply replacing acAlignmentLeft with acAlignmentCenter but that moved my text to 0,0 Thanks so much! (defun c:tjLeft(/ ss obj) (vl-load-com) (and (setq ss (ssget "_+.:E:S" '((0 . "TEXT")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (vla-put-alignment obj acAlignmentLeft) ) (princ) ) ;| acAlignmentLeft acAlignmentCenter acAlignmentRight acAlignmentAligned acAlignmentMiddle acAlignmentFit acAlignmentTopLeft acAlignmentTopCenter acAlignmentTopRight acAlignmentMiddleLeft acAlignmentMiddleCenter acAlignmentMiddleRight acAlignmentBottomLeft acAlignmentBottomCenter acAlignmentBottomRight |; Quote Link to comment Share on other sites More sharing options...
CAB Posted October 14, 2008 Share Posted October 14, 2008 Use this routine to get the object properties: (defun c:dump (/ ent obj) (while (setq ent (entsel "\nSelect entity to get object data: ")) (setq obj (vlax-ename->vla-object (car ent))) (vlax-dump-object obj t) (vlax-release-object obj) ) (princ) ) Select object: #<VLA-OBJECT IAcadText 02ce832c> ; IAcadText: AutoCAD Text Interface ; Property values: ; Alignment = 0 ; Application (RO) = #<VLA-OBJECT IAcadApplication 00ac8928> ; Backward = 0 ; Color = 256 ; Document (RO) = #<VLA-OBJECT IAcadDocument 01b694bc> ; Handle (RO) = "A367" ; HasExtensionDictionary (RO) = 0 ; Height = 5.0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 02cebb0c> ; InsertionPoint = (1799.16 -194.612 0.0) ; Layer = "POWER" ; Linetype = "ByLayer" ; LinetypeScale = 1.0 ; Lineweight = -1 ; Normal = (0.0 0.0 1.0) ; ObjectID (RO) = 29887800 ; ObjectName (RO) = "AcDbText" ; ObliqueAngle = 0.0 ; OwnerID (RO) = 29804560 ; PlotStyleName = "ByLayer" ; Rotation = 0.0 ; ScaleFactor = 1.0 ; StyleName = "SIMPLEX 0" ; TextAlignmentPoint = (0.0 0.0 0.0) ; TextGenerationFlag = 0 ; TextString = "this is a" ; Thickness = 0.0 ; UpsideDown = 0 ; Visible = -1 See if this is what you wanted: (defun c:tjc(/ ss obj) (vl-load-com) (if (and (setq ss (ssget "_+.:E:S" '((0 . "TEXT")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (setq ipt (vla-get-InsertionPoint obj))) (progn (vla-put-alignment obj acAlignmentCenter) (vla-put-TextAlignmentPoint obj ipt) ) ) (princ) ) ;| acAlignmentLeft acAlignmentCenter acAlignmentRight acAlignmentAligned acAlignmentMiddle acAlignmentFit acAlignmentTopLeft acAlignmentTopCenter acAlignmentTopRight acAlignmentMiddleLeft acAlignmentMiddleCenter acAlignmentMiddleRight acAlignmentBottomLeft acAlignmentBottomCenter acAlignmentBottomRight |; Quote Link to comment Share on other sites More sharing options...
Longchamp Posted May 21, 2009 Share Posted May 21, 2009 Sorry i dont know much about programming within autoCAD. Could someone tell me how i would install this? i'm using land desktop 06 Quote Link to comment Share on other sites More sharing options...
Zorg Posted May 21, 2009 Share Posted May 21, 2009 Sorry i dont know much about programming within autoCAD. Could someone tell me how i would install this? i'm using land desktop 06 add it to your ACAD.LSP file Quote Link to comment Share on other sites More sharing options...
CAB Posted May 21, 2009 Share Posted May 21, 2009 Copy the code making sure you get the last line of the code, sometimes that is missed. Paste it into your text editor like NotePad. Save it to your ACAD folder, I have a sub folder named LISP which I save to. Use APPLOAD at the command line Navigate to the file you just saved & load it or add to your StartUp Suite to be loaded for each DWG. Note that load will only install the routine for the current DWG & only for this session. Look at the lisp file for (defun the one above has this (defun c:tjc(/ ss obj) c: means you can run it from the command line by typing tjc If the c: was missing like this (defun tjc(/ ss obj) You would need to enter (tjc) to run it. Anyone seeing anything I left out please chime in. HTH Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 21, 2009 Share Posted May 21, 2009 Anyone seeing anything I left out please chime in. Great bit of advice, just a few pointers I might add if I may... When saving the file in notepad or another Text Editor, make sure that the box "Save as Type" is set to "All Files", and use the extension ".lsp" when saving. Alternatively to using the Start-up Suite, you could make a call to load the LISP from your ACADDOC.lsp which loads at every drawing session. More help can be found here HTH also, Lee Quote Link to comment Share on other sites More sharing options...
CAB Posted May 21, 2009 Share Posted May 21, 2009 Thanks Lee, Also Note If you want to use a file to automatically load a lisp I do not recommend using the ACAD.lsp file! It may be over written any time you upgrade ACAD or re-install ACAD. Use the ACADDOC.lsp like this: First see if it exist by typing this at the command line (findfile "acaddoc.lsp") If it returns a path you should use your editor to add a line to it. (load "AlansAutoLoad.lsp") make up a file name for your system like (load "MyAutoLoad.lsp") If the file does not exist then create one with your editor. Add this (load "MyAutoLoad.lsp") (princ) then save as ACADDOC.LSP making sure you save it in the ACAD search path. Now create another file with your editor called MyAutoLoad.lsp Add this to the file: ;;; =============================================== ;;; Lisp Routine Loader ;;; AUTOLOAD only loads the routine when needed ;;; =============================================== ;;;------ Lisp name -- Function name(s) ------- Discription ----------------------- (AUTOLOAD "MyLispFileName" '("FunctionName")) ; comment what it does (princ) ;; End of file Also save it to the ACAD search path. Now each time your open a DWG the "MyLispFileName" routine will be loaded if you enter FunctionName at the command line. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 21, 2009 Share Posted May 21, 2009 This information should definitely be added to the FAQ at some point The article we have in there at the moment is somewhat brief... http://www.cadtutor.net/faq/questions/53/How+do+I+automatically+load+variables%3F Quote Link to comment Share on other sites More sharing options...
