Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,148
    If you are only given the x dimension and an angle, then you can always construct the required length. You cannot enter it directly
  2. #12
    Super Member SuperCAD's Avatar
    SuperCAD's Computer Details
    Win7 Professional 64bit
    Some POS given to my by corporate...
    16G :-(
    NVIDIA 2000
    500G
    Manufacture
    SuperCAD's Discipline Details
    Detailer
    Manufacture
    Drawings for a steel manufacturing company.
    Solidworks 2016
    Sep 2008
    WI, USA
    762
    What about drawing two lines at a 90 degree angle and then using the Chamfer option? Just hit the button and type D for distance and then set Distance 1 to 0.25. Distance 2 should automatically be set to 0.25 as well, but you can change it to be any other dimension you like.
  3. #13
    Junior Member
    honestbud's Computer Details
    XP
    1.73 GHz
    1.5 GB
    Construction
    honestbud's Discipline Details
    civil engineer
    Construction
    I work as a construction site engineer.
    AutoCAD 2014
    Jan 2010
    Iran,Tehran
    10
    i searched for "drawing a line with specific angle" and then if found this pages.i read this 2 pages.
    Quote Originally Posted by SuperCAD View Post
    chamber is best chois for drawing a line at specific angle WHEN you already have 2 object. but sometimes you start drawing in blank screen.you need to draw a line with X distant and angle. i prefer to draw line and then ROTATE it.
    dose anybody have any practical solution?
  4. #14
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Eldon, back to trig! TANKS for the reminder.
    The "Cheesehead" has a better idea. What happened to the Vikings?
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  5. #15
    Forum Newbie
    Map 3D 2013
    Jan 2013
    1
    you can always use some inline lisp.
    This should work:
    l[enter]
    x,y[enter]
    <angle[enter]
    (/ dx (sin (* angle (/ pi 180))))[enter]
    where
    x,y are the coordinates of the firs point
    dx is the desired dimension on x axis
    angle is the desired angle
    To answer the question:
    <45
    (/ 0.25 (sin (* 45 (/ pi 180))))
  6. #16
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Nyd, I believe that you should use Cosine instead of Sine trigonometric function - although it works for your case since the angle is 45 degrees.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  7. #17
    Senior Member
    Manufacture
    iainlines's Discipline Details
    Manufacture
    I make boxes n stuff!
    AutoCAD 2013
    Dec 2011
    Smack bang in the middle of England
    264
    Draw a line 0.25 in X axis, draw a line straight up from this longer than needed. Then go back to your starting point and use <45 to draw a line that intersects the upright (Y axis) line. Trim to produce the desired results.
    That said, chamfer is really the best and easiest way
  8. #18
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Chamfer is easiest.
    Next best way might be to Offset .25
    or with Otracking draw vertical line, select the line, get rotation grip and rotate and trim as needed
    or
    polar tracking and trim
    or xline
    or ray
    ...........so many ways that will work even when not 45°
  9. #19
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,129
    Hopefully the OP has figured this out in the last 4 1/2 years.
  10. #20
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2013
    Dec 2011
    264
    That's the second time I've done something like that. I think it was 9 years last time. I feel slightly less silly as JDM was also caught out. D'oh!
  1. Replies: 7
    Last Post: 6th May 2010, 01:39 pm
  2. lisp to draw line on same angle as line picked
    By john_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2009, 03:32 pm
  3. How to draw a cylinder at a specific angle
    By cruzersoul in forum AutoCAD 3D Modelling & Rendering
    Last Post: 1st May 2009, 01:55 pm
  4. draw a line using VBA with an angle and a length?
    By wbluem88 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Aug 2008, 06:07 pm
  5. Drawing line at a specific angle.
    By bobsly in forum AutoCAD General
    Last Post: 2nd Jun 2006, 02:38 pm
